    [Plugin] Material Replacer
    73 Posts 39 Posters 81.1k Views 39 Watching
    • JQLJ Offline
      JQL
      Rombout,
      You can change materials while keeping the same UV with Fredo Tool's Thrupaint. There's an Icon with a multicolor brush there that does that. That doesn't do it automatically, but you can paint without being inside the group wich is handy.
      www.casca.pt
      Visit us on facebook!
        ronhiatt
        TT:
        Wow! Thanks very much. Great tool that does what it names says. Rare these days.
        Ron
        • asimonasA Offline
          asimonas
          Thank you!
            JDZYN
            ]I think it would be great to be able to consolidate materials by selecting in the material palette. I've seen the script that isolates objects by material (material selector), but it doesn't seem to work in my model. Besides, I'm trying to take a hundred-ish materials and reduce them to a more manageable figure.
            I've run your material consolidator, but the materials aren't exactly the same.
            As you can see... if I could select a couple dozen similar grays and tell them to be one... life would be much better.
            • asimonasA Offline
              asimonas
              I'm using this plug in a lot. Changing materials all the time in my work. It would be good to have an option to change materials in a group or component only and not in all model. Would that be difficult to integrate?
              thanks!
              • H Offline
                huybinhktr
                Can you continue to improve this version for su2019?
                  It should work in v2019.
                  Are you having issues ?
                  If so, then what are they ??
                  Note: because it hasn't been updated for many years it is not 'signed' for full compatibility with all Extension Loading Policies in the newer SketchUp versions - BUT this doesn't matter provided that you have your newer SketchUp's Extension Manager's Loading Policy set to 'Unrestricted'...
                    dtrarch
                    I use a very old plugin Material_Maintenance that still works up to SU 2018 Pro.
                    Really super for material replace and edit.
                    Author Akira Yamada and not to be found anywhere.
                    His web listed as http://www.KeepingMyHandIn.com but a dead end.
                    It is free to edit and distribute
                    I have folder in the SU plugins and the Material_Maintenance.rb copied to same.
                    Works for me and check it out and see if it can be configured properly as an rbz
                    Help from the Masters needed.
                    dtrarch
                    Material_Maintenance.zip
                    • pbacotP Offline
                      It's nice this works in the model. It would be nice too if one could do the material replacement in the browser.
                      Another nice thing is how the material replacer can give you the name of a material immediately. This is a slow, painful process on the Mac. Why?
                      • I Offline
                        irinapopescu
                        Hei there! This pluigin was one of the best things to use last year for me, but since I upgradated to sketchup 2023 I ca't seem to install it. It shows "unsigned". Can anyone help?
                          @irinapopescu said:
                          ... but since I upgradated to sketchup 2023 I ca't seem to install it. It shows "unsigned".
                          Unsigned doesn't mean it won't install. You just have to make sure you have set loading policy in Extension Manager to allow unsigned extensions to load.
                          Please update your forum profile. It is way out of date.
                            mtanure1234
                            I need to paint only those face with default material inside a model of a window I've created. But if I a replace with the Replace Material plugin it will change all the file default faces.
                            Any tips? Thank you.
                            N 1 Reply Last reply Reply Quote 0
                            • N Offline
                              nlipovac @mtanure1234
                              @mtanure1234, just use the 'B' button on the UI, which will color only the backside face. Then, use the 'All adjacent faces with the same material' button to map material to all of them in that object.
                              • 4 / 4
