    1.5k Posts 477 Posters 4.2m Views 477 Watching
      Jim
      It seems like some modules are still being defined even when the extension is disabled.
      RoundCorner, for example exists even if the plugin is disabled in the Extensions list.
      • fredo6F
        Correct, but the module is almost empty. No code is loaded actually.
          Jim
          I was looking for a method to tell me if the Toolbar was available. I tried
          defined?(RoundCorner) which is defined even if the extension is disabled.
            andretbms
            Hello. Is it only me or the link that leads to the LibFredo6 3.3a post is broken? I can't get it opened here, forum gets an error.
            Thank you 😃
            André Thomé Barbosa
            Architecture and Product Ilustrator.
            Be sure to check my channel, plenty of SketchUp modelling videos and some tutorials.
            http://www.youtube.com/andretbms
              Daniel S
              Thank you 😃
              andretbms is right. If you go to the main post:
              It says http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=17947#p144178
              If you click in the link:
              It should be changed for the correct link:
              http://forums.sketchucation.com/viewtopic.php?f=180&t=17947#p144178
              In hoverselect (http://forums.sketchucation.com/viewtopic.php?t=18916)
              there is also the same problem:
              I didn´t try with the other Fredo plugins... but perhaps the link problem is on every post.
              Fredo or some moderator can change the links?
              Since nobody mention this problem before... perhaps is because in the last SFC 5 minutes URL change(http://forums.sketchucation.com/viewtopic.php?f=323&t=29947), somebody break the automatic redirection?
              Daniel S
              • GaieusG
                Thanks guys, I have updated the link.
                It would normally work this way as well because there's a wild card redirect only it's not working now because there's some maintenance going on in the main site. See Coen's post about those URL changes.
                anyway, when you see such a broken link, just swap the www.sketchucation.com/forums/scf/ part of the link to forums.sketchucation.com/
                • GaieusG
                  Just for the record guys, the redirect has been fixed. Now both url's / links should point to the same post.
                  And thanks again for the alarm! 👍
                  • B
                    Builder Boy
                    I noticed this plugin could not smooth this vertex.
                    However, I was able to bevel it manually without any problems.
                    Step 1
                    Step 2
                    Step 3 (the final result)
                    If you wanted to sharp the corner, you could do this:
                    And, if you wanted to round the corner, you could do this:
                    Please post an update.
                    Untitled2.skp
                    All my plugins
                    • F
                      Fluxus63
                      Hi there,
                      need some help to install RoundCorner on Mac. Get only errors! Ruby Console is installed. THX
                      • jeff hammondJ
                        make sure you also download LibFredo6 from:
                        http://forums.sketchucation.com/viewtopic.php?f=323&t=17947#p144178
                        the installation looks like this:
                        **click picture for larger
                        • K
                          kylebc86
                          I am just wondering if anyone can help me. I have installed both lib fredo file and the round corner plugins as instructed, however when i launch sketchup, i get a warning message that says
                          *"Cannot load plugin Round Corner because the script cannot create DEFPARAM_Dir folder in: Users/kylebc86/Library/Application Support/Google Sketchup 7/ Sketchup/ Plugins
                          Please create it manually respecting the case"*
                          Anybody have any idea what i need to do. Thanks in advance
                          Kyle
                          • fredo6F
                            @kylebc86 said:
                            Kyle
                            Kyle,
                            Just as the message says, create a folder named DEFPARAM_Dir in the directory Users/kylebc86/Library/Application Support/Google Sketchup 7/ Sketchup/ Plugins
                            The script cannot create it by itself, probably because of some security settings on your Mac.
                            • K
                              kylebc86
                              Brilliant, thanks Fredo, had a feeling it was something as simple as that.
                              • O
                                OZX
                                Salut,
                                C'est très très lent sur ma machine. Une solution ?
                                • JujuSKPJ
                                  JujuSKP Extension Creator
                                  Dear All,
                                  I recently update to sketchup 8, get the last fredo lib (3.4c) and the last roundcorner plugin.
                                  I also change windows to mac os.
                                  I have tried roundcorner plugin on sketchup 7 on windows (work fine), sketchup 7 and 8 on Mac (just crash or really lagy).
                                  Any idea for this problem?
                                  I am using Mac os 10.6
                                  Thank for reply,
                                  • fredo6F
                                    Dear All,
                                    Thank for reply,
                                    Juju,
                                    Can you be more explicit:
                                    • when is it slow: when you luanch it, when you select edges, when you generate the round geometry?
                                    • when does the crash on Mac happen?
                                    • is it slow for complex models or regradless?
                                    • JujuSKPJ
                                      Hi Fredo,
                                      First congratulation for this plugin (very usefull).
                                      I will try to explain my problem clearly in English (i am french native)
                                      To be more explicit:
                                      I have made some tries with complex and very simple models (simple cube), the problem is exactly the same.
                                      (I might think that the problem come from the ToolBar display, but I am not expert).
                                      • When I launch the tool, sketchup became lagy (almost freezing) and the toolbar make long time to appear (minimum 20 seconds).
                                      • It is mostly impossible to change the parameters on the tool bar (take 1, 2, 3 minutes to respond). I also try to change the settings with the Sketchup toolbar (the one at the right bottom) and the problem is still the same.
                                      • The probleme is the same if I want to select an edge.
                                      • If i do not change parameters (avoiding me 5 to 10 minutes of waiting), I can validate the action and Sketchup does the round corner. But it is also very laggy (2 to 3 minutes between my click and the corner drawing).
                                      To resume, Sketchup become really lagy as soon as I launch the round corner tools.
                                      The strangest thing is that when I use the round corner, not only sketchup freeze but my whole mac interface.
                                      I hope my explanations are clear.
                                      Thanks for your help,
                                      Julien
                                      • fredo6F
                                        Julien,
                                        1. Do you notice the same lagy behavior when you use my other plugins using the button palette interface (such as Curvilft or Tools On Surface)?
                                        2. When you execute the operation (click with green check mark), do you see the progressbar immediately and then progressing slowly, or do you see it appearing only at the end briefly? This will tell me if the problem is in the GUI refresh or in the global execution of the ruby code.
                                        3. Also, do you have a real crash on your Mac, or is it just álmost freezing'?
                                          To Mac users: Do you have the same bad experience with RoundCorner?
                                        • JujuSKPJ
                                          Fredo,
                                          1. Your other plugin such as Tools On Surface work fine (I just download and test the last version of Tools on Surface)
                                          2. Yes, the progress bar is working normally (As soon as I execute the operation, progress bar works and quickly). The difficult and laggy thing is to launch the operation.
                                          3. Not a real crash, my commands doesn't respond until sketchup come back to normal.
                                          Hope it helps
                                          thanks
                                          • JujuSKPJ
                                            If it can help, here is an extract of my ruby console for One operation:
                                            /Users/Ju/Library/Application Support/Google SketchUp 8/SketchUp/Plugins/ROUNDCORNER_Dir_21/RoundCorner_Algo.rb:1186: warning: Object#id will be deprecated; use Object#object_id
                                            /Users/Ju/Library/Application Support/Google SketchUp 8/SketchUp/Plugins/ROUNDCORNER_Dir_21/RoundCorner_Algo.rb:1187: warning: Object#id will be deprecated; use Object#object_id
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 74
                                            • 75
                                            • 14 / 75
