    [Plugin] Material Replacer
    79 Posts 42 Posters 94.6k Views 42 Watching
    • asimonasA
      asimonas
      I'm using this plug in a lot. Changing materials all the time in my work. It would be good to have an option to change materials in a group or component only and not in all model. Would that be difficult to integrate?
      thanks!
      • H
        huybinhktr
        Can you continue to improve this version for su2019?
          It should work in v2019.
          Are you having issues ?
          If so, then what are they ??
          Note: because it hasn't been updated for many years it is not 'signed' for full compatibility with all Extension Loading Policies in the newer SketchUp versions - BUT this doesn't matter provided that you have your newer SketchUp's Extension Manager's Loading Policy set to 'Unrestricted'...
            dtrarch
            I use a very old plugin Material_Maintenance that still works up to SU 2018 Pro.
            Really super for material replace and edit.
            Author Akira Yamada and not to be found anywhere.
            His web listed as http://www.KeepingMyHandIn.com but a dead end.
            It is free to edit and distribute
            I have folder in the SU plugins and the Material_Maintenance.rb copied to same.
            Works for me and check it out and see if it can be configured properly as an rbz
            Help from the Masters needed.
            dtrarch
            Material_Maintenance.zip
            • pbacotP
              It's nice this works in the model. It would be nice too if one could do the material replacement in the browser.
              Another nice thing is how the material replacer can give you the name of a material immediately. This is a slow, painful process on the Mac. Why?
              • I
                irinapopescu
                Hei there! This pluigin was one of the best things to use last year for me, but since I upgradated to sketchup 2023 I ca't seem to install it. It shows "unsigned". Can anyone help?
                  @irinapopescu said:
                  ... but since I upgradated to sketchup 2023 I ca't seem to install it. It shows "unsigned".
                  Unsigned doesn't mean it won't install. You just have to make sure you have set loading policy in Extension Manager to allow unsigned extensions to load.
                  Please update your forum profile. It is way out of date.
                    mtanure1234
                    I need to paint only those face with default material inside a model of a window I've created. But if I a replace with the Replace Material plugin it will change all the file default faces.
                    Any tips? Thank you.
                    N 1 Reply Last reply
                    • N
                      nlipovac @mtanure1234
                      @mtanure1234, just use the 'B' button on the UI, which will color only the backside face. Then, use the 'All adjacent faces with the same material' button to map material to all of them in that object.
                      • L
                        LayaCZ
                        Hello,
                        "Material Replacer 1.3.0" from sketchucation.com is actually installed as "SubD"
                        Best regards R.
                        • L
                          LayaCZ
                          'tt_mat_replace_v1.3.0' is actually installed as 'SubD'
                            @LayaCZ
                            I have tested the RBZ and it is definitely installing SubD in error, although the RBZ is properly named ?? Perhaps @thomthom or @rich-o-brien or @Gábor can shed some light on this weirdness
                              @layacz I've contacted Thom to get it sorted
                              • N
                                nay_bernilla
                                me sale como si fuera otro plugin
                                  I have found a good version of the RBZ which installs v1.3.0 of the tool properly. It's now in the PluginStore / ExtensionStore³...
                                  Just tested it and it works fine...
                                  • 4 / 4
