    [Plugin][$] RoundCorner - v3.4a - 31 Mar 24
    1.5k Posts 470 Posters 3.3m Views 469 Watching
    • H Offline
      Headroom
      Fredo,
      I just downloaded Joint Push-Pull and Tools on Surface and both are very responsive (in OSX) and I don't experience the sluggishness I encounter when working with RoundCorner.
      BTW. What awesome tools you have created here. Until now my main workhorse has been Blender (http://www.blender.org). Now with Sketchup and these powerful plugins that you have created I have another powerful tool.
      Thanks!!!
      • I Offline
        inasia
        Hi Fredo,
        Good Evening and a huge thank you for the round edge plugin.....indeed it is a very useful excellent tool.
        Thank you again
        Have a good day.
        inasia
          Hi Fredo
          Have you seen this SketchUp blog post? http://sketchupdate.blogspot.com/2010/07/take-edge-off-roundcorners.html
          You've been featured - very nice article with lots of great action screenshots! 😄
          • fredo6F Offline
            fredo6
            @thomthom said:
            Hi Fredo
            Very good tutorial by Aidan.
            This proves that the users of scripts are the best to explain what a script can be used for!
            Fredo
              Jim
              It seems like some modules are still being defined even when the extension is disabled.
              RoundCorner, for example exists even if the plugin is disabled in the Extensions list.
              • fredo6F Offline
                fredo6
                Correct, but the module is almost empty. No code is loaded actually.
                Fredo
                  Jim
                  Fredo
                  I was looking for a method to tell me if the Toolbar was available. I tried
                  defined?(RoundCorner) which is defined even if the extension is disabled.
                    andretbms
                    Hello. Is it only me or the link that leads to the LibFredo6 3.3a post is broken? I can't get it opened here, forum gets an error.
                    Thank you 😃
                    André Thomé Barbosa
                    Architecture and Product Ilustrator.
                    Be sure to check my channel, plenty of SketchUp modelling videos and some tutorials.
                    http://www.youtube.com/andretbms
                      Daniel S
                      Thank you 😃
                      andretbms is right. If you go to the main post:
                      It says http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=17947#p144178
                      If you click in the link:
                      It should be changed for the correct link:
                      http://forums.sketchucation.com/viewtopic.php?f=180&t=17947#p144178
                      In hoverselect (http://forums.sketchucation.com/viewtopic.php?t=18916)
                      there is also the same problem:
                      I didn´t try with the other Fredo plugins... but perhaps the link problem is on every post.
                      Fredo or some moderator can change the links?
                      Since nobody mention this problem before... perhaps is because in the last SFC 5 minutes URL change(http://forums.sketchucation.com/viewtopic.php?f=323&t=29947), somebody break the automatic redirection?
                      Daniel S
                        Thanks guys, I have updated the link.
                        It would normally work this way as well because there's a wild card redirect only it's not working now because there's some maintenance going on in the main site. See Coen's post about those URL changes.
                        anyway, when you see such a broken link, just swap the www.sketchucation.com/forums/scf/ part of the link to forums.sketchucation.com/
                          Just for the record guys, the redirect has been fixed. Now both url's / links should point to the same post.
                          And thanks again for the alarm! 👍
                            Builder Boy
                            I noticed this plugin could not smooth this vertex.
                            However, I was able to bevel it manually without any problems.
                            Step 1
                            Step 2
                            Step 3 (the final result)
                            If you wanted to sharp the corner, you could do this:
                            And, if you wanted to round the corner, you could do this:
                            Please post an update.
                            Untitled2.skp
                            All my plugins
                            • F Offline
                              Fluxus63
                              Hi there,
                              need some help to install RoundCorner on Mac. Get only errors! Ruby Console is installed. THX
                              • jeff hammondJ Offline
                                jeff hammond
                                make sure you also download LibFredo6 from:
                                http://forums.sketchucation.com/viewtopic.php?f=323&t=17947#p144178
                                the installation looks like this:
                                **click picture for larger
                                dotdotdot
                                • K Offline
                                  kylebc86
                                  I am just wondering if anyone can help me. I have installed both lib fredo file and the round corner plugins as instructed, however when i launch sketchup, i get a warning message that says
                                  *"Cannot load plugin Round Corner because the script cannot create DEFPARAM_Dir folder in: Users/kylebc86/Library/Application Support/Google Sketchup 7/ Sketchup/ Plugins
                                  Please create it manually respecting the case"*
                                  Anybody have any idea what i need to do. Thanks in advance
                                  Kyle
                                  • fredo6F Offline
                                    fredo6
                                    @kylebc86 said:
                                    Kyle
                                    Kyle,
                                    Just as the message says, create a folder named DEFPARAM_Dir in the directory Users/kylebc86/Library/Application Support/Google Sketchup 7/ Sketchup/ Plugins
                                    The script cannot create it by itself, probably because of some security settings on your Mac.
                                    Fredo
                                    • K Offline
                                      kylebc86
                                      Brilliant, thanks Fredo, had a feeling it was something as simple as that.
                                      • O Offline
                                        OZX
                                        Salut,
                                        C'est très très lent sur ma machine. Une solution ?
                                        • JujuSKPJ Offline
                                          JujuSKP Extension Creator
                                          Dear All,
                                          I recently update to sketchup 8, get the last fredo lib (3.4c) and the last roundcorner plugin.
                                          I also change windows to mac os.
                                          I have tried roundcorner plugin on sketchup 7 on windows (work fine), sketchup 7 and 8 on Mac (just crash or really lagy).
                                          Any idea for this problem?
                                          I am using Mac os 10.6
                                          Thank for reply,
                                          • fredo6F Offline
                                            fredo6
                                            Dear All,
                                            Thank for reply,
                                            Juju,
                                            Can you be more explicit:
                                            • when is it slow: when you luanch it, when you select edges, when you generate the round geometry?
                                            • when does the crash on Mac happen?
                                            • is it slow for complex models or regradless?
                                            Fredo
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 73
                                            • 74
                                            • 14 / 74
