    OMG! fur plugin is AMAZING!
    168 Posts 44 Posters 62.0k Views 44 Watching
    • olisheaO Offline
      olishea
      ah you projected the grass onto that jagged geometry! sneaky sneaky! i wondered what the blue bits were but its just the reverse face, right? 😲
      looks mint
      oli
      • soloS Offline
        solo
        yup, easy as pie.
        http://www.solos-art.com
        • W Offline
          wyatt
          I may be a little slow, but why is the component and clip map upside-down?
          • soloS Offline
            solo
            The way it was baked. πŸ’š just apply as is, it will show correctly.
              d12dozr
              Pete that's crafty! Can I make that component work in Twilight? I did a quick test and it didn't look right..
              http://goo.gl/f7ooYh
              • michaliszissiouM Offline
                michaliszissiou
                Pete, nice grass, really convincing! πŸ‘
                • soloS Offline
                  solo
                  marcus, I'm not sure it will work, as there is no option to insert an alpha map as far as I can see. 😞
                  Here is another one, I used some low poly coconut palms. (whole model is only 1.6mb)
                  • FrederikF Offline
                    Frederik
                    Looks GREAT, Pete... πŸ‘
                    I only wish there were an option to avoid components from intersecting (like we've both requested for the component spray tool)...
                    Perhaps this can be added in a future version...
                    One question...
                    For this particular component, why have you turned it upside down...??
                    It will only work correct if you apply/spray it to a surface showing the backface - or am I missing something...?? πŸ˜•
                    Regarding Twilight Render:
                    As Pete already have mentioned, you can't get this Buffalo grass to work correct, since you're unable to apply a seperate clipping mask (alpha mask) in the current TWR material editor... 😞
                    However, if you're able to save the texture with a transparent background (I.e. as a .png file), it will automatically be made into an alpha-channel... πŸ˜‰
                    Cheers
                    Kim Frederik
                    • boofredlayB Offline
                      boofredlay
                      Nice Pete.
                        briggs
                        @solo said:
                        Briggs, it's pretty simple really, create a plane, import the component you want to populate, select it in the drop down window as the component to populate and enter.
                        Then in your render app, use the supplied alpha map as the clipmap as it's already UV mapped and will work without fail.
                        Righto, I'll give it a go in podium.... Clipmaps have always been my enemy in podium but I'll give it a whirl! Those palm trees look great solo πŸ‘
                        • soloS Offline
                          solo
                          This is an addictive plugin.
                          • X Offline
                            xrok1
                            and with thea, you could use fur in combination with displacement to double the flexibility! πŸ˜„
                            β€œThere are three classes of people: those who see. Those who see when they are shown. Those who do not see.”
                              briggs
                              With what you've done there Solo does SUp slow down massively? If it doesn't I can't wait to give it a try and make some full scale scenes I thought would only be capable using something like 3DS max!
                              Oh, and here's one of mine......
                              Grass through the grid:
                                d12dozr
                                Thanks for the component, Pete, and for the tech support, Frederick.
                                Here is Pete's component Twilight-ready πŸ˜„
                                bufalo grass png.skp
                                • olisheaO Offline
                                  olishea
                                  briggs: if you put the grass on hidden layer it will not slow down sketchup. just turn the layer on before rendering...i assume you are using podium. i place all my heavy geometry on hidden layers, its so much better
                                  nice one d12
                                  oli
                                    Rico91
                                    http://lh3.ggpht.com/_rMc47FEl0fA/S-1CLDIV09I/AAAAAAAAB_M/VbdjAQArNwY/untitled.56.jpg
                                    [img:y90a5vdg]http://lh5.ggpht.com/_rMc47FEl0fA/Sro-DozMGPI/AAAAAAAABwU/zZsLbdpwWAs/forum_onderschrift_r3d_30pxh.jpg[/img:y90a5vdg] [url:y90a5vdg]http://www.R3Design.nl[/url:y90a5vdg]
                                      briggs
                                      nice one d12
                                      Cheers for the tip oli. I'd just seen your post about doing this earlier on, it works too. Not a chance my puny little laptop can take progressive renders with all that geometry now though 😲 Think I might move onto Maxwell soon, that should hopefully open up a few more doors for me! I've been toying with getting Twilight but I like the idea of having an outside "studio" program to work in.
                                      I honestly think if Pete's technique is fully explored then it will enable SU to create some renders that are up there with the best in terms of scene composition and environment construction! Who needs 3ds? πŸ˜‰
                                        mitsubishi_becloud
                                        Using the fur plugin for the first time, I used default settings as well as mixing them up a bit. This is the best I can come up with and it still looks like crap. Anybody got any suggestions as to why the grass is showing up blotchy over the selected area?
                                          Hi Bran,
                                          "Tune up" the Density and the Max number settings (top two) considerably. The first is set to 200 pieces per 1 m2 (or about 9 square feet) which is obviously too low for a real, dense grass.
                                          Be carefully however NOT to populate your scene with too many instances as they can (and definitely WILL) slow down SU considerably. Experiment with smaller areas first to see what results you get.
                                          • massimoM Offline
                                            massimo Moderator
                                            Bran, you can also hit the "make fur" button many times on the same surface.
                                            • 6
                                            • 7
                                            • 8
                                            • 9
                                            • 5 / 9
