    [Plugin] Make Fur v.2.1.0(20140323)
    650 Posts 255 Posters 1.1m Views 254 Watching
      DavorP
      @latetzki said:
      What can I do to make this more precise so it wont place anything outside the selected face??
      You could use offset tool to make the area smaller. If the component is proprely centered on origin then measure the horizontal distance from origin to the farthest point of component geometry. Use that value to offset the boundary. If you have surface use offset on surface tool.
        tak2hata
        Hi,Davor.
        I guess that problem....
        Fur brade may up to Z aixis in the component.
        so I think your component is filpped for Z axis.
        or Your selected face for making fur is flipped.
        The Selected Face must directed to upward for you want.
        or The value of Force(Z) is too strong.
        Is your case there?
        Hi,Latetzki.
        I think like as Davor's,too.
        Fur is created on the points of selected face.
        But,The blade of fur has width.
        offset the face if you want more precise inside.
        Thanks.
        by TAK2HATA
          tak2hata
          Hi,All.
          I update to version2.0.1 in 2013.06.02.
          UI is improved.
          Hi,zieios.
          The icon is pretty cool! 😍
          Fur will be grown thick on sketchup!
          Thanks.
          by TAK2HATA
            Anton_S
            Amazing plugin!!!
            I just got a hair cut, and didn't know how to fullfill my hair.
            But, now I found a way
            Thank you 😎
              pepa
              Thanks for update, there is a czech translation.
              fur_lang_cz.txt
              http://jsvizualizace.daportfolio.com/
                tak2hata
                Hi,All.
                Now I place the new language files in language folder.
                fur_lang_farsi.txt:Persian translation by Majid.Thanks!
                fur_lang_cz.txt:Czech translation by Pepa.Thanks!
                Hi,Anton!
                Nice hair!
                I wish if I had hair like him.
                It will need too much hair spray.
                by TAK2HATA
                • majidM Offline
                  majid
                  Thank you for update and new interface 😍 πŸ‘
                    macmac12
                    thanks for the update πŸ˜„
                    • OxerO Offline
                      Oxer
                      Thanks for the update, I have done a new translation for Spanish Language, I add new strings to the file.
                      Spanish Language v2.0.4
                      fur_lang_esv2.0.4.txt
                      • H Offline
                        hebeijianke
                        Chinese translation new
                        fur_lang_cn.txt
                        • olisheaO Offline
                          olishea
                          thanks for the update. great plugin πŸ‘
                          oli
                          • erikBE Offline
                            erikB
                            thanks for the update, great plugin I use it regularly.
                            erikB
                              tak2hata
                              Thanks Hebeijianke and Oxer for uploading the translation files.
                              Now I'm busy ,so I will update plugin including these translation files in the end of this week.
                              Thank you very much!
                              by TAK2HATA
                                tak2hata
                                Hi,All.
                                I update to v2.0.5.
                                Include new language file for Spanish and Chinese.
                                Thanks Oxer and Hebeijianke!
                                Enjoy!
                                by TAK2HATA
                                  meoa
                                  Preview shows fur on the selected face but after clicking make fur, quite a number of it go off the selected face. The ones on the face are also scattered unevenly unlike the preview.
                                  Is this what should happen or am i doing something wrong ?
                                  Ok, sketchup just crashed. I tried it again and it seems to be fine now. Fur stays on the faces. I stil don't know what happened before and the cause.
                                    tak2hata
                                    Hi,meoa.
                                    I need more information for your problem.
                                    I can not know what happened, too.
                                    Please upload your model and the picture of the fur setting and selected face.
                                    Thanks.
                                    by TAK2HATA
                                      meoa
                                      @tak2hata said:
                                      Hi,meoa.
                                      Thanks.
                                      Sorry tak2hata, it was my mistake.
                                      I deleted geometry in a component and for some reason it did not rescale or i may have moved the axes by mistake so the component size was far larger than the content(space when you edit the component). Thus, the make fur moved the components further away than the size of the content which explains why they were off the face.
                                      make fur on the rectangle's surface using the component beside it
                                        tak2hata
                                        @meoa said:
                                        @tak2hata said:
                                        Hi,meoa.
                                        Thanks.
                                        Hi,meoa.
                                        This problem is solved by yourself.
                                        by TAK2HATA
                                          menes
                                          Hello there,
                                          First thanks tak2hata for the wonderful plugin.
                                          I'm trying long time now to use this for create a nice Olive tree.
                                          While the plugin work perfectly for create the single element.
                                          I can not in any way create the proper effect randomizing the element using the "leaf" mode.
                                          any suggestion?
                                          thanks
                                          • srxS Offline
                                            srx
                                            Wonderful plugin. Here is Serbian translation. Just to feel the excitement of taking part in an international project πŸ˜„ .
                                            fur_lang_srb.txt
                                            www.saurus.rs
                                            • 23
                                            • 24
                                            • 25
                                            • 26
                                            • 27
                                            • 32
                                            • 33
                                            • 25 / 33
