    OMG! fur plugin is AMAZING!
    168 Posts 44 Posters 76.5k Views 44 Watching
      sketchnl
      @olishea said:
      from the cigarette rendering challenge a while back:
      lets smoke some grass! 😎
      http://i654.photobucket.com/albums/uu269/olishea/4-1.jpg
      πŸ˜† very cool oli 😎
      http://www.sketchimpressions.nl
      • olisheaO Offline
        olishea
        nice one dylan! although i wouldn't like to sit on it! πŸ˜„
        here is another one. next time I will use high res grass component.
        "Morning Dew"
        [EDIT] improved grass contrast
        http://i654.photobucket.com/albums/uu269/olishea/6-1.jpg
        with crude dof blur:
        http://i654.photobucket.com/albums/uu269/olishea/6_dof.jpg
        [EDIT]: I ruined michalis' amazing sculpture. Again, sorry mate!
        http://i654.photobucket.com/albums/uu269/olishea/Picture34.png
        oli
        • soloS Offline
          Bufalo grass.
          • olisheaO Offline
            olishea
            i don't understand what you've done there pete! but it looks sweet!
            oli
            • soloS Offline
              Oli, and anyone that wants it, here it is.
              bufalo grass1.skp
              And here is the clip map/alpha:
                briggs
                Wow - It looks absolutely awesome!
                I'm currently trying to learn how to get grass into sketchup renders, it would be really helpful if you could just put up a few pointers on how you achieved that image 😎
                • soloS Offline
                  Briggs, it's pretty simple really, create a plane, import the component you want to populate, select it in the drop down window as the component to populate and enter.
                  Then in your render app, use the supplied alpha map as the clipmap as it's already UV mapped and will work without fail.
                  • olisheaO Offline
                    olishea
                    ah you projected the grass onto that jagged geometry! sneaky sneaky! i wondered what the blue bits were but its just the reverse face, right? 😲
                    looks mint
                    oli
                    • soloS Offline
                      yup, easy as pie.
                      • W Offline
                        wyatt
                        I may be a little slow, but why is the component and clip map upside-down?
                        • soloS Offline
                          The way it was baked. πŸ’š just apply as is, it will show correctly.
                            d12dozr
                            Pete that's crafty! Can I make that component work in Twilight? I did a quick test and it didn't look right..
                            http://goo.gl/f7ooYh
                            • michaliszissiouM Offline
                              michaliszissiou
                              Pete, nice grass, really convincing! πŸ‘
                              • soloS Offline
                                marcus, I'm not sure it will work, as there is no option to insert an alpha map as far as I can see. 😞
                                Here is another one, I used some low poly coconut palms. (whole model is only 1.6mb)
                                • FrederikF Offline
                                  Frederik
                                  Looks GREAT, Pete... πŸ‘
                                  I only wish there were an option to avoid components from intersecting (like we've both requested for the component spray tool)...
                                  Perhaps this can be added in a future version...
                                  One question...
                                  For this particular component, why have you turned it upside down...??
                                  It will only work correct if you apply/spray it to a surface showing the backface - or am I missing something...?? πŸ˜•
                                  Regarding Twilight Render:
                                  As Pete already have mentioned, you can't get this Buffalo grass to work correct, since you're unable to apply a seperate clipping mask (alpha mask) in the current TWR material editor... 😞
                                  However, if you're able to save the texture with a transparent background (I.e. as a .png file), it will automatically be made into an alpha-channel... πŸ˜‰
                                  Cheers
                                  Kim Frederik
                                  • boofredlayB Offline
                                    boofredlay
                                    Nice Pete.
                                      briggs
                                      Righto, I'll give it a go in podium.... Clipmaps have always been my enemy in podium but I'll give it a whirl! Those palm trees look great solo πŸ‘
                                      • soloS Offline
                                        This is an addictive plugin.
                                        • X Offline
                                          xrok1
                                          and with thea, you could use fur in combination with displacement to double the flexibility! πŸ˜„
                                            briggs
                                            With what you've done there Solo does SUp slow down massively? If it doesn't I can't wait to give it a try and make some full scale scenes I thought would only be capable using something like 3DS max!
                                            Oh, and here's one of mine......
                                            Grass through the grid:
                                            • 5 / 9
