    [Plugin Library] LibFredo6
    2.2k Posts 583 Posters 7.7m Views 585 Watching
    • fredo6F Offline
      fredo6
      How did you install LibFredo6?
      • Copying files?
      • Sketchup Extension manager from a rbz
      • Sketchucation ExtensionStore?
      It seems one file is altered.
      • tlehman914T Offline
        tlehman914
        I am still not able to use most all of the Fredo extensions. I have removed ALL Fredo plugins and reinstalled LibFredo6 v11.6a from SketchUcation PluginStore and still get the following error:
        Error: #<ArgumentError: invalid byte sequence in UTF-8>
        /users/toddlehman/library/application support/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/body_lib6g6.rbe:9318:in strip' /users/toddlehman/library/application support/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/body_lib6g6.rbe:9318:in load_from_file'
        /users/toddlehman/library/application support/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/body_lib6g6.rbe:9221:in block in load_all_colors' /users/toddlehman/library/application support/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/body_lib6g6.rbe:9216:in each'
        /users/toddlehman/library/application support/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/body_lib6g6.rbe:9216:in load_all_colors' /users/toddlehman/library/application support/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/body_lib6g6.rbe:9164:in initialize'
        /users/toddlehman/library/application support/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/body_lib6g6.rbe:9151:in new' /users/toddlehman/library/application support/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/body_lib6g6.rbe:9151:in instantiate'
        /users/toddlehman/library/application support/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/body_lib6g6.rbe:3830:in color_parse' /users/toddlehman/library/application support/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/body_lib6g6.rbe:4007:in color_luminance'
        /users/toddlehman/library/application support/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/body_lib6g6.rbe:4017:in color_is_dark?' /users/toddlehman/library/application support/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/body_lib6palette.rbe:2797:in draw_button_text'
        /users/toddlehman/library/application support/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/body_lib6palette.rbe:2699:in draw_button' /users/toddlehman/library/application support/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/body_lib6palette.rbe:3203:in block in draw'
        /users/toddlehman/library/application support/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/body_lib6palette.rbe:3196:in each' /users/toddlehman/library/application support/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/body_lib6palette.rbe:3196:in draw'
        /users/toddlehman/library/application support/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/lib6palette.rbe:78:in draw' /users/toddlehman/library/application support/sketchup 2021/sketchup/plugins/fredo6_toolsonsurface/shapeonsurface.rbe:575:in draw'
        • fredo6F Offline
          fredo6
          I don't know what happened during the installation, but there is clearly a problem in a few files which lost their UTF8 encoding.
          Could you try the following
          • Open the Ruby Console
          • copy the following command in red and type Enter:
            UI.openURL LibFredo6.path + '/Ancillary'
          • This will open a subfolder of LibFredo6
          • Delete the file Colors_RAL_classic.txt
          • restart Sketchup to see if this improves the situation
          • Otherwise, delete all files with names beginning with Colors_ and extension txt.
          Then restart Sketchup to see if this improves the situation.
            tlehman914
            I did try to copy the following command in red and type Enter:
            Result:
            false
            I did however, go to that folder in 'Finder' and Delete the file Colors_RAL_classic.txt - restarted and no change.
            I then deleted all files with names beginning with Colors_ and extension txt. - restarted and tried to use the only PlugIn installed: ToolsOnSurface - result:
            • fredo6F Offline
              fredo6
              What is left in the directory?
              Just type in the Ruby console:
              Dir[LibFredo6.path + '/Ancillary/*.*']
                tlehman914
                Nothing is left in the directory...?
                No change after typing the above.
                • fredo6F Offline
                  fredo6
                  Did you define a custom color file?
                  If so, do you remember where you save it?
                  In the Ruby Console, could you type
                  Traductor::Marshall.new.decode(Traductor::Registry.load "Fredo6_ColorFan_Custom")
                  This should be the list of custom color files.
                    tlehman914
                    {"/Users/toddlehman/Dropbox (Cre8Play)/SketchUp/Materials/Archive/Bark/Tree Tex8.jpg"=>true}
                      tlehman914
                      I deleted the material 'Tree Tex8.jpg', and all is working!!!! 👍 😎 🎉
                      THANK YOU!!!!
                      • fredo6F Offline
                        fredo6
                        In ColorPaint, you are supposed to load only plain text file (tabular value of colors: name, R, G, B), not images or material.
                          tlehman914
                          Understood. I didn't even know that I had done that...!? Thanks again!
                            Robotopera
                            • Copying files?
                            Tried all 3 with full uninstalls in between each. Sadly no luck.
                            Success! Running a repair on the sketchup installation seemed to fix it!
                              atrasnap
                              Bonjour à tous,
                              Je viens d'installer l'extension FredoTools via le gestionnaire d'extension,
                              Elle apparait bien dans mon gestionnaire d'extension mais nul part ailleurs ?
                              Je ne peut donc pas l'utiliser.
                              Il ya t-il une raison ou une manip particulière à effectuer ?
                              Je suis sur SketchUp 21pro
                              Merci d'avance
                                Have you also installed LibFredo ?
                                Have you restarted SketchUp ?
                                Have you looked in the Tools menu's submenus ?
                                Avez-vous également installé LibFredo?
                                Avez-vous redémarré SketchUp?
                                Avez-vous regardé dans les sous-menus du menu Outils [Tools]?
                                  martychristoffel
                                  I'm seeing some UI problems, specifically buttons at the bottom of various dialog boxes being completely washed out. I'm on MacOS Big Sur.
                                  I don't have this problem in other applications, only here in SketchUp and with these dialog box buttons.
                                  Any thoughts? Is it a SketchUp thing, an extension thing, or an OS thing?
                                  Please see image examples.
                                  Thanks.
                                  • fredo6F Offline
                                    fredo6
                                    @martychristoffel
                                    Thanks for signaling this problem. You are the first one.
                                    Big Sur seems to be a master in term of non-backward compatibility, at least for Sketchup...!
                                    I will see if I can find a workaround in a next version of LibFredo6.
                                    Fredo
                                      Dekorte
                                      Hello LibFredo6,
                                      I recieved your message showing me your Pic2Shape plugin.
                                      I tried it with a couple of images and it works great.
                                      However, I would like to use this for cutting out the contours of 2D trees, so i can cast a more realistic shadow.
                                      And here I ran into some troubles.
                                      For complex trees (with a lot of tiny holes between the branches) the plugin says he can't generate any contours.
                                      I wonder if you could help me with the right filter settings so that the plugin can still work ?
                                      I attached a tree (png) that doesn't generate a boundary when using the plugin.
                                      All the png trees i'm using are available (for free) as high quality PNG’s with transparent background from this website : https://meye.dk/info/
                                      Many thanks in advance !
                                      Boris
                                      example tree png
                                      • fredo6F Offline
                                        fredo6
                                        Since this thread is about LibFredo6, I created a dedicated thread here.
                                        Fredo
                                          Tibonator
                                          Very efficient plugin thank you.
                                          The only issue is that the colour of action icons are extremely difficult to read against the white background.
                                          I am using SUP2021 on a MacBoo pro 2018 running under MacOS Mojave.
                                          Is it just me or a common issue that could be resolved easily on the developer's end?
                                          Thank you.
                                          T
                                          Icons colour (dotted in red) unreadable against white background.
                                          • fredo6F Offline
                                            fredo6
                                            This will be fixed in the next version of LibFredo6. This seems to happen for some Mac configurations.
                                            • 86
                                            • 87
                                            • 88
                                            • 89
                                            • 90
                                            • 112
                                            • 113
                                            • 88 / 113
