    OMG! fur plugin is AMAZING!
    168 Posts 44 Posters 74.4k Views 44 Watching
    • olisheaO Offline
      olishea
      nice one dylan! although i wouldn't like to sit on it! πŸ˜„
      here is another one. next time I will use high res grass component.
      "Morning Dew"
      [EDIT] improved grass contrast
      http://i654.photobucket.com/albums/uu269/olishea/6-1.jpg
      with crude dof blur:
      http://i654.photobucket.com/albums/uu269/olishea/6_dof.jpg
      [EDIT]: I ruined michalis' amazing sculpture. Again, sorry mate!
      http://i654.photobucket.com/albums/uu269/olishea/Picture34.png
      oli
      • soloS Offline
        Bufalo grass.
        • olisheaO Offline
          olishea
          i don't understand what you've done there pete! but it looks sweet!
          oli
          • soloS Offline
            Oli, and anyone that wants it, here it is.
            bufalo grass1.skp
            And here is the clip map/alpha:
              briggs
              Wow - It looks absolutely awesome!
              I'm currently trying to learn how to get grass into sketchup renders, it would be really helpful if you could just put up a few pointers on how you achieved that image 😎
              • soloS Offline
                Briggs, it's pretty simple really, create a plane, import the component you want to populate, select it in the drop down window as the component to populate and enter.
                Then in your render app, use the supplied alpha map as the clipmap as it's already UV mapped and will work without fail.
                • olisheaO Offline
                  olishea
                  ah you projected the grass onto that jagged geometry! sneaky sneaky! i wondered what the blue bits were but its just the reverse face, right? 😲
                  looks mint
                  oli
                  • soloS Offline
                    yup, easy as pie.
                    • W Offline
                      wyatt
                      I may be a little slow, but why is the component and clip map upside-down?
                      • soloS Offline
                        The way it was baked. πŸ’š just apply as is, it will show correctly.
                          d12dozr
                          Pete that's crafty! Can I make that component work in Twilight? I did a quick test and it didn't look right..
                          http://goo.gl/f7ooYh
                          • michaliszissiouM Offline
                            michaliszissiou
                            Pete, nice grass, really convincing! πŸ‘
                            • soloS Offline
                              marcus, I'm not sure it will work, as there is no option to insert an alpha map as far as I can see. 😞
                              Here is another one, I used some low poly coconut palms. (whole model is only 1.6mb)
                              • FrederikF Offline
                                Frederik
                                Looks GREAT, Pete... πŸ‘
                                I only wish there were an option to avoid components from intersecting (like we've both requested for the component spray tool)...
                                Perhaps this can be added in a future version...
                                One question...
                                For this particular component, why have you turned it upside down...??
                                It will only work correct if you apply/spray it to a surface showing the backface - or am I missing something...?? πŸ˜•
                                Regarding Twilight Render:
                                As Pete already have mentioned, you can't get this Buffalo grass to work correct, since you're unable to apply a seperate clipping mask (alpha mask) in the current TWR material editor... 😞
                                However, if you're able to save the texture with a transparent background (I.e. as a .png file), it will automatically be made into an alpha-channel... πŸ˜‰
                                Cheers
                                Kim Frederik
                                • boofredlayB Offline
                                  boofredlay
                                  Nice Pete.
                                    briggs
                                    Righto, I'll give it a go in podium.... Clipmaps have always been my enemy in podium but I'll give it a whirl! Those palm trees look great solo πŸ‘
                                    • soloS Offline
                                      This is an addictive plugin.
                                      • X Offline
                                        xrok1
                                        and with thea, you could use fur in combination with displacement to double the flexibility! πŸ˜„
                                          briggs
                                          With what you've done there Solo does SUp slow down massively? If it doesn't I can't wait to give it a try and make some full scale scenes I thought would only be capable using something like 3DS max!
                                          Oh, and here's one of mine......
                                          Grass through the grid:
                                            d12dozr
                                            Thanks for the component, Pete, and for the tech support, Frederick.
                                            Here is Pete's component Twilight-ready πŸ˜„
                                            bufalo grass png.skp
                                            • 5 / 9
