    [Plugin Library] LibFredo6 - v16.4b - 21 Nov 26
    2.3k Posts 597 Posters 16.1m Views 599 Watching
    • TIGT
      It is at v6.0b, and it is currently available in the PluginStore - learn to use it. it'll make you life a lot easier...
      • B
        behnam123
        thanks!!!!! From Iran
        • Z
          zemane
          sketchup 2014 says it can't find Fredo Library folder after I install it.
            It must not be installed correctly. How and where did you install it?
            • Z
              zemane
              I used SU2014 extension warehouse. It allocates the folder under the correct path.. but SU doesn't see it. Why??
              the folder is there, under appdata......plugins, with the default extensions, under the name of Fredo6_!LibFredo6 and Fredo6_!LibFredo6.rb
              What should be wrong?
              • TIGT
                What is your Windows User-name?
                Please post the results of this code in the Ruby Console:
                It should return the paths to various folders...
                If your user-name has accents in it, then it is a known issue that can block some Ruby ' File' operations.
                This has greatly improved in v2014 Ruby2, but with accented characters there can still be some failures when using __FILE__, which itself sets the path to a loading .rb file and which is used to set relative-paths, but can be incorrectly encoded, if accented.
                There is a clunky workaround used by some scripts [like the SketchUcation toolset] which sidesteps the issue by forcing the correct encoding in v2014 - but in earlier versions the problem can't be circumvented...
                • Z
                  zemane
                  yep.. that is the case.. my user name has accent : (
                  I though that might be the issue.. I'll try a work around.
                  • Z
                    ZeMiguel
                    I have the exact same problem.
                    I must ask! what kind of “work around” can solve this problem…without having to change the user name. Thanks!
                    • TIGT
                      Sorry 😞
                      Unfortunately there is no effective solution - except getting SketchUp v2014...
                      What is stopping you using that - in parallel with earlier versions if you must...
                      But why must you have an accent in your Windows user-name ?
                      It is well know to cause issues with applications - like SketchUp < v2014 where the Ruby version cannot cope with the 'File' issues...
                      Unfortunately simply renaming your Windows user-account still leaves residual linked in 'accented-name' folders etc...
                      There is good guidance on the www on how to make another 'clean' user-name account and then copy over all of your current folders and files to that.
                      Then once it is all working you can remove the accented-name account ???
                      e.g. http://www.thewindowsclub.com/transfer-user-profile-in-windows
                      • Z
                        ZeMiguel
                        Thank you!
                        Well, the solution seems clear, never had a similar problem before
                        …till now didn’t even knew this could be an issue!
                        • fredo6F
                          fredo6
                          NEW RELEASE: LibFredo6 v6.1a - 21 Sep 14
                          LibFredo6 6.1a is a release mainly for VisuHole 1.0.
                          See main post of this thread for Download of LibFredo6.
                          Fredo
                          • halroachH
                            halroach
                            Fredo
                            Hi Fredo!
                            Visuhole Looks like an amazing plugin, though I can't find where to download the latest Libfredo from. The download button doesn't appear for me on: http://sketchucation.com/pluginstore?pln=LibFredo6
                            Nor on the sketchucaiton plugin store from within Sketchup.
                            Can't wait to try it out! 😄
                            FlexTools - Super Quick Windows, Doors, Slats...
                            • C
                              chris87
                              Fredo
                              Where is the download button ?
                              • fredo6F
                                fredo6
                                Chris,
                                Thanks for signaling. For whatever reasons, the attachment in the Plugin Store had disappeared. I put it back
                                Fredo
                                • OxerO
                                  Oxer
                                  New Spanish Language File
                                  Spanish Language LibFredo6 v6.1a
                                  http://www.oxervision.blogspot.com/
                                  • tinanneT
                                    tinanne
                                    I have tried to use the Sketchucation Plugin, download, install, copy paste the latest version but I keep getting errors. Any help on what I may be doing wrong?
                                    Executive Director : American Society of Architectural Illustrators
                                    AIP 30 Competition opens soon. ASAI.org
                                    Architectural Rendering
                                      Fredo, I have upgraded LibFredo6 via Plugin Store auto-install and installed VisuHole. Now when I start up SketchUp I get the following error.
                                      I also tried downloading the RBZ file and installing it with Install Extension. Same result.
                                      "You must install LibFredo6 version 5.2 or higher to run Fredo6_VisuHole"
                                      • fredo6F
                                        fredo6
                                        Could you be more precise on the error you get.
                                        Fredo
                                        • fredo6F
                                          fredo6
                                          Dave,
                                          Strange. I think you need to check the footprint to see if there is nothing wrong in the Plugins directory. You get this message if the LibFredo6 files cannot be found in the same directory as VisuHole.
                                          Fredo
                                          • tinanneT
                                            tinanne
                                            Fredo
                                            Thanks for the help!
                                            Error Loading File Fredo6_!LibFredo6.rb
                                            Error: #<ArgumentError: invalid byte sequence in UTF-8>
                                            C:/Users/Tina/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6.rb:206:in block (2 levels) in manage_compatibility' C:/Users/Tina/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6.rb:205:in foreach'
                                            C:/Users/Tina/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6.rb:205:in block in manage_compatibility' C:/Users/Tina/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6.rb:201:in each'
                                            C:/Users/Tina/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6.rb:201:in manage_compatibility' C:/Users/Tina/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6.rb:121:in startup'
                                            C:/Users/Tina/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6.rb:306:in <module:LibFredo6>' C:/Users/Tina/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6.rb:34:in <top (required)>'
                                            Error Loading File Fredo6_JointPushPull.rb
                                            Error: #<NameError: uninitialized constant Fredo6::Traductor>
                                            C:/Users/Tina/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_JointPushPull.rb:41:in <module:Fredo6>' C:/Users/Tina/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_JointPushPull.rb:25:in <top (required)>'
                                            Error Loading File Fredo6_RoundCorner.rb
                                            C:/Users/Tina/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_RoundCorner.rb:41:in <module:Fredo6>' C:/Users/Tina/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_RoundCorner.rb:25:in <top (required)>'
                                            Error Loading File Fredo6_ToolsOnSurface.rb
                                            C:/Users/Tina/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_ToolsOnSurface.rb:41:in <module:Fredo6>' C:/Users/Tina/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_ToolsOnSurface.rb:25:in <top (required)>'
                                            Error Loading File C:/Users/Tina/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/maxwell/init.rb
                                            Could not find included file 'C:/Users/Tina/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/maxwell/init.rb'
                                            Error Loading File C:/Users/Tina/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/su_grid/grid.rb
                                            Error: #<SyntaxError: C:/Users/Tina/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/su_grid/grid.rb:63: syntax error, unexpected ',', expecting =>
                                            defaults = {"dx", 8.feet, "dy", 8.feet, "nx", 4, "ny", 4}
                                            C:/Users/Tina/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/su_grid/grid.rb:63: syntax error, unexpected ',', expecting :: or '[' or '.'
                                            C:/Users/Tina/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/su_grid/grid.rb:63: syntax error, unexpected ',', expecting keyword_end
                                            C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/extensions.rb:197:in require' C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/extensions.rb:197:in load'
                                            C:/Users/Tina/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/su_grid.rb:36:in register_extension' C:/Users/Tina/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/su_grid.rb:36:in module:Grid'
                                            C:/Users/Tina/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/su_grid.rb:26:in <module:Samples>' C:/Users/Tina/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/su_grid.rb:25:in <top (required)>'
                                            • 39
                                            • 40
                                            • 41
                                            • 42
                                            • 43
                                            • 116
                                            • 117
                                            • 41 / 117
