    ๐Ÿ”Œ Smart Spline | Fluid way to handle splines for furniture design and complex structures. Download
    [Plugin] TrueTangents v3.0
    95 Posts 34 Posters 110.9k Views 34 Watching
    • BepB Offline
      Bep
      Hello Tig,
      Would it be possible to add "true intersections points" to the plugin.
      These would indicate where cirkels and arcs mathematicly intersect.
      as in the second picture
      As I understand true cirkels in Sketchup are impractical because the would couse a to many faces in a model,
      a true "construction cirkel" as in the first picture,(that would not be able to create a face to be push-pull't) as a build in tool or plugin however would be the best solution IMHO to overcome a lot of strugling of the ruby programmers to repair this shortcomming of Sketchup.
      Thanks for all your great plugins.
      Bep van Malde
      True consstruction circel
      True intersections
      "History is written by the winners"
        v1.5 is now available with a new tool 'trueintersections' - which adds cpoints at true intersection points for either 2nr selected intersecting arcs/circles OR a selected arc/circle and intersecting cline...
        Get it here: http://forums.sketchucation.com/viewtopic.php?p=160780#p160780
        • massimoM Offline
          massimo Moderator
          Thank you, TIG. Really useful.
          • BepB Offline
            Bep
            ๐Ÿ‘ ๐Ÿ‘
            Many Thanks Tig!
            Greetings ,
            Bep van Malde
            • utilerU Offline
              utiler
              This is fantastic, TIG, much appreciated!!!
              Just Curious...
                cyan.archnet
                THANKS A LOT for this GREAT plugin.
                • jeff hammondJ Offline
                  jeff hammond
                  hi TIG
                  i'm wondering if it's possible to add the following ability to TrueTangents:
                  http://homepage.mac.com/jeffhammond/.Public/scf/TIG_question.jpg
                  or, is there already a way to do this with v1.5 that i'm overlooking? it appears the options in v1.5 are working in similar fashion as each other (all dimensions are locked in place prior to using the tool) and this request would work a bit differently but if you think it's possible, i think it'd be a great addition to the toolset.
                  thanks much
                  dotdotdot
                    Jeff
                    v1.6 http://forums.sketchucation.com/viewtopic.php?p=160780#p160780
                    Now includes an extra tool 'tangentialarcs' which does what was asked ? Select a Line and an Arc/circle and useful cpoints and lines are added for you...
                    It does actually draw the arc for you as there are two possibilities - it makes the cpoints and clines needed and you can easily use the 2D Arc / Circle tool in 3-point mode to make the arc/circle needed...
                      curro_laca
                      Thanks, tig. Working like a charm.
                      Everything you release is really top of the tops. ๐Ÿ‘
                        jeff hammond
                        Sweet! I'm on a phone right now but I'll try it out a little later.
                        dotdotdot
                          That is geometry! ๐Ÿ˜Ž
                          • mitcorbM Offline
                            mitcorb
                            Hmmm. Looks like it's time for me to check this out. Thank you, again, TIG
                              jeff hammond
                              oh man, that's great!
                              i basically have two situations where i need to make the double benders and this fully covers one of those (the one that's much harder for me to figure out manually). Thanks so much for adding this to TrueTangents!
                              [the other situation is when both arcs are a known radii but i can resolve that one easier.. still, if you think you could add the dialog box etc, that'd be cool too.. surely some other people would like that type of fillet tool in SU, no?]
                              dotdotdot
                                v1.7 now available http://forums.sketchucation.com/viewtopic.php?p=160780#p160780
                                With new filletarc tool to fillet a selected arc/circle to a selected line/cline, to a radius given in a dialog, clines/cpoints for centers/tangent-points etc for the 4 or 8 possible fillets depending on whether or not the line intersects the arc...
                                  jeff hammond
                                  damn! perfect!
                                  thanks a ton TIG
                                  dotdotdot
                                  • simon le bonS Offline
                                    simon le bon
                                    filletarc tool: what a good idea ๐Ÿ‘
                                    filletarc
                                    Select an arc/circle and a cline/line (aka guide-line)
                                    Run filletarc
                                    unfortunately, it doesn't appear for me in the plugin menu ๐Ÿ˜ž
                                    (what am I doing wrong?) โ“ simon
                                      jeff hammond
                                      @simon le bon said:
                                      I'm a little bit disappointed by the fact that depending on the radius is, the tangent lines cannot join perfectly ( certainly due to segmentation of the circles)
                                      but that's the whole point ๐Ÿ˜„
                                      the cpoints are placed in the correct place so you can the draw (or redraw) the arcs at the true position. Hence - true tangents
                                      dotdotdot
                                        Here's v1.8 that fixes the missing menu item glitch - there are now 5 !
                                        My latest tool "Fillet Arc [Arc+Line|Cline]" should now appear in the Plugins menu at the end of the rest ๐Ÿ˜ณ
                                        At the last moment just before I uploaded v1.7 I changed that item's text to read "Fillet Arc [Arc+Line/Cline]" forgetting that a '/' in a menu name stops it appearing - at least on PCs...
                                        Note that typing filletarc in the Console also runs it...
                                        Sorry for the confusion... ๐Ÿ˜•
                                          filletarc
                                          Run filletarc
                                          There should be a group of 4+1 tools in the Plugins menu with TrueTangents et al the last one is FilletArc... Alternatively select an arc/circle and a line/cline and type filletarc in the Ruby Console - it should work... If not, then there might be a problem with the install...
                                          • utilerU Offline
                                            utiler
                                            Thank you TIG, your generosity is greatly appreciated!!!! ๐ŸŽ‰
                                            Just Curious...
                                            • 2 / 5
