    [Plugin] TrueTangents v3.0
    95 Posts 34 Posters 118.9k Views 34 Watching
      cyan.archnet
      GREAT PLUGUN!, thanks a lot!
      • erikBE Offline
        erikB
        very usefull !!
        Thanks TIG
        erikB
          Here's v1.3... http://forums.sketchucation.com/viewtopic.php?p=160780#p160780
          I've added some more cpoints - at the intersections of the circumference(s) and the line from cpoint-to-centre or centre-to-centre - these can be useful if you want to redraw an arc through three points from tp to tp quickly with the same radius...
            Here's v1.4 http://forums.sketchucation.com/viewtopic.php?p=160780#p160780
            It's updated to have extra cpoints/clines on the opposite sides of the arcs' circumferences - now to aid in possible redraw in both directions of arc's curve...
            • H Offline
              HBMASA
              TIG,I wanted a celebration, this plug-in.
              The traditional skills are essential to kikujutu Japan.
              • BepB Offline
                Bep
                Hello Tig,
                Would it be possible to add "true intersections points" to the plugin.
                These would indicate where cirkels and arcs mathematicly intersect.
                as in the second picture
                As I understand true cirkels in Sketchup are impractical because the would couse a to many faces in a model,
                a true "construction cirkel" as in the first picture,(that would not be able to create a face to be push-pull't) as a build in tool or plugin however would be the best solution IMHO to overcome a lot of strugling of the ruby programmers to repair this shortcomming of Sketchup.
                Thanks for all your great plugins.
                Bep van Malde
                True consstruction circel
                True intersections
                "History is written by the winners"
                  v1.5 is now available with a new tool 'trueintersections' - which adds cpoints at true intersection points for either 2nr selected intersecting arcs/circles OR a selected arc/circle and intersecting cline...
                  Get it here: http://forums.sketchucation.com/viewtopic.php?p=160780#p160780
                  • massimoM Offline
                    massimo Moderator
                    Thank you, TIG. Really useful.
                    • BepB Offline
                      Bep
                      Many Thanks Tig!
                      Greetings ,
                      Bep van Malde
                      • utilerU Offline
                        utiler
                        This is fantastic, TIG, much appreciated!!!
                        Just Curious...
                          cyan.archnet
                          THANKS A LOT for this GREAT plugin.
                          • jeff hammondJ Offline
                            hi TIG
                            i'm wondering if it's possible to add the following ability to TrueTangents:
                            http://homepage.mac.com/jeffhammond/.Public/scf/TIG_question.jpg
                            or, is there already a way to do this with v1.5 that i'm overlooking? it appears the options in v1.5 are working in similar fashion as each other (all dimensions are locked in place prior to using the tool) and this request would work a bit differently but if you think it's possible, i think it'd be a great addition to the toolset.
                            thanks much
                              Jeff
                              v1.6 http://forums.sketchucation.com/viewtopic.php?p=160780#p160780
                              Now includes an extra tool 'tangentialarcs' which does what was asked ? Select a Line and an Arc/circle and useful cpoints and lines are added for you...
                              It does actually draw the arc for you as there are two possibilities - it makes the cpoints and clines needed and you can easily use the 2D Arc / Circle tool in 3-point mode to make the arc/circle needed...
                                curro_laca
                                Thanks, tig. Working like a charm.
                                Everything you release is really top of the tops. 👍
                                  Sweet! I'm on a phone right now but I'll try it out a little later.
                                    That is geometry! 😎
                                    • mitcorbM Offline
                                      mitcorb
                                      Hmmm. Looks like it's time for me to check this out. Thank you, again, TIG
                                        oh man, that's great!
                                        i basically have two situations where i need to make the double benders and this fully covers one of those (the one that's much harder for me to figure out manually). Thanks so much for adding this to TrueTangents!
                                        [the other situation is when both arcs are a known radii but i can resolve that one easier.. still, if you think you could add the dialog box etc, that'd be cool too.. surely some other people would like that type of fillet tool in SU, no?]
                                          v1.7 now available http://forums.sketchucation.com/viewtopic.php?p=160780#p160780
                                          With new filletarc tool to fillet a selected arc/circle to a selected line/cline, to a radius given in a dialog, clines/cpoints for centers/tangent-points etc for the 4 or 8 possible fillets depending on whether or not the line intersects the arc...
                                            damn! perfect!
                                            thanks a ton TIG
                                            • 2 / 5
