[Plugin] TrueTangents v3.0
Thank you very much for this TIG. This will come in very handy.
Thanks a bunch TIG, now a simple thing is truely simple.
I confirmed it works on Macs.
Thank you, TIG!
I missed this tool a lot of times in the past.
And a special thank you for making it work in SU5 and on the mac!
Jörg -
Nice one TIG, thanks a lot!
GREAT PLUGUN!, thanks a lot!
very usefull !!
Thanks TIG
erikB -
Here's v1.3... http://forums.sketchucation.com/viewtopic.php?p=160780#p160780
I've added some more cpoints - at the intersections of the circumference(s) and the line from cpoint-to-centre or centre-to-centre - these can be useful if you want to redraw an arc through three points from tp to tp quickly with the same radius... -
Here's v1.4 http://forums.sketchucation.com/viewtopic.php?p=160780#p160780
It's updated to have extra cpoints/clines on the opposite sides of the arcs' circumferences - now to aid in possible redraw in both directions of arc's curve... -
TIG,I wanted a celebration, this plug-in.
The traditional skills are essential to kikujutu Japan. -
Hello Tig,
Would it be possible to add "true intersections points" to the plugin.
These would indicate where cirkels and arcs mathematicly intersect.
as in the second pictureAs I understand true cirkels in Sketchup are impractical because the would couse a to many faces in a model,
a true "construction cirkel" as in the first picture,(that would not be able to create a face to be push-pull't) as a build in tool or plugin however would be the best solution IMHO to overcome a lot of strugling of the ruby programmers to repair this shortcomming of Sketchup.Thanks for all your great plugins.
Bep van Malde
v1.5 is now available with a new tool 'trueintersections' - which adds cpoints at true intersection points for either 2nr selected intersecting arcs/circles OR a selected arc/circle and intersecting cline...
Get it here: http://forums.sketchucation.com/viewtopic.php?p=160780#p160780
Thank you, TIG. Really useful.
Many Thanks Tig!
Greetings ,
Bep van Malde
This is fantastic, TIG, much appreciated!!!
THANKS A LOT for this GREAT plugin.
hi TIG
i'm wondering if it's possible to add the following ability to TrueTangents:
or, is there already a way to do this with v1.5 that i'm overlooking? it appears the options in v1.5 are working in similar fashion as each other (all dimensions are locked in place prior to using the tool) and this request would work a bit differently but if you think it's possible, i think it'd be a great addition to the toolset.
thanks much
Jeff
v1.6 http://forums.sketchucation.com/viewtopic.php?p=160780#p160780
Now includes an extra tool 'tangentialarcs' which does what was asked ? Select a Line and an Arc/circle and useful cpoints and lines are added for you...
It does actually draw the arc for you as there are two possibilities - it makes the cpoints and clines needed and you can easily use the 2D Arc / Circle tool in 3-point mode to make the arc/circle needed...
Thanks, tig. Working like a charm.
Everything you release is really top of the tops.
Sweet! I'm on a phone right now but I'll try it out a little later.
That is geometry!
