    [Plugin] TrueTangents v3.0
    95 Posts 34 Posters 120.3k Views 34 Watching
    • takesh hT
      takesh h
      Thanks a bunch TIG, now a simple thing is truely simple.
      I confirmed it works on Macs. 😉
        joergj
        Thank you, TIG!
        I missed this tool a lot of times in the past.
        And a special thank you for making it work in SU5 and on the mac!
        Jörg
        • P
          putnik
          Nice one TIG, thanks a lot!
          http://keshas.info
          • C
            cyan.archnet
            GREAT PLUGUN!, thanks a lot!
            • erikBE
              erikB
              very usefull !!
              Thanks TIG
              erikB
                Here's v1.3... http://forums.sketchucation.com/viewtopic.php?p=160780#p160780
                I've added some more cpoints - at the intersections of the circumference(s) and the line from cpoint-to-centre or centre-to-centre - these can be useful if you want to redraw an arc through three points from tp to tp quickly with the same radius...
                  Here's v1.4 http://forums.sketchucation.com/viewtopic.php?p=160780#p160780
                  It's updated to have extra cpoints/clines on the opposite sides of the arcs' circumferences - now to aid in possible redraw in both directions of arc's curve...
                  • H
                    HBMASA
                    TIG,I wanted a celebration, this plug-in.
                    The traditional skills are essential to kikujutu Japan.
                    • BepB
                      Bep
                      Hello Tig,
                      Would it be possible to add "true intersections points" to the plugin.
                      These would indicate where cirkels and arcs mathematicly intersect.
                      as in the second picture
                      As I understand true cirkels in Sketchup are impractical because the would couse a to many faces in a model,
                      a true "construction cirkel" as in the first picture,(that would not be able to create a face to be push-pull't) as a build in tool or plugin however would be the best solution IMHO to overcome a lot of strugling of the ruby programmers to repair this shortcomming of Sketchup.
                      Thanks for all your great plugins.
                      Bep van Malde
                      True consstruction circel
                      True intersections
                      "History is written by the winners"
                        v1.5 is now available with a new tool 'trueintersections' - which adds cpoints at true intersection points for either 2nr selected intersecting arcs/circles OR a selected arc/circle and intersecting cline...
                        Get it here: http://forums.sketchucation.com/viewtopic.php?p=160780#p160780
                        • massimoM
                          massimo Moderator
                          Thank you, TIG. Really useful.
                          • BepB
                            Bep
                            Many Thanks Tig!
                            Greetings ,
                            Bep van Malde
                            • utilerU
                              utiler
                              This is fantastic, TIG, much appreciated!!!
                              Just Curious...
                              • C
                                cyan.archnet
                                THANKS A LOT for this GREAT plugin.
                                • jeff hammondJ
                                  hi TIG
                                  i'm wondering if it's possible to add the following ability to TrueTangents:
                                  http://homepage.mac.com/jeffhammond/.Public/scf/TIG_question.jpg
                                  or, is there already a way to do this with v1.5 that i'm overlooking? it appears the options in v1.5 are working in similar fashion as each other (all dimensions are locked in place prior to using the tool) and this request would work a bit differently but if you think it's possible, i think it'd be a great addition to the toolset.
                                  thanks much
                                    Jeff
                                    v1.6 http://forums.sketchucation.com/viewtopic.php?p=160780#p160780
                                    Now includes an extra tool 'tangentialarcs' which does what was asked ? Select a Line and an Arc/circle and useful cpoints and lines are added for you...
                                    It does actually draw the arc for you as there are two possibilities - it makes the cpoints and clines needed and you can easily use the 2D Arc / Circle tool in 3-point mode to make the arc/circle needed...
                                    • C
                                      curro_laca
                                      Thanks, tig. Working like a charm.
                                      Everything you release is really top of the tops. 👍
                                      • jeff hammondJ
                                        Sweet! I'm on a phone right now but I'll try it out a little later.
                                          That is geometry! 😎
                                          • mitcorbM
                                            mitcorb
                                            Hmmm. Looks like it's time for me to check this out. Thank you, again, TIG
                                            • 2 / 5
