    [Plugin Library] LibFredo6 - v16.2b - 22 Sep 26
    2.2k Posts 583 Posters 9.1m Views 585 Watching
    • Z
      ZeMiguel
      @zemane said:
      yep.. that is the case.. my user name has accent : (
      I though that might be the issue.. I'll try a work around.
      I have the exact same problem.
      I must ask! what kind of “work around” can solve this problem…without having to change the user name. Thanks!
        Sorry 😞
        Unfortunately there is no effective solution - except getting SketchUp v2014...
        What is stopping you using that - in parallel with earlier versions if you must...
        But why must you have an accent in your Windows user-name ?
        It is well know to cause issues with applications - like SketchUp < v2014 where the Ruby version cannot cope with the 'File' issues...
        Unfortunately simply renaming your Windows user-account still leaves residual linked in 'accented-name' folders etc...
        There is good guidance on the www on how to make another 'clean' user-name account and then copy over all of your current folders and files to that.
        Then once it is all working you can remove the accented-name account ???
        e.g. http://www.thewindowsclub.com/transfer-user-profile-in-windows
        • Z
          ZeMiguel
          Thank you!
          Well, the solution seems clear, never had a similar problem before
          …till now didn’t even knew this could be an issue!
          • fredo6F
            NEW RELEASE: LibFredo6 v6.1a - 21 Sep 14
            LibFredo6 6.1a is a release mainly for VisuHole 1.0.
            See main post of this thread for Download of LibFredo6.
            • halroachH
              halroach
              Hi Fredo!
              Visuhole Looks like an amazing plugin, though I can't find where to download the latest Libfredo from. The download button doesn't appear for me on: http://sketchucation.com/pluginstore?pln=LibFredo6
              Nor on the sketchucaiton plugin store from within Sketchup.
              Can't wait to try it out! 😄
              FlexTools - Super Quick Windows, Doors, Slats...
              • C
                chris87
                Where is the download button ?
                • fredo6F
                  Chris,
                  Thanks for signaling. For whatever reasons, the attachment in the Plugin Store had disappeared. I put it back
                  • OxerO
                    Oxer
                    New Spanish Language File
                    Spanish Language LibFredo6 v6.1a
                    • tinanneT
                      tinanne
                      I have tried to use the Sketchucation Plugin, download, install, copy paste the latest version but I keep getting errors. Any help on what I may be doing wrong?
                      Executive Director : American Society of Architectural Illustrators
                      AIP 30 Competition opens soon. ASAI.org
                      Architectural Rendering
                        Fredo, I have upgraded LibFredo6 via Plugin Store auto-install and installed VisuHole. Now when I start up SketchUp I get the following error.
                        I also tried downloading the RBZ file and installing it with Install Extension. Same result.
                        "You must install LibFredo6 version 5.2 or higher to run Fredo6_VisuHole"
                        • fredo6F
                          Could you be more precise on the error you get.
                          • fredo6F
                            Dave,
                            Strange. I think you need to check the footprint to see if there is nothing wrong in the Plugins directory. You get this message if the LibFredo6 files cannot be found in the same directory as VisuHole.
                            • tinanneT
                              tinanne
                              Thanks for the help!
                              Error Loading File Fredo6_!LibFredo6.rb
                              Error: #<ArgumentError: invalid byte sequence in UTF-8>
                              C:/Users/Tina/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6.rb:206:in block (2 levels) in manage_compatibility' C:/Users/Tina/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6.rb:205:in foreach'
                              C:/Users/Tina/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6.rb:205:in block in manage_compatibility' C:/Users/Tina/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6.rb:201:in each'
                              C:/Users/Tina/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6.rb:201:in manage_compatibility' C:/Users/Tina/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6.rb:121:in startup'
                              C:/Users/Tina/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6.rb:306:in <module:LibFredo6>' C:/Users/Tina/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6.rb:34:in <top (required)>'
                              Error Loading File Fredo6_JointPushPull.rb
                              Error: #<NameError: uninitialized constant Fredo6::Traductor>
                              C:/Users/Tina/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_JointPushPull.rb:41:in <module:Fredo6>' C:/Users/Tina/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_JointPushPull.rb:25:in <top (required)>'
                              Error Loading File Fredo6_RoundCorner.rb
                              C:/Users/Tina/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_RoundCorner.rb:41:in <module:Fredo6>' C:/Users/Tina/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_RoundCorner.rb:25:in <top (required)>'
                              Error Loading File Fredo6_ToolsOnSurface.rb
                              C:/Users/Tina/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_ToolsOnSurface.rb:41:in <module:Fredo6>' C:/Users/Tina/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_ToolsOnSurface.rb:25:in <top (required)>'
                              Error Loading File C:/Users/Tina/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/maxwell/init.rb
                              Could not find included file 'C:/Users/Tina/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/maxwell/init.rb'
                              Error Loading File C:/Users/Tina/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/su_grid/grid.rb
                              Error: #<SyntaxError: C:/Users/Tina/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/su_grid/grid.rb:63: syntax error, unexpected ',', expecting =>
                              defaults = {"dx", 8.feet, "dy", 8.feet, "nx", 4, "ny", 4}
                              C:/Users/Tina/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/su_grid/grid.rb:63: syntax error, unexpected ',', expecting :: or '[' or '.'
                              C:/Users/Tina/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/su_grid/grid.rb:63: syntax error, unexpected ',', expecting keyword_end
                              C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/extensions.rb:197:in require' C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/extensions.rb:197:in load'
                              C:/Users/Tina/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/su_grid.rb:36:in register_extension' C:/Users/Tina/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/su_grid.rb:36:in module:Grid'
                              C:/Users/Tina/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/su_grid.rb:26:in <module:Samples>' C:/Users/Tina/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/su_grid.rb:25:in <top (required)>'
                                I'll look into that Fredo but I don't see why it should get installed in a different directory either via the Pluginstore (which is pointing to ~/User/Library/.../SketchUp 2014/Plugins) or via Install Extension.
                                • fredo6F
                                  Tinanne
                                  You seem to have a version of Fredo6_!LibFredo6.rb which is not correct (as it is not correctly encoded).
                                  Strange, because many users should have this problem too.
                                  • fredo6F
                                    NEW RELEASE: LibFredo6 v6.1b - 22 Sep 14
                                    LibFredo6 6.1b is a release mainly for VisuHole 1.0.
                                    I republish it because there seems to be a problem with the encoding of the main rb file.
                                    • tinanneT
                                      tinanne
                                      @fredo6 said:
                                      Tinanne
                                      So what do I do from here? I used the Sketchucation plugin to install it and then tried the other types of installs.
                                      Thanks again for looking into it.
                                      • fredo6F
                                        Tianne,
                                        I have republish a version of LibFredo6 - 6.1b - in the PluginStore.
                                        Can you try it.
                                        • tinanneT
                                          tinanne
                                          @fredo6 said:
                                          Tianne,
                                          I republish a version LibFredo6 6.1b on PluginStore. Can you try it.
                                          I just installed from the plugin store and still getting this error...
                                          • fredo6F
                                            Tinanne,
                                            You must have an old version of some of my plugins, or some plugins that have their UTF encoding changed for whatever reason.
                                            Can you check
                                            • 39
                                            • 40
                                            • 41
                                            • 42
                                            • 43
                                            • 112
                                            • 113
                                            • 41 / 113
