    [Plugin] TrueTangents v3.0
    95 Posts 34 Posters 120.3k Views 34 Watching
      Here's v2.0 http://forums.sketchucation.com/viewtopic.php?p=160780#p160780
      It has a tolerance added to the check on pairs of arcs' co-planar-ness: now pair of arcs that are not quite co-planar are still processed successfully...
      • simon le bonS
        simon le bon
        Hurra!
        I don't experience no difficulty anymore. Top strong!
        Thank you TIG πŸ‘
          Noticed this TIG: http://forums.sketchucation.com/viewtopic.php?f=323&t=27592#p271449 ?
            Here's v3.0 http://forums.sketchucation.com/viewtopic.php?p=160780#p160780
            The Float method 'n1=~n2' has been replaced with 'eq(n1,n2)' to avoid potential clashes. πŸ€“
              MartinK
              Thanks TIG. I appreciate your hard work. It's great to find something you can't figure out how to do with standard SU tools and be able to find a plugin that will.
              • Y
                Yomull
                Hi TIG, Your plug in is working very well, thank you. But in fact I was looking for a tool that should make possible to draw a circle tangent to two other arcs or circles like the "Tan Tan Radius" option in autocad when drawing a circle. Do you have any idea how this is possible achieve into SketchUp?
                  Can't you do this combining these tools and some offset clines ?
                  Can you post an example of what you want ? πŸ˜•
                  • sdmitchS
                    sdmitch
                    The Tan-Tan-Radius problem is a simple circle-circle intersection problem as you may know if you have ever done this manually. If not, simply offset the two arcs/circles by the radius of the circle to be placed tangent to the two. Where those offsets intersect is the center of the tangent circle.
                    http://sdmitch.blogspot.com/
                    • C
                      carlm
                      Hi TIG-
                      TT 3.0's "filletarc" is exactly the tool I need, but it has a 'feature' that doesn't make sense to me: It appears that at least for circles in the <1" diameter range the minimum fillet radius is limited to 1/2 the circle's radius.
                      In other words the smallest fillet I can add to a 1" circle is 1/4".
                      On the other hand I can use TT's "tangentialarcs" tool to make a 1/16" fillet -- but I have to take the added step of constructing a 1/16" inch long line segment on my fillet line and select that in order to force "tangentialarcs" to construct a fillet of the correct radius -- except that this actually creates an approximately correct radius, whereas Filletarc's radius is exactly what I input.
                      Anyway, I guess my point is that I don't understand why Filletarc shouldn't be able to make fillets whose radii are smaller that 1/2 the filleted circle's radius.
                      Regardless, it's a really useful tool for dealing with the true geometry of circles!
                      Thanks, -Carl-
                      • gonashviliG
                        gonashvili
                        Looks great, although I'm not really sure whats this plugin good for? (Hey, I ain't bi engineer πŸ˜„)
                          Seriously? πŸ˜’
                          • massimoM
                            massimo Moderator
                            Well there are 66 lines of explanations and more than 10 images in the first TIG's post, plus 5 pages of thread so...seriously? πŸ˜‰
                              If you really need these tools then you'll already understand what they do... otherwise don't bother installing the toolset...
                              • jeff hammondJ
                                ha!.. a decent way to put it πŸ˜‰
                                (sorry about my missing imgs in the thread.. I used to upload and display via mobile me then apple just wiped the whole thing out... meh.. I upload directly to scf nowadays)
                                  matt.gordon320
                                  Thanks TIG! I don't think I've ever seen such thorough explanations of plugin functionality. Much appreciated.
                                    I believe that make that πŸ˜„
                                    http://moi3d.com/forum/get_attachment.php?webtag=MOI&hash=4c456a620293175a29e2553cc76a28b2&filename=TanTanObjectSnap.gif
                                      dedmin
                                      Hi TIG. I installed TrueTangents via latest SketchUcation Plugin Store. It works, but why are the tool-tips displayed in the Ruby console and not in the status bar?
                                      Latest SU Pro, Win 7 64 bit latest.
                                      Thanks.
                                        Thanks.
                                        [attachment=0:ahmfglq7]<!-- ia0 -->Capture-2.jpg<!-- ia0 -->[/attachment:ahmfglq7]
                                        This toolset was originally designed to run from the Ruby Console, or from within other methods - so the tools' guidance/errors go into the Ruby Console, rather than the status-bar or an error message-box...
                                        It's the same in all SketchUp versions - it's not v2014 specific.
                                        πŸ€“
                                          dedmin
                                          Thanks.
                                          [attachment=0:2c4kpk1c]<!-- ia0 -->Capture-2.jpg<!-- ia0 -->[/attachment:2c4kpk1c]
                                          πŸ€“
                                          I see. πŸ€“
                                          • B
                                            bobsammer
                                            Does the True Tangent plugin work in SU2017?
                                            Bob
                                            • 4 / 5
