    [Plugin][$] RoundCorner - v3.4a - 31 Mar 24
    1.5k Posts 476 Posters 3.9m Views 476 Watching
      letuanFilip Newcomers
      Tool is very useful πŸ‘ , i like it but purchasing is a problem, i purchased for fredo roundcorner and i got fredo scale, which is not even in purchasing menu. πŸ‘Ž πŸ‘Ž
      • fredo6F Offline
        fredo6
        Apparently you purchased licenses for both RoundCorner (today 14h13) and FredoScale (today 15h53).
        Maybe the 2 license emails are in the same master email...
          I sorted it out. He bought wrong license and ended up in a muddle
          • G Offline
            GraceMien Newcomers
            I've run into a bit of an error (probably on my part).
            I've got two pentagons stacked on top of each other to make a makeshift pyramid and I went to round all the edges except for the bottom edges with an offset of .5" with 5 segments. For some reason, all the projected edges are equal except for the sides of the bottom half. They appear to shrink in size in that particular spot.
            The edges are all connected correctly making up one shape, yet this issue is occurring. Does anyone know what might be happening?
            Thank you!
            Additional info:
            Computer OS: Windows 11
            SketchUp version: 23.0.419
            Round Corner version: 3.3a - 18 Dec 18
            Link to file:
            https://drive.google.com/file/d/1R0vkeJtWug0lc09JairvZRK94XGUCvQ4/view?usp=sharing
            Screenshot of the error previously described.
              Did you try setting Offset to Strict?
              https://i.imgur.com/JmyrbFc.png
              • G Offline
                GraceMien Newcomers
                Well it looks like I got some better results! I gave that a try, and everything looks a fair bit more equal now.
                It's not perfect however. The points between the two sides on the top and the bottom are slightly off.
                But I suppose in the grand scheme of things it doesn't matter that much. I still wonder what might be causing the inaccuracy though.
                Thank you for the tip!
                  The angles between the faces are different so the lengths of the curves would be different. You can see that more easily when the angles between are more different.
                  I expect you would have an easier time modeling this thing if you do so with the thing at a larger size.
                  • G Offline
                    GraceMien Newcomers
                    I'm afraid I don't fully understand which lines you are referring to that have different angles. Are you talking about the yellow lines, green lines, or blue lines?
                      I'm referring to the angle between the triangular faces above the "belt" and the angle between the trapezoidal faces below the belt. They are different so the arc lengths will be different. I tried to simplify the illustration but making a 3D thing instead of a 3D object.
                      • G Offline
                        GraceMien Newcomers
                        Ohhh gotcha. Yeah unfortunately there isn't much I can do about that since I can't change the angles of anything since it's based on a design someone else made. I'll just have to live with it.
                        Thank you for your time!
                          Yep. You'll have to blame Euclid or one of those other old dead guys who invented Geometry. πŸ˜›
                          • leedeeteeL Offline
                            leedeetee
                            Morning, just a quick question ..
                            I purchased JPP only yesterday, but realised I should have bought the bundle - great value!
                            Is there any way of paying the difference so I can get the bundle rather than paying $12 + $40.
                            I understand this is my fault but just thought it was worth the question.
                            Many thanks. πŸ™‚
                              Rich O Brien Moderator @leedeetee
                              @leedeetee it is easier for us to refund and then you buy what you need.
                              just send us an email support@sketchucation.com
                              leedeeteeL 1 Reply Last reply Reply Quote 0
                                leedeetee @Rich O Brien
                                @Rich-O-Brien said in [Plugin][$] RoundCorner - v3.3a - 18 Dec 18:
                                Thanks Rich, will do that now. Thanks very much.
                                Lee
                                • fredo6F Offline
                                  fredo6
                                  NEW RELEASE: RoundCorner v3.4a - 31 Mar 24
                                  Requirement: LibFredo6 v14.3b or above
                                  RoundCorner 3.4a is a maintenance release for future compatibility
                                  Home Page of RoundCorner for information and Download.
                                  Main post of this thread.
                                  R K 2 Replies Last reply Reply Quote 0
                                    raptorscream @fredo6
                                    @fredo6
                                    Hello,
                                    I'm using the free license of RoundCorner and I have an issue I dont understand how to fix.
                                    When I select the inside edges of this object, it just bridges/fills the entire hole even if I try just to round a single edge that's inside the "hole". Why is that?
                                    4ecc6f19-506a-41c8-9dd7-a1e5a50c06b8-image.png 21b2818b-b7b6-4710-9ac3-5054b1229739-image.png
                                    massimoM 1 Reply Last reply Reply Quote 0
                                    • massimoM Offline
                                      massimo Moderator @raptorscream
                                      @raptorscream Hi, this is a normal behaviour for RoundCorner in some circumstances. For example when you bevel coplanar edges that are a closed loop or part of it. I guess because the plugin somehow "erases" and then "draws" again some lines in the process. This causes Sketchup to automatically generate a face.
                                      Just select and delete the unwanted surface.
                                      • I Offline
                                        ianpemb496
                                        Hi I have and am able to use fredo round corner in ketchup pro2023 however I just upgraded to SketchUp pro 2024 and I am now getting a licence issue. How do I transfer the licence
                                          Rich O Brien Moderator @ianpemb496
                                          @ianpemb496 said in [Plugin][$] RoundCorner - v3.4a - 31 Mar 24:
                                          You can release seats by following the guide:
                                          https://downloads.sketchucation.com/licensing/SCFLicense-Instructions_to_Users.pdf
                                          Or at https://sketchucation.com/webshop/my-licences.php if you kept Sketchucation Tools and Libfredo updated
                                            dalebailey
                                            I recently upgraded to lib fredo 15.1 as requested, and skucation tools 4.4.1 and now my Fredo Round Corner 3.4a doesn't work. Like most of my licensed fredo plugins we randomly lose them because we don't know when the " occasional checks" occur for the licensing. The computer we use is an offline cpu. Anyway when we ping every month for updates we usually have to re-activate all the plugins. This time when we did all the plugins activated properly but round corner. It says "sorry - an error occurred in the communication with sketchucation." and wont license. it says i must be connected to the internet, even though i am. All the others worked properly. This is a new development.
                                            • 71
                                            • 72
                                            • 73
                                            • 74
                                            • 75
                                            • 73 / 75
