    [Plugin] TrueTangents v3.0
    95 Posts 34 Posters 116.9k Views 34 Watching
    • simon le bonS Offline
      simon le bon
      Dear Jeff,
      I come back again on this method you develop into the previous video(the first one).
      http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/Jeff.jpg
      Very foxy, indeed. I keep the link apart 😉
      Can I make a critique on the video itself !
      Some few editing, pointing milestones and resizing the long sames actions are preferable to this speedy solution. Witch we drive us to come again 5 or 6 times on the same rocket transition.
      ++simon.
        Ricco
        Thank for this TIG
        I think it will help me in my work,
        Now, i'm gonig to watch tutorials,
        Bye Jeff
        Ricco
        • dermotcollD Offline
          dermotcoll
          Thanks TIG - I look forwardto using this in my modelling.
          Slainte
          Dermot
          When you burn your arse - you gotta sit on the blisters!!
            simon le bon
            Dear Tig,
            sorry for disturbing!
            I experience some difficulty with "Common Tangents"
            After various tries, I haven't found what can be the point which make the plug sometime not working!
            http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/commonTangents01th.jpg
            Maybe an idea?
            😕 simon
              So, to recap... you have discovered certain combinations of circles that won't display 'common-tangents'?
              Looking at you image there seems nothing untoward. However, are all of these circles 'co-planar'? If they are not then they have no 'common-tangents'... I can't get it to reproduce unless I lift one of the circles up by a tiny amount (0.1mm) then it fails. The one with partial clines is a mystery...
              To check this move the problem circles up in the z a large amount then draw a large face at z=0 under the circles and use the Sandbox Drape Tool to ensure they 'stamp' onto the face. Erase the originals and the rest of the unwanted face. Retry the common-tangent tool to see if they now form...
              Could you send your problem skp to me by PM rather than clog up this thread ?
                Here's v2.0 http://forums.sketchucation.com/viewtopic.php?p=160780#p160780
                It has a tolerance added to the check on pairs of arcs' co-planar-ness: now pair of arcs that are not quite co-planar are still processed successfully...
                  simon le bon
                  Hurra!
                  I don't experience no difficulty anymore. Top strong!
                  Thank you TIG 👍
                    Noticed this TIG: http://forums.sketchucation.com/viewtopic.php?f=323&t=27592#p271449 ?
                      Here's v3.0 http://forums.sketchucation.com/viewtopic.php?p=160780#p160780
                      The Float method 'n1=~n2' has been replaced with 'eq(n1,n2)' to avoid potential clashes. 🤓
                        MartinK
                        Thanks TIG. I appreciate your hard work. It's great to find something you can't figure out how to do with standard SU tools and be able to find a plugin that will.
                        • Y Offline
                          Yomull
                          Hi TIG, Your plug in is working very well, thank you. But in fact I was looking for a tool that should make possible to draw a circle tangent to two other arcs or circles like the "Tan Tan Radius" option in autocad when drawing a circle. Do you have any idea how this is possible achieve into SketchUp?
                            Can't you do this combining these tools and some offset clines ?
                            Can you post an example of what you want ? 😕
                            • sdmitchS Offline
                              sdmitch
                              The Tan-Tan-Radius problem is a simple circle-circle intersection problem as you may know if you have ever done this manually. If not, simply offset the two arcs/circles by the radius of the circle to be placed tangent to the two. Where those offsets intersect is the center of the tangent circle.
                              http://sdmitch.blogspot.com/
                                carlm
                                Hi TIG-
                                TT 3.0's "filletarc" is exactly the tool I need, but it has a 'feature' that doesn't make sense to me: It appears that at least for circles in the <1" diameter range the minimum fillet radius is limited to 1/2 the circle's radius.
                                In other words the smallest fillet I can add to a 1" circle is 1/4".
                                On the other hand I can use TT's "tangentialarcs" tool to make a 1/16" fillet -- but I have to take the added step of constructing a 1/16" inch long line segment on my fillet line and select that in order to force "tangentialarcs" to construct a fillet of the correct radius -- except that this actually creates an approximately correct radius, whereas Filletarc's radius is exactly what I input.
                                Anyway, I guess my point is that I don't understand why Filletarc shouldn't be able to make fillets whose radii are smaller that 1/2 the filleted circle's radius.
                                Regardless, it's a really useful tool for dealing with the true geometry of circles!
                                Thanks, -Carl-
                                • gonashviliG Offline
                                  gonashvili
                                  Looks great, although I'm not really sure whats this plugin good for? (Hey, I ain't bi engineer 😄)
                                    Seriously? 😒
                                    • massimoM Offline
                                      massimo Moderator
                                      Well there are 66 lines of explanations and more than 10 images in the first TIG's post, plus 5 pages of thread so...seriously? 😉
                                        If you really need these tools then you'll already understand what they do... otherwise don't bother installing the toolset...
                                        • jeff hammondJ Offline
                                          jeff hammond
                                          ha!.. a decent way to put it 😉
                                          (sorry about my missing imgs in the thread.. I used to upload and display via mobile me then apple just wiped the whole thing out... meh.. I upload directly to scf nowadays)
                                          dotdotdot
                                            matt.gordon320
                                            Thanks TIG! I don't think I've ever seen such thorough explanations of plugin functionality. Much appreciated.
                                            • 4 / 5
