    [Plugin][$] FredoScale - v3.6a - 01 Apr 24
    1.1k Posts 343 Posters 2.3m Views 340 Watching
      chouaibcl65
      thank you , i dont know how to download
      • Jean-FrancoJ Offline
        Jean-Franco
        Hi Chouaib,
        go to the end of the first post of this thread and you will find the file to download.
        Jean-Franco
          chouaibcl65
          thank yououuu
            Mocom
            i love your plug-ins you are the master thank you. 😄
            • K Offline
              KarinaGM
              I have a problem with the plugin. It suddendly stoped working.
              A couple of hours ago I used it normaly. Now I can't bend or twist... 😕
              I haven't installed nothing new, just worked with huge files that sometimes crash.
              Here I put some screenshots of what is happening now when I try to use radial bend
              I downoladed and reinstaled the plugin and Libredo (just in case) in the correct path, just where it was this morning. I checked the list file by file (everything was there), anyway I deleted and place the new ones instead. No luck. Restarted pc (sometimes it works) no luck again.
              **"Aquel que sacrifica un poco de libertad por seguridad, no se merece ninguna y terminará perdiendo ambas"
              -Benjamín Franklin.**
                There is a toggle that makes it subdivide the object. Looks like you have turned it off. I can't remember what key toggled it though.
                  Read the manual... http://forums.sketchucation.com/download/file.php?id=35246
                  • K Offline
                    KarinaGM
                    well I read it... but until now it never ocured to me that the defaults didn't include slicing. 😳
                    THANKS!
                    • fredo6F Offline
                      fredo6
                      THANKS!
                      Slicer is activated by key F4.
                      Note that all options can also be activated via the contextual menu (right click).
                      Fredo
                        Barack
                        SUCH A POWERFUL PLUGIN--- FOR FREE!!! YOU ARE THE COOLEST!!! 😄:D:D:D!!!
                        I'm a Sketchup Free user, nothing else. 3DS is way too expensive, and Pro, ditto. What else do you expect?
                        UPDATE: I have some blender knowledge, that is why this signature is edited.
                          lensman
                          As I said somewhere else in a review of this plug-in, it goes waaaay beyond that status and should have been a part of the original programme. Google snap this guy up! - No, wait, don't!! - We'd have to pay for this stuff then!
                          Great stuff.
                          • pyrolunaP Offline
                            pyroluna
                            Someone is advertising for you, Fredo!
                              It is 'free' - but like many of us 'scripters' donations are accepted by Fredo - no matter how small they are - then at least it's a recognition of the efforts involved in making these tools for you - a euro/dollar or two/ten wouldn't hurt... 😒
                                So comical 🤣
                                [flash=480,385:1r6pod0m]http://www.youtube.com/v/Z7HyPsyLY3A&hl[/flash:1r6pod0m]
                                [flash=480,385:1r6pod0m]http://www.youtube.com/v/tixFgx-Uv3I&hl[/flash:1r6pod0m]
                                  rafaelds
                                  Hi everybody, specially Fredo! 😄
                                  I'm not sure if this is the right place, but I think I found a bug in FredoScale and would like to report it. Here are the steps to reproduce it:
                                  1. I've drawn 2 boxes. Each is an individual component. The one in the right has the top texture set to 'projected', the left one does not.
                                  http://img532.imageshack.us/img532/4449/fs1p.jpg
                                  1. Using planar shearing, I 'shear-ed' both along the blue axis, by the same amount.
                                  http://img14.imageshack.us/img14/8697/fs2u.jpg
                                  1. I opened the right component for editing. Just opened, did not even click on a single surface. Texture placement gets messed up.
                                  http://img576.imageshack.us/img576/2955/fs3.jpg
                                  1. After closing the component it's easier to spot the difference between both textures:
                                  http://img16.imageshack.us/i/fs4z.jpg/
                                  1. Even after undo'ing the operation, textures are still incorrect:
                                  http://img338.imageshack.us/img338/6219/fs5q.jpg
                                  The same effect happens if the boxes are not components, but with slightly different characteristics: if each box is sheared individually, only the one with the projected textures is 'damaged'. But if both are selected at the same time and the shearing is done to the whole lot, both end up correct, even though textures are set to projected in only one.
                                  I first noticed this effect in a model I am working on, but the problem seems more serious there. After opening the component textures are messed up, and show in different ways if a component is open or closed:
                                  http://img16.imageshack.us/img16/563/fs6o.jpg
                                  http://img163.imageshack.us/img163/2717/fs7e.jpg
                                  In this case I can't even repair the problem manually. I do have a hidden rectangle with the whole texture, from which I can pick the texture and paint the new created geometry, but the textures never show up correctly, it does not matter if set to projected or not. I wish I had made at least a daily backup... 😕
                                  • fredo6F Offline
                                    fredo6
                                    Rafael,
                                    Can you post the skp file with the two boxes and texture.
                                    Planar shearing is an atypical transformation, because it seems that SU also shears the reference axes of the component and groups. I don't know why, but this is what SU does. And this may be the reason why the textures cannot be projected correctly.
                                    Anyway, I can try to find a way to overcome this
                                    Fredo
                                    PS: For recovering your initial model, did you try to use the autosave version.
                                      rafaelds
                                      Thanks for the quick reply, Fredo!
                                      That model I used for the screenshot I no longer have, it was just something I put together quickly to illustrate. I just made another one, hopefully more explaining.
                                      As for my model, never mind it. I use a program for online backup and sync'ing across computers and it turns out it stores previous versions of files as well. 😄
                                      Attached to this post goes a SKP file. It shows a similar operation performed on a pair of boxes, the one on the right having projected textures. Along the green axis different techniques with and without FredoScale are used, and the differences are shown.
                                      boxes.skp
                                      • fredo6F Offline
                                        fredo6
                                        I had a look at the file, and it seems that it is related to the sharing of the component axes. You can of course remodify the axes so that they are orthogonal, but this does not restore the expected projected texture (however, subsequence projections are OK).
                                        So, I may have no way to fix that, and it may be advised to first deform, and then apply textures.
                                        Fredo
                                          rafaelds
                                          Thanks, Fredo.
                                          I am working around this "issue" by unsetting the 'projected' flag from the appropriate faces prior to shearing with FredoScale. As can be seen in the SKP file I uploaded, FredoScale by itself does what I expected and projecting was unnecessary.
                                          • mitcorbM Offline
                                            mitcorb
                                            Hi, Fredo:
                                            I don't know if anyone has asked this about the suite of tools in Fredoscale, but here goes. (of course this ability may already be available)
                                            Have you considered modifying your temporary lattice cage to address the pre-existing mesh for bending and tapering? By this I mean make it optional to use a replication of the existing model as the temporary deformation lattice?
                                            Just a thought. 😄
                                            Best Regards,
                                            mitcorb
                                            • 21
                                            • 22
                                            • 23
                                            • 24
                                            • 25
                                            • 56
                                            • 57
                                            • 23 / 57
