    1.5k Posts 477 Posters 4.1m Views 477 Watching
    • G
      GraceMien Newcomers
      @dave r said:
      I'm referring to the angle between the triangular faces above the "belt" and the angle between the trapezoidal faces below the belt. They are different so the arc lengths will be different. I tried to simplify the illustration but making a 3D thing instead of a 3D object.
      Ohhh gotcha. Yeah unfortunately there isn't much I can do about that since I can't change the angles of anything since it's based on a design someone else made. I'll just have to live with it.
      Thank you for your time!
        Yep. You'll have to blame Euclid or one of those other old dead guys who invented Geometry. πŸ˜›
        • leedeeteeL
          leedeetee
          Morning, just a quick question ..
          I purchased JPP only yesterday, but realised I should have bought the bundle - great value!
          Is there any way of paying the difference so I can get the bundle rather than paying $12 + $40.
          I understand this is my fault but just thought it was worth the question.
          Many thanks. πŸ™‚
            Rich O Brien Moderator @leedeetee
            @leedeetee it is easier for us to refund and then you buy what you need.
            just send us an email support@sketchucation.com
            leedeeteeL 1 Reply Last reply
            • leedeeteeL
              leedeetee @Rich O Brien
              @Rich-O-Brien said in [Plugin][$] RoundCorner - v3.3a - 18 Dec 18:
              Thanks Rich, will do that now. Thanks very much.
              Lee
              • fredo6F
                NEW RELEASE: RoundCorner v3.4a - 31 Mar 24
                Requirement: LibFredo6 v14.3b or above
                RoundCorner 3.4a is a maintenance release for future compatibility
                Home Page of RoundCorner for information and Download.
                Main post of this thread.
                R K 2 Replies Last reply
                  raptorscream @fredo6
                  @fredo6
                  Hello,
                  I'm using the free license of RoundCorner and I have an issue I dont understand how to fix.
                  When I select the inside edges of this object, it just bridges/fills the entire hole even if I try just to round a single edge that's inside the "hole". Why is that?
                  4ecc6f19-506a-41c8-9dd7-a1e5a50c06b8-image.png 21b2818b-b7b6-4710-9ac3-5054b1229739-image.png
                  massimoM 1 Reply Last reply
                  • massimoM
                    massimo Moderator @raptorscream
                    @raptorscream Hi, this is a normal behaviour for RoundCorner in some circumstances. For example when you bevel coplanar edges that are a closed loop or part of it. I guess because the plugin somehow "erases" and then "draws" again some lines in the process. This causes Sketchup to automatically generate a face.
                    Just select and delete the unwanted surface.
                    • I
                      ianpemb496
                      Hi I have and am able to use fredo round corner in ketchup pro2023 however I just upgraded to SketchUp pro 2024 and I am now getting a licence issue. How do I transfer the licence
                        Rich O Brien Moderator @ianpemb496
                        @ianpemb496 said in [Plugin][$] RoundCorner - v3.4a - 31 Mar 24:
                        You can release seats by following the guide:
                        https://downloads.sketchucation.com/licensing/SCFLicense-Instructions_to_Users.pdf
                        Or at https://sketchucation.com/webshop/my-licences.php if you kept Sketchucation Tools and Libfredo updated
                          dalebailey
                          I recently upgraded to lib fredo 15.1 as requested, and skucation tools 4.4.1 and now my Fredo Round Corner 3.4a doesn't work. Like most of my licensed fredo plugins we randomly lose them because we don't know when the " occasional checks" occur for the licensing. The computer we use is an offline cpu. Anyway when we ping every month for updates we usually have to re-activate all the plugins. This time when we did all the plugins activated properly but round corner. It says "sorry - an error occurred in the communication with sketchucation." and wont license. it says i must be connected to the internet, even though i am. All the others worked properly. This is a new development.
                          • fredo6F
                            What is the exact error message?
                            • E
                              ediarbi
                              it very nice plugin
                              • I
                                isidrodaniel
                                I have the Perpetual licence (3 seats).
                                I had to reinstall sketchup and now I receive a message saying licence seats exceeded.
                                How can I fix this?
                                  Release seats at https://sketchucation.com/webshop/my-licences.php
                                  If seat releasing is unavailabe at https://sketchucation.com/webshop/my-licences.php please update Sketchucation Tools
                                  • B
                                    buzniak
                                    How do you get it to stop filling in your holes?
                                    Dave RD 1 Reply Last reply
                                      Dave R @buzniak
                                      @buzniak In many cases that's just the way Round Corner works. It's simple enough to delete the faces over the holes. FredoCorner, on the other hand doesn't seem to do that. I find it useful to have both extensions because one sometimes works better than the other depending on the situation.
                                      • K
                                        khanhafeez @fredo6
                                        @fredo6 i purchase round corner license there are some issue in skethcup 2025 when i use it to genrate skethcup shutdown automatically,
                                        one more issue is i have 3 license in that two i used in same pc as message appear that trial finish when is upload license key my prviouse license is wasted, do somthing for this issue we loosing money
                                          @khanhafeez
                                          Please release seats online or by following guide: https://downloads.sketchucation.com/licensing/SCFLicense-Instructions_to_Users.pdf
                                            MarkDuncan1966
                                            attempted to purchase using my only payment method i dont (AND WILL NOT USE PAYPAL) your system advises my VALID credit card cannot be used, please advise how i can make a purchase (and no i dont know anyone with paypal)
                                            • 71
                                            • 72
                                            • 73
                                            • 74
                                            • 75
                                            • 73 / 75
