    How to use Ruby API
    28 Posts 5 Posters 2.8k Views 5 Watching
    • honoluludesktopH Offline
      honoluludesktop
      OK, now I can locate components, their name, and groups. How do I use the API to get information of the faces within a component, or group?
      module WMY_putdxf
       def WMY_putdxf.main #main proc
         model = Sketchup.active_model # make db of active model
         entities = model.active_entities
         selection = model.selection # make db of selections
         if model.selection.empty?
         else
            entities = model.selection
         end #endif
         entities.each do |e| # do loop through database and
                              # place entities in type array
           if e.is_a? Sketchup;;ComponentInstance
                stuff= e.definition.name
                WMY_putdxf.get_faces(stuff) #call procedure/function
           end #endif
         end #end loop
      And:
          def WMY_putdxf.get_faces (stuff)# procedure or method
              # UI.messagebox(stuff)# used this to test
              # if component instance is selected
              # How do I use API to get component's face info
      Btw, please advise if I have redundant coding:-), or if my qusetions don't make sense.
        group.entities
        component_instance.definition.entities
        That will give you a collection of the entities they contain - like model.entities.
          honoluludesktop
          OK, so now all I have to do is search the new collection for faces? Lets see if I can figure that out:-)
            This makes a 'list' called faces of all of the faces inside the group...
            faces=[]
            ### *** note how the list must be defined outside of the {...} block
            group.entities.each{|e|faces<<e if e.class==Sketchup;;Face}
            This approach can be adjusted to suit any type of 'entities' list and any type of 'class' of thing you want to extract from it - faces, edges, cpoints, clines, text...
            Then of course you can loop through you faces for say a particular material (or any other property)...
            red_faces=[] ### ***
            faces.each{|f|red_faces<<f if f.material.name=="Red"}
            red_faces now contains all of the group's faces that are "Red" etc etc...
            PS: Note that the .entities method returns all of the entities associated with the specified object - i.e. model/group/definition... There is another list of entities: model.active_entities that applies to the current set of entities available in the present edit session - this could equivalent ot the model.entities or if you are editing a group or component-definition the available entities within that - e.g. group.entities...
              honoluludesktop
              OK, I put:
                     name=e.definition.name#e.typename
                     faces=e.definition.entities
                     WMY_putdxf.get_faces(name,faces)
              And:
              def WMY_putdxf.get_faces(name,faces)# procedure or method
                 faces.each do |e|
                   info = e.typename
                   if e.is_a? Sketchup;;Face
                     UI.messagebox(name+"; "+info)
                   end #endif
                 end #end do
              end #end method
              So, you declare a array=[], but a collection (something like an array) makes itself?
              OK, how do I make a collection of the geometric imformation inside each face so that I can access it later? Wild guess to start below:
                 faces.each do |e| #why do we use e; can I use f?
                   info = e.typename
                      facegeo=e.something #get face geo collection goes here?
                   end #endif
                 end #end do
              end #end method
                @honoluludesktop said:
                OK, I put:
                I USE CAPITALS FOR EASE OF READING ONLY !!!
                >        name=e.definition.name#e.typename### NAME IS THE 'NAME' - LIKE 'BED' TYPENAME IS THE CLASS/KIND_OF ETC
                >        faces=e.definition.entities### THERE WILL BE MORE THAN FACES IN ENTITIES - AT LEAST EDGES TO FORM THE FACES
                >        WMY_putdxf.get_faces(name,faces)### IF YOU WANT TO PASS THE DEFINITION THEN PASS E.DEFINITION NOT ITS 'NAME'
                >        ### REMEMBER THAT 'FACES' IS 'ENTITIES' THAT WILL INCLUDE FACES BUT NOT JUST FACES ALONE...
                >    end
                And:
                > ### START DEF WITH lowercase LETTERS !!! wmy_putdxf etc
                > ### THIS GETS YOU NOTHING EXCEPT A MESSAGE LISTING THE DEF'S NAME AND EACH FACE IN TURN...
