    [Plugin Library] LibFredo6 - v16.1a - 31 Aug 26
    2.2k Posts 580 Posters 6.6m Views 582 Watching
    • fredo6F Offline
      NEW RELEASE: LibFredo6 v6.0b - 16 Jul 14
      LibFredo6 6.0b is a release for the support of Section Planes in:
      • DrawAlong,
      • MoveAlong,
        which are published as part of FredTools 2.0.
      Section Planes can now be moved and be used as a reference for inferencing
      See main post of this thread for Download of LibFredo6.
        Papapa
        Hey Fredo,
        Thanks for the great work you do with these plugins.
        But why do you make these pages so complicated to read? Everything looks like a link that you can click or something, and all kind of bullet lists don't help. I'm trying to look for the download link, which should be recognizable in the page, and I stumble all the time with words and titles and headers which are misleading. Couldn't you simplify it so it's easier to find things? It's missing a sort of hierarchy in the page in my opinion.
        Cheers
          @papapa said:
          Hey Fredo,
          Cheers
          Use the PluginStore !
          • fredo6F Offline
            Precisely, as TIG highlighted, you should use Sketchucation PluginStore, which is an addon script running within Sketchup. This is where you'll see the single "Install' button.
            The web page in the forum is primarily informative about the Plugin. It is organized in sections hoping users would read some of them prior to use the plugin and thus avoid common problems.
            • architexA Offline
              architex
              How do I install LibFredo 6 (new release.
              I have try to install with the skechucation toolbar.. Autoinstall don't do anything. I have to install all by .RBZ (for me is the only way to install any plugins)
              Any suggestions?
              • fredo6F Offline
                Any suggestions?
                Strange. SCF Plugin Store tools works on SU2013.
                Did you install some of my plugins along with LibFredo6?
                  matiu
                  i have libfredo 6 57 says i need 58 or higher where do i get higher version??
                    It is at v6.0b, and it is currently available in the PluginStore - learn to use it. it'll make you life a lot easier...
                      behnam123
                      thanks!!!!! From Iran
                      • Z Offline
                        zemane
                        sketchup 2014 says it can't find Fredo Library folder after I install it.
                          It must not be installed correctly. How and where did you install it?
                          • Z Offline
                            zemane
                            I used SU2014 extension warehouse. It allocates the folder under the correct path.. but SU doesn't see it. Why??
                            the folder is there, under appdata......plugins, with the default extensions, under the name of Fredo6_!LibFredo6 and Fredo6_!LibFredo6.rb
                            What should be wrong?
                              What is your Windows User-name?
                              Please post the results of this code in the Ruby Console:
                              It should return the paths to various folders...
                              If your user-name has accents in it, then it is a known issue that can block some Ruby ' File' operations.
                              This has greatly improved in v2014 Ruby2, but with accented characters there can still be some failures when using __FILE__, which itself sets the path to a loading .rb file and which is used to set relative-paths, but can be incorrectly encoded, if accented.
                              There is a clunky workaround used by some scripts [like the SketchUcation toolset] which sidesteps the issue by forcing the correct encoding in v2014 - but in earlier versions the problem can't be circumvented...
                              • Z Offline
                                zemane
                                yep.. that is the case.. my user name has accent : (
                                I though that might be the issue.. I'll try a work around.
                                • Z Offline
                                  ZeMiguel
                                  I have the exact same problem.
                                  I must ask! what kind of “work around” can solve this problem…without having to change the user name. Thanks!
                                    Sorry 😞
                                    Unfortunately there is no effective solution - except getting SketchUp v2014...
                                    What is stopping you using that - in parallel with earlier versions if you must...
                                    But why must you have an accent in your Windows user-name ?
                                    It is well know to cause issues with applications - like SketchUp < v2014 where the Ruby version cannot cope with the 'File' issues...
                                    Unfortunately simply renaming your Windows user-account still leaves residual linked in 'accented-name' folders etc...
                                    There is good guidance on the www on how to make another 'clean' user-name account and then copy over all of your current folders and files to that.
                                    Then once it is all working you can remove the accented-name account ???
                                    e.g. http://www.thewindowsclub.com/transfer-user-profile-in-windows
                                    • Z Offline
                                      ZeMiguel
                                      Thank you!
                                      Well, the solution seems clear, never had a similar problem before
                                      …till now didn’t even knew this could be an issue!
                                      • fredo6F Offline
                                        NEW RELEASE: LibFredo6 v6.1a - 21 Sep 14
                                        LibFredo6 6.1a is a release mainly for VisuHole 1.0.
                                        • halroachH Offline
                                          halroach
                                          Hi Fredo!
                                          Visuhole Looks like an amazing plugin, though I can't find where to download the latest Libfredo from. The download button doesn't appear for me on: http://sketchucation.com/pluginstore?pln=LibFredo6
                                          Nor on the sketchucaiton plugin store from within Sketchup.
                                          Can't wait to try it out! 😄
                                          FlexTools - Super Quick Windows, Doors, Slats...
                                            chris87
                                            Where is the download button ?
                                            • 39
                                            • 40
                                            • 41
                                            • 42
                                            • 43
                                            • 111
                                            • 112
                                            • 41 / 112
