    1.5k Posts 477 Posters 4.2m Views 477 Watching
    • H
      Headroom
      Fredo,
      I get the sluggish behavior even with a simple cube. I see the buttons respond but have to be very slow with the mouse. I also see the Spinning Ball quite often.
      I came across a thread here a Sketchucation and it appears this may be a Sketchup 7.1 Mac only problem as several users have complained about the generally sluggish behavior of Sketchup 7. I tested Roundcorner with Sketchup 7.1 in VMware Fusion on my iMac on a Win Vista installation and it works fine.
      I hope Google fixes this Mac related Sketchup performance problem soon!
      I own a Indigo license (http://www.indigorenderer.com) and the SkIndigo exporter, another Sketchup plugin, works fine on my iMac.
      • Q
        qiqi
        may i know how and where to download the file?
        Tq
          1st post of this thread has the download and documentation
          • fredo6F
            Any other Mac users with this performance problem?
            Headroom (Peter): do you have the same problem with other plugins, like FredoScale or ToolsOnSurface?
            • H
              Headroom
              Fredo,
              I just downloaded Joint Push-Pull and Tools on Surface and both are very responsive (in OSX) and I don't experience the sluggishness I encounter when working with RoundCorner.
              BTW. What awesome tools you have created here. Until now my main workhorse has been Blender (http://www.blender.org). Now with Sketchup and these powerful plugins that you have created I have another powerful tool.
              Thanks!!!
              • I
                inasia
                Hi Fredo,
                Good Evening and a huge thank you for the round edge plugin.....indeed it is a very useful excellent tool.
                Thank you again
                Have a good day.
                inasia
                  Hi Fredo
                  Have you seen this SketchUp blog post? http://sketchupdate.blogspot.com/2010/07/take-edge-off-roundcorners.html
                  You've been featured - very nice article with lots of great action screenshots! πŸ˜„
                  • fredo6F
                    @thomthom said:
                    Hi Fredo
                    Very good tutorial by Aidan.
                    This proves that the users of scripts are the best to explain what a script can be used for!
                      Jim
                      It seems like some modules are still being defined even when the extension is disabled.
                      RoundCorner, for example exists even if the plugin is disabled in the Extensions list.
                      • fredo6F
                        Correct, but the module is almost empty. No code is loaded actually.
                          Jim
                          I was looking for a method to tell me if the Toolbar was available. I tried
                          defined?(RoundCorner) which is defined even if the extension is disabled.
                            andretbms
                            Hello. Is it only me or the link that leads to the LibFredo6 3.3a post is broken? I can't get it opened here, forum gets an error.
                            Thank you πŸ˜ƒ
                            AndrΓ© ThomΓ© Barbosa
                            Architecture and Product Ilustrator.
                            Be sure to check my channel, plenty of SketchUp modelling videos and some tutorials.
                            http://www.youtube.com/andretbms
                              Daniel S
                              Thank you πŸ˜ƒ
                              andretbms is right. If you go to the main post:
                              It says http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=17947#p144178
                              If you click in the link:
                              It should be changed for the correct link:
                              http://forums.sketchucation.com/viewtopic.php?f=180&t=17947#p144178
                              In hoverselect (http://forums.sketchucation.com/viewtopic.php?t=18916)
                              there is also the same problem:
                              I didnΒ΄t try with the other Fredo plugins... but perhaps the link problem is on every post.
                              Fredo or some moderator can change the links?
                              Since nobody mention this problem before... perhaps is because in the last SFC 5 minutes URL change(http://forums.sketchucation.com/viewtopic.php?f=323&t=29947), somebody break the automatic redirection?
                              Daniel S
                              • GaieusG
                                Thanks guys, I have updated the link.
                                It would normally work this way as well because there's a wild card redirect only it's not working now because there's some maintenance going on in the main site. See Coen's post about those URL changes.
                                anyway, when you see such a broken link, just swap the www.sketchucation.com/forums/scf/ part of the link to forums.sketchucation.com/
                                • GaieusG
                                  Just for the record guys, the redirect has been fixed. Now both url's / links should point to the same post.
                                  And thanks again for the alarm! πŸ‘
                                  • B
                                    Builder Boy
                                    I noticed this plugin could not smooth this vertex.
                                    However, I was able to bevel it manually without any problems.
                                    Step 1
                                    Step 2
                                    Step 3 (the final result)
                                    If you wanted to sharp the corner, you could do this:
                                    And, if you wanted to round the corner, you could do this:
                                    Please post an update.
                                    Untitled2.skp
                                    All my plugins
                                    • F
                                      Fluxus63
                                      Hi there,
                                      need some help to install RoundCorner on Mac. Get only errors! Ruby Console is installed. THX
                                      • jeff hammondJ
                                        make sure you also download LibFredo6 from:
                                        http://forums.sketchucation.com/viewtopic.php?f=323&t=17947#p144178
                                        the installation looks like this:
                                        **click picture for larger
                                        • K
                                          kylebc86
                                          I am just wondering if anyone can help me. I have installed both lib fredo file and the round corner plugins as instructed, however when i launch sketchup, i get a warning message that says
                                          *"Cannot load plugin Round Corner because the script cannot create DEFPARAM_Dir folder in: Users/kylebc86/Library/Application Support/Google Sketchup 7/ Sketchup/ Plugins
                                          Please create it manually respecting the case"*
                                          Anybody have any idea what i need to do. Thanks in advance
                                          Kyle
                                          • fredo6F
                                            @kylebc86 said:
                                            Kyle
                                            Kyle,
                                            Just as the message says, create a folder named DEFPARAM_Dir in the directory Users/kylebc86/Library/Application Support/Google Sketchup 7/ Sketchup/ Plugins
                                            The script cannot create it by itself, probably because of some security settings on your Mac.
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 74
                                            • 75
                                            • 14 / 75