                >    faces.each do |e|
                >      info = e.typename
                >      end #endif
                >    end #end do
                > end #end method
                AN ARRAY FACES=[] IS A LIST
                  ### REMEMBER THE lowercase LETTERS TA THE START
                >    faces.each do |e| #why do we use e; can I use f? ### CAN USE ANY VARIBALE 'E' IS OFTEN USED FOR 'EntitY'
                >      info = e.typename
                >      end #endif
                >    end #end do
                > end #end method
                HERE IS MY GET FACE VERSION...
                if object.class==Sketchup;;ComponentInstance
                  faces=[]
                  object.definition.entities.each{|entity|
                    faces<< entity if entity.class==Sketchup;;Face
                  ### now do stuff to these faces...
                end#if
                Done with sub-defs or anything... Tests if the object is an Instance and if so make an Array [list] of its Definition's Entities' Faces to process...
                  honoluludesktop
                  Thanks guys. Will work on this later tonight after I get home. About the lowercase, if the def is inside a module, will it make a difference?
                  This runs ok on my system:
                  require 'sketchup.rb'
                  module WMY_putdxf
                    def WMY_putdxf.main
                     else
                   	# test if selection made
                      entities.each do |e| # do loop through database and place entities in type array
                  			#comp_file_name=e.definition.name
                    end # .main method
                  	faces.each do |e|
                  	   info = e.typename
                  	   end #ednif
                  	end #end do
                  end # WMY_putdxf module
                  #----------------menu------------------
                  if !file_loaded?(__FILE__) #_FILE_  permits renaming the file
                    UI.menu("Plugins").add_item("Yet Another Test") { WMY_putdxf.main }
                  file_loaded(__FILE__)
                  But with WMY_ as wmy_ this error message:
                  Error Loading File yet_another_script.rb
                  C:/PROGRA~1/Google/GO2494~1/Plugins/yet_another_script.rb:3: class/module name must be CONSTANT
                  Sorry for the uneven indenting, when I copy from notepad++ and paste, the indent spacing changes.
                  • Chris FullmerC Offline
                    module names always must start with a capital letter. methods do not start with a cap. Classes start with a cap. That is the basic rule. Constants are variables that start with a capital letter, and should remain constant - like Pi.
                    Chris
                    All my Plugins I've written
                      Chris
                      Normal convention is to type constants in all caps.
                        Sorry for the confusion 😳 - I didn't realise there was an enclosing module / class. They need initial CAPITAL letter; whereas defs and variables need lowercase. Consonants ion caps e.g. ORIGIN...
                          honoluludesktop
                          OK I am stuck again. Problem is with the last box of code below:
                          This is the main proc, methods below are at the bottom of the code in this section:
                          else
                              the_name=e.definition.name
                              stuff=e.definition.entities
                              counter=0
                              faces=[]
                              stuff.each do |e|
                                  counter=counter+1
                                  faces.push e
                                end ###if
                              end ###loop
                              points=[]
                              add_face_vert_to_file(faces,points)
                              make_comp_face_file(the_name,faces,counter,model,points)
                            end ###if
                          end ###loop
                          Method to make a collection of face.vertices
                          ###make vertices file of faces in component
                          def add_face_vert_to_file(faces,points)
                            faces.each do |e|
                              points.push e.vertices
                            end ###end loop
                          Method to make empty text file, then (where I fail) to take the face.vertices and copy them as string to the text file.
                          ###create file ComponentName.txt
                          def make_comp_face_file(the_name,faces,counter,model,points)
                            the_line=the_name+" ",counter," faces"
                            UI.messagebox(the_line)
                            model_filename = File.basename(model.path)
                            path=File.dirname(model.path)+"\\"
                            out_name=the_name+".txt"
                            out_path=path+out_name
                            $mesh_file=File.new(out_path,"w")
                            #HERE is problem code. How do I take the collection
                            #of face.vertices and copy as strings to the text file.
                            points.each do |e|
                              $mesh_file.puts(e.x.to_s)
                              $mesh_file.puts(e.y.to_s)
                              $mesh_file.puts(e.z.to_s)
                            end ###loop
                          Am writing with the Web Console, and having some problems. Saving seems to drop characters, and the indents are gone. Any ideas?
                            points.each do |e|
                            end ###loop
                            Adds x/y/z into file on separate lines...
                            to test if it's at least getting the points values use plain puts so it appears in the console
                            points.each do |e|
                                puts(e.x.to_s)
                                puts(e.y.to_s)
                                puts(e.z.to_s)
                            end ###loop
                            To write an xyz line use
                            points.each do |e|
                                $mesh_file.puts(e.x.to_s+","+e.y.to_s+","+e.z.to_s)
                            end ###loop
                            Does
                            actually make the file ?
