    [Plugin] Make Fur v.2.1.0(20140323)
    650 Posts 255 Posters 1.3m Views 254 Watching
    • T
      tak2hata
      @slapfoot said:
      "The real problem is, the grass generation is not evenly distributed (sometimes). There is more grass on some areas (looks like big triangles). It does this with the green dots, and also when making the fur."
      Any solution to this issue yet? I'm experiencing the same problem (using SK8 if that helps). Even when generating fur on a simple rectangular face - the fur distributes unevenly into these weird triangles. So i'll be left with fur concentrated triangles and then more sparse regions. Any help would be most appreciated!
      • slapfoot
      Hi,slapfoot.
      The generating method was not improved.
      Please set the large value to "MaxNumber(/Face) :".
      But too many furs will make the model file size too large.
      Please notice about this.
      by TAK2HATA
      • C
        cricrichan1984
        Thank you!! πŸ˜„
        That a sweet plugin
          jujepoy
          where to download?
            @jujepoy said:
            where to download?
            In the first post on the first page of this thread.
            • C
              cucumuda
              how to i get the plugin?
              can u tell me how to download the plugin.... πŸ˜„
              the plugin very nice....
                Click on this link πŸ˜‰
                it's the same than the current version that you can find on the first post of this thread!
                Download it Unzip and put it on the Plugins folder!
                  jujepoy
                  pls help me where to download this plug.in
                  • massimoM
                    massimo Moderator
                    Go to the very first post of the thread and scroll down a bit the page. Is there.
                      ATBP
                      Very nice.
                      • L
                        Latetzki
                        What can I do to make this more precise so it wont place anything outside the selected face??
                          DavorP
                          Plugin is great but I have a problem. I use previously modeled component as fur instance. What happens is that each component that fur drops is inverted. How can I make sure this does not happen?
                            DavorP
                            You could use offset tool to make the area smaller. If the component is proprely centered on origin then measure the horizontal distance from origin to the farthest point of component geometry. Use that value to offset the boundary. If you have surface use offset on surface tool.
                            • T
                              tak2hata
                              Hi,Davor.
                              I guess that problem....
                              Fur brade may up to Z aixis in the component.
                              so I think your component is filpped for Z axis.
                              or Your selected face for making fur is flipped.
                              The Selected Face must directed to upward for you want.
                              or The value of Force(Z) is too strong.
                              Is your case there?
                              Hi,Latetzki.
                              I think like as Davor's,too.
                              Fur is created on the points of selected face.
                              But,The blade of fur has width.
                              offset the face if you want more precise inside.
                              Thanks.
                              by TAK2HATA
                              • T
                                tak2hata
                                Hi,All.
                                I update to version2.0.1 in 2013.06.02.
                                UI is improved.
                                Hi,zieios.
                                The icon is pretty cool! 😍
                                Fur will be grown thick on sketchup!
                                Thanks.
                                by TAK2HATA
                                  Anton_S
                                  Amazing plugin!!!
                                  I just got a hair cut, and didn't know how to fullfill my hair.
                                  But, now I found a way
                                  Thank you 😎
                                  • P
                                    pepa
                                    Thanks for update, there is a czech translation.
                                    fur_lang_cz.txt
                                    http://jsvizualizace.daportfolio.com/
                                    • T
                                      tak2hata
                                      Hi,All.
                                      Now I place the new language files in language folder.
                                      fur_lang_farsi.txt:Persian translation by Majid.Thanks!
                                      fur_lang_cz.txt:Czech translation by Pepa.Thanks!
                                      Hi,Anton!
                                      Nice hair!
                                      I wish if I had hair like him.
                                      It will need too much hair spray.
                                      by TAK2HATA
                                      • majidM
                                        majid
                                        Thank you for update and new interface 😍 πŸ‘
                                          macmac12
                                          thanks for the update πŸ˜„
                                          • OxerO
                                            Oxer
                                            Thanks for the update, I have done a new translation for Spanish Language, I add new strings to the file.
                                            Spanish Language v2.0.4
                                            fur_lang_esv2.0.4.txt
                                            • 23
                                            • 24
                                            • 25
                                            • 26
                                            • 27
                                            • 32
                                            • 33
                                            • 25 / 33
