    [Plugin] Make Fur v.2.1.0(20140323)
    650 Posts 255 Posters 1.2m Views 254 Watching
    • massimoM Offline
      massimo Moderator
      Go to the very first post of the thread and scroll down a bit the page. Is there.
        ATBP
        Very nice.
          Latetzki
          What can I do to make this more precise so it wont place anything outside the selected face??
            DavorP
            Plugin is great but I have a problem. I use previously modeled component as fur instance. What happens is that each component that fur drops is inverted. How can I make sure this does not happen?
              DavorP
              You could use offset tool to make the area smaller. If the component is proprely centered on origin then measure the horizontal distance from origin to the farthest point of component geometry. Use that value to offset the boundary. If you have surface use offset on surface tool.
                tak2hata
                Hi,Davor.
                I guess that problem....
                Fur brade may up to Z aixis in the component.
                so I think your component is filpped for Z axis.
                or Your selected face for making fur is flipped.
                The Selected Face must directed to upward for you want.
                or The value of Force(Z) is too strong.
                Is your case there?
                Hi,Latetzki.
                I think like as Davor's,too.
                Fur is created on the points of selected face.
                But,The blade of fur has width.
                offset the face if you want more precise inside.
                Thanks.
                by TAK2HATA
                  tak2hata
                  Hi,All.
                  I update to version2.0.1 in 2013.06.02.
                  UI is improved.
                  Hi,zieios.
                  The icon is pretty cool! 😍
                  Fur will be grown thick on sketchup!
                  Thanks.
                  by TAK2HATA
                    Anton_S
                    Amazing plugin!!!
                    I just got a hair cut, and didn't know how to fullfill my hair.
                    But, now I found a way
                    Thank you 😎
                    • P Offline
                      pepa
                      Thanks for update, there is a czech translation.
                      fur_lang_cz.txt
                      http://jsvizualizace.daportfolio.com/
                        tak2hata
                        Hi,All.
                        Now I place the new language files in language folder.
                        fur_lang_farsi.txt:Persian translation by Majid.Thanks!
                        fur_lang_cz.txt:Czech translation by Pepa.Thanks!
                        Hi,Anton!
                        Nice hair!
                        I wish if I had hair like him.
                        It will need too much hair spray.
                        Thanks!
                        by TAK2HATA
                        • majidM Online
                          majid
                          Thank you for update and new interface 😍 πŸ‘
                            macmac12
                            thanks for the update πŸ˜„
                            • OxerO Offline
                              Oxer
                              Thanks for the update, I have done a new translation for Spanish Language, I add new strings to the file.
                              Spanish Language v2.0.4
                              fur_lang_esv2.0.4.txt
                              http://www.oxervision.blogspot.com/
                              • H Offline
                                hebeijianke
                                Chinese translation new
                                fur_lang_cn.txt
                                • olisheaO Offline
                                  olishea
                                  thanks for the update. great plugin πŸ‘
                                  oli
                                  • erikBE Offline
                                    erikB
                                    thanks for the update, great plugin I use it regularly.
                                    erikB
                                      tak2hata
                                      Thanks Hebeijianke and Oxer for uploading the translation files.
                                      Now I'm busy ,so I will update plugin including these translation files in the end of this week.
                                      Thank you very much!
                                      by TAK2HATA
                                        tak2hata
                                        Hi,All.
                                        I update to v2.0.5.
                                        Include new language file for Spanish and Chinese.
                                        Thanks Oxer and Hebeijianke!
                                        Enjoy!
                                        by TAK2HATA
                                          meoa
                                          Preview shows fur on the selected face but after clicking make fur, quite a number of it go off the selected face. The ones on the face are also scattered unevenly unlike the preview.
                                          Is this what should happen or am i doing something wrong ?
                                          Ok, sketchup just crashed. I tried it again and it seems to be fine now. Fur stays on the faces. I stil don't know what happened before and the cause.
                                            tak2hata
                                            Hi,meoa.
                                            I need more information for your problem.
                                            I can not know what happened, too.
                                            Please upload your model and the picture of the fur setting and selected face.
                                            Thanks.
                                            by TAK2HATA
                                            • 23
                                            • 24
                                            • 25
                                            • 26
                                            • 27
                                            • 32
                                            • 33
                                            • 25 / 33