                            You need to open the file for writing AND then close it after you are done writing to it.
                            $mesh_file.close
                            perhaps it's still open and so a second [separate] attempt to write to it fails...
                              Oh yeah! I rarely intialize them. Thanks Thom,
                              Chris
                                honoluludesktop
                                TIG, Just got up, and finished reading at your post. Thanks I think I understand, and have a lot to work with.
                                Made a 0 byte file that I can see in "My Computer". I assumed it was open, guess it wasn't:-). Looks like a lot of stuff to work on later today. Good advice about using "puts" to check output. I use the messagebox a lot but that is slow.
                                puts(e.x.to_s) prints Sketchup::Vertex:0xea24668 ?-(, Crossed this bridge once before, but don't recall how to get output as a number.
                                  puts(e.x.to_s) should return a numerical "x" position if e is a Point3d object. if e is a vertex, it should return an error. If e is a vertex, you can do e.position.x and that will return the x position of the vertex.
                                  That sounded confusing to me. A few more lines of your code and I could give a slightly more complete example.
                                  Great job so far!
                                  Chris
                                    honoluludesktop
                                    "oops: - I" πŸ™‚ A little slow this morning, didn't get it until now. Thanks guys, lets see how far I can get with what I have before I, OOPS:-(, need help getting off the floor. Might not take too long.
                                    Tig, I can now open, write to, and close files:-)
                                    Chris above here is where I stumbled on the code.
                                    It occurred to me that a "method", a "function" in other languages (I missed this one), was in my day know as a "procedure", having evolved from a "[C}all". Before this I did a Basic "sub routine", itself born out of "jump xxxx:xxxx, where xxxx:xxxx began a set of instruction that ended in "return". Before "Buddha" it was all 1111's and 0000's πŸ™‚
                                      honoluludesktop
                                      Help! How do I get a number that repersents the location of a face vertices? The following is setup for Web Console. When I output to UI.messagebox(e.vertices), I get:
                                      #Sketchup::Vertex:0xfc83800#Sketchup::Vertex:0xfc837e8#Sketchup::Vertex:0xfc837d0
                                      The main proc is at the bottom, and the methods are above it.
                                      ### Test is selection made
                                      else
                                      def make_comp_face_file(the_name,faces,counter,model)
                                      ###make vertices collection of faces in component
                                      def add_face_vertices_collect(faces,points)
                                        faces.each do |e|
                                          points.push e.outer_loop
                                        end ### loop
                                      ###make 3dpoint from vertex HELP HERE!!!! I think
                                      def print_vertices_collect(points)
                                        points.each do |e|
                                          UI.messagebox(e.vertices)       ###puts to test will be
                                          ###$points_file.puts(e.vertices)###put here when works
                                      ###Get su;;component collection
                                          faces=[]
                                          counter=0
                                          ###Locate faces in each component and make faces collection
                                          stuff.each do |e|
                                      	  counter=counter+1
                                      	  faces.push e
                                      	end ###if
                                          end ###loop
                                          make_comp_face_file(the_name,faces,counter,model)####Have to
                                          points=[]
                                          add_face_vertices_collect(faces,points)          ####nest these
                                          print_vertices_collect(points)                   ####later
                                          $points_file.close
                                        end ###if
                                      end ###loop
                                        Jim
                                        The Vertex entity has a position.
                                        point = vertex.position
                                        The position will be relative to parent container, and not relative the SketchUp axes.
                                          ### points>>>vertices
                                          vertices.each do |vertex|
                                            $points_file.puts(vertex.vertices.point.to_a)
                                            ### FILE of VERTICES POINTS AS AN ARRAY ONE PER LINE...
                                            honoluludesktop
                                            Hi guys, Thanks for your help. I stumbled on e.vertices.x.position after starting over. Now how do I read the SU Ruby API to make this easier to understand?-(
                                            entities = model.entities
                                            else
                                            		ci_name=e.definition.name
                                            		#UI.messagebox(ci_name)
                                            		ci_collection=e.definition.entities
                                            		#UI.messagebox(ci_collection)
                                            		ci_collection.each do |e|
                                            			ci_faces_collection=[]
                                            				ci_faces_collection.push e
                                            				ci_faces_collection.each do |e|
                                            					faces_vertices_collection=[]
                                            					if e.vertices
                                            						faces_vertices_collection.push e
                                            						puts(e.vertices.x.position)
                                            • 1 / 2
