    [Plugin] Pivot Around Axis
    32 Posts 15 Posters 27.6k Views 15 Watching
    • xiombargX Offline
      xiombarg
      This is massively helpful for me. I wish I would have noticed it earlier.
      Cookie sent! 😄
      • halroachH Offline
        halroach
        @thomthom said:
        Yup. I added a couple of things today, like being able to rotate groups. And click on other instances to adjust another object without existing the tool. Will hook up the VCB shortly.
        Hi Thom,
        Nice plugin!
        I can't seem to be able to select other objects when in the tool.
        Also it works only after I've selected an object. If nothing is selected, and the tool is run, nothing much happens... maybe I'm missing something?
        Thanks!! Many Cookies!!!
        FlexTools - Super Quick Windows, Doors, Slats...
          What other objects are you trying to select? What type of entities?
          • halroachH Offline
            halroach
            components...
              Hmm... that should work, after the tool is active it should be possible to click other components (in the same context though)
              • halroachH Offline
                halroach
                I click to turn the tool on. I click on any component, and it just doesn't do anything. Only if I have a component pre-selected and then activate the tool it works. But then I am limited to playing around with only that component. I cannot select other components without exiting the tool, selecting, and then running it again...
                Maybe it's cause I'm using sketchup 2015 and not 2016?
                  Shouldn't be any difference between SU2015 and SU2016. This extension was created years ago.
                  Can you video-capture what you do? Maybe share a model?
                  • halroachH Offline
                    halroach
                    See attached video:
                    pivot_around_axis_01.avi
                      Hm... I wasn't able to play that in WMP. What codec are you using?
                      • halroachH Offline
                        halroach
                        I must have messed up something with the video, here it is on youtube instead:
                        https://youtu.be/8T2krSYI8_w
                          Huh,... looks like this isn't implemented after all. I must be confusing it with another extension.
                          • micioneM Offline
                            micione
                            Strange. It works well for me in SU 2016
                            • 2 / 2
