    [Plugin] Make Fur v.2.1.0(20140323)
    650 Posts 255 Posters 1.2m Views 254 Watching
      @jujepoy said:
      where to download?
      In the first post on the first page of this thread.
        cucumuda
        how to i get the plugin?
        can u tell me how to download the plugin.... πŸ˜„
        the plugin very nice....
          Click on this link πŸ˜‰
          it's the same than the current version that you can find on the first post of this thread!
          Download it Unzip and put it on the Plugins folder!
            jujepoy
            pls help me where to download this plug.in
            • massimoM Offline
              massimo Moderator
              Go to the very first post of the thread and scroll down a bit the page. Is there.
                ATBP
                Very nice.
                  Latetzki
                  What can I do to make this more precise so it wont place anything outside the selected face??
                    DavorP
                    Plugin is great but I have a problem. I use previously modeled component as fur instance. What happens is that each component that fur drops is inverted. How can I make sure this does not happen?
                      DavorP
                      You could use offset tool to make the area smaller. If the component is proprely centered on origin then measure the horizontal distance from origin to the farthest point of component geometry. Use that value to offset the boundary. If you have surface use offset on surface tool.
                        tak2hata
                        Hi,Davor.
                        I guess that problem....
                        Fur brade may up to Z aixis in the component.
                        so I think your component is filpped for Z axis.
                        or Your selected face for making fur is flipped.
                        The Selected Face must directed to upward for you want.
                        or The value of Force(Z) is too strong.
                        Is your case there?
                        Hi,Latetzki.
                        I think like as Davor's,too.
                        Fur is created on the points of selected face.
                        But,The blade of fur has width.
                        offset the face if you want more precise inside.
                        Thanks.
                        by TAK2HATA
                          tak2hata
                          Hi,All.
                          I update to version2.0.1 in 2013.06.02.
                          UI is improved.
                          Hi,zieios.
                          The icon is pretty cool! 😍
                          Fur will be grown thick on sketchup!
                          Thanks.
                          by TAK2HATA
                            Anton_S
                            Amazing plugin!!!
                            I just got a hair cut, and didn't know how to fullfill my hair.
                            But, now I found a way
                            Thank you 😎
                              pepa
                              Thanks for update, there is a czech translation.
                              fur_lang_cz.txt
                              http://jsvizualizace.daportfolio.com/
                                tak2hata
                                Hi,All.
                                Now I place the new language files in language folder.
                                fur_lang_farsi.txt:Persian translation by Majid.Thanks!
                                fur_lang_cz.txt:Czech translation by Pepa.Thanks!
                                Hi,Anton!
                                Nice hair!
                                I wish if I had hair like him.
                                It will need too much hair spray.
                                by TAK2HATA
                                • majidM Offline
                                  majid
                                  Thank you for update and new interface 😍 πŸ‘
                                    macmac12
                                    thanks for the update πŸ˜„
                                    • OxerO Offline
                                      Oxer
                                      Thanks for the update, I have done a new translation for Spanish Language, I add new strings to the file.
                                      Spanish Language v2.0.4
                                      fur_lang_esv2.0.4.txt
                                      • H Offline
                                        hebeijianke
                                        Chinese translation new
                                        fur_lang_cn.txt
                                        • olisheaO Offline
                                          olishea
                                          thanks for the update. great plugin πŸ‘
                                          oli
                                          • erikBE Offline
                                            erikB
                                            thanks for the update, great plugin I use it regularly.
                                            erikB
                                            • 23
                                            • 24
                                            • 25
                                            • 26
                                            • 27
                                            • 32
                                            • 33
                                            • 25 / 33
