    [Plugin Library] LibFredo6 - v16.2b - 22 Sep 26
    2.3k Posts 587 Posters 10.9m Views 589 Watching
    • OxerO
      Oxer
      New Spanish Language File.
      Spanish Language
        Stonecold
        Still not working on Sketchup 2014. Here is the error, what am I doing wrong?
        Error Loading File Fredo6_!LibFredo6.rb
        Error: #<LoadError: cannot load such file -- LibTraductor.rb>
        C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:45:in require' C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:45:in require'
        C:/Users/Username/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6.rb:29:in `<top (required)>'
        Hm... Renamed Lib6Traductor to LibTraductor and it worked somehow o.O
        • fredo6F
          NEW RELEASE: LibFredo6 v6.0b - 16 Jul 14
          LibFredo6 6.0b is a release for the support of Section Planes in:
          • DrawAlong,
          • MoveAlong,
            which are published as part of FredTools 2.0.
          Section Planes can now be moved and be used as a reference for inferencing
          See main post of this thread for Download of LibFredo6.
          • P
            Papapa
            Hey Fredo,
            Thanks for the great work you do with these plugins.
            But why do you make these pages so complicated to read? Everything looks like a link that you can click or something, and all kind of bullet lists don't help. I'm trying to look for the download link, which should be recognizable in the page, and I stumble all the time with words and titles and headers which are misleading. Couldn't you simplify it so it's easier to find things? It's missing a sort of hierarchy in the page in my opinion.
            Cheers
              @papapa said:
              Hey Fredo,
              Cheers
              Use the PluginStore !
              • fredo6F
                Precisely, as TIG highlighted, you should use Sketchucation PluginStore, which is an addon script running within Sketchup. This is where you'll see the single "Install' button.
                The web page in the forum is primarily informative about the Plugin. It is organized in sections hoping users would read some of them prior to use the plugin and thus avoid common problems.
                • architexA
                  architex
                  How do I install LibFredo 6 (new release.
                  I have try to install with the skechucation toolbar.. Autoinstall don't do anything. I have to install all by .RBZ (for me is the only way to install any plugins)
                  Any suggestions?
                  • fredo6F
                    Any suggestions?
                    Strange. SCF Plugin Store tools works on SU2013.
                    Did you install some of my plugins along with LibFredo6?
                      matiu
                      i have libfredo 6 57 says i need 58 or higher where do i get higher version??
                        It is at v6.0b, and it is currently available in the PluginStore - learn to use it. it'll make you life a lot easier...
                        • B
                          behnam123
                          thanks!!!!! From Iran
                          • Z
                            zemane
                            sketchup 2014 says it can't find Fredo Library folder after I install it.
                              It must not be installed correctly. How and where did you install it?
                              • Z
                                zemane
                                I used SU2014 extension warehouse. It allocates the folder under the correct path.. but SU doesn't see it. Why??
                                the folder is there, under appdata......plugins, with the default extensions, under the name of Fredo6_!LibFredo6 and Fredo6_!LibFredo6.rb
                                What should be wrong?
                                  What is your Windows User-name?
                                  Please post the results of this code in the Ruby Console:
                                  It should return the paths to various folders...
                                  If your user-name has accents in it, then it is a known issue that can block some Ruby ' File' operations.
                                  This has greatly improved in v2014 Ruby2, but with accented characters there can still be some failures when using __FILE__, which itself sets the path to a loading .rb file and which is used to set relative-paths, but can be incorrectly encoded, if accented.
                                  There is a clunky workaround used by some scripts [like the SketchUcation toolset] which sidesteps the issue by forcing the correct encoding in v2014 - but in earlier versions the problem can't be circumvented...
                                  • Z
                                    zemane
                                    yep.. that is the case.. my user name has accent : (
                                    I though that might be the issue.. I'll try a work around.
                                    • Z
                                      ZeMiguel
                                      I have the exact same problem.
                                      I must ask! what kind of “work around” can solve this problem…without having to change the user name. Thanks!
                                        Sorry 😞
                                        Unfortunately there is no effective solution - except getting SketchUp v2014...
                                        What is stopping you using that - in parallel with earlier versions if you must...
                                        But why must you have an accent in your Windows user-name ?
                                        It is well know to cause issues with applications - like SketchUp < v2014 where the Ruby version cannot cope with the 'File' issues...
                                        Unfortunately simply renaming your Windows user-account still leaves residual linked in 'accented-name' folders etc...
                                        There is good guidance on the www on how to make another 'clean' user-name account and then copy over all of your current folders and files to that.
                                        Then once it is all working you can remove the accented-name account ???
                                        e.g. http://www.thewindowsclub.com/transfer-user-profile-in-windows
                                        • Z
                                          ZeMiguel
                                          Thank you!
                                          Well, the solution seems clear, never had a similar problem before
                                          …till now didn’t even knew this could be an issue!
                                          • fredo6F
                                            NEW RELEASE: LibFredo6 v6.1a - 21 Sep 14
                                            LibFredo6 6.1a is a release mainly for VisuHole 1.0.
                                            • 39
                                            • 40
                                            • 41
                                            • 42
                                            • 43
                                            • 113
                                            • 114
                                            • 41 / 114
