    [Plugin Library] LibFredo6 - v16.1a - 31 Aug 26
    2.2k Posts 582 Posters 7.4m Views 584 Watching
    • fredo6F Offline
      NEW RELEASE: LibFredo6 v6.1a - 21 Sep 14
      LibFredo6 6.1a is a release mainly for VisuHole 1.0.
      See main post of this thread for Download of LibFredo6.
      • halroachH Offline
        halroach
        Hi Fredo!
        Visuhole Looks like an amazing plugin, though I can't find where to download the latest Libfredo from. The download button doesn't appear for me on: http://sketchucation.com/pluginstore?pln=LibFredo6
        Nor on the sketchucaiton plugin store from within Sketchup.
        Can't wait to try it out! 😄
        FlexTools - Super Quick Windows, Doors, Slats...
          chris87
          Where is the download button ?
          • fredo6F Offline
            Chris,
            Thanks for signaling. For whatever reasons, the attachment in the Plugin Store had disappeared. I put it back
            • OxerO Offline
              Oxer
              New Spanish Language File
              Spanish Language LibFredo6 v6.1a
              • tinanneT Offline
                tinanne
                I have tried to use the Sketchucation Plugin, download, install, copy paste the latest version but I keep getting errors. Any help on what I may be doing wrong?
                Executive Director : American Society of Architectural Illustrators
                AIP 30 Competition opens soon. ASAI.org
                Architectural Rendering
                  Fredo, I have upgraded LibFredo6 via Plugin Store auto-install and installed VisuHole. Now when I start up SketchUp I get the following error.
                  I also tried downloading the RBZ file and installing it with Install Extension. Same result.
                  "You must install LibFredo6 version 5.2 or higher to run Fredo6_VisuHole"
                  • fredo6F Offline
                    Could you be more precise on the error you get.
                    • fredo6F Offline
                      Dave,
                      Strange. I think you need to check the footprint to see if there is nothing wrong in the Plugins directory. You get this message if the LibFredo6 files cannot be found in the same directory as VisuHole.
                      • tinanneT Offline
                        tinanne
                        Thanks for the help!
                        Error Loading File Fredo6_!LibFredo6.rb
                        Error: #<ArgumentError: invalid byte sequence in UTF-8>
                        C:/Users/Tina/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6.rb:206:in block (2 levels) in manage_compatibility' C:/Users/Tina/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6.rb:205:in foreach'
                        C:/Users/Tina/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6.rb:205:in block in manage_compatibility' C:/Users/Tina/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6.rb:201:in each'
                        C:/Users/Tina/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6.rb:201:in manage_compatibility' C:/Users/Tina/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6.rb:121:in startup'
                        C:/Users/Tina/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6.rb:306:in <module:LibFredo6>' C:/Users/Tina/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6.rb:34:in <top (required)>'
                        Error Loading File Fredo6_JointPushPull.rb
                        Error: #<NameError: uninitialized constant Fredo6::Traductor>
                        C:/Users/Tina/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_JointPushPull.rb:41:in <module:Fredo6>' C:/Users/Tina/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_JointPushPull.rb:25:in <top (required)>'
                        Error Loading File Fredo6_RoundCorner.rb
                        C:/Users/Tina/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_RoundCorner.rb:41:in <module:Fredo6>' C:/Users/Tina/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_RoundCorner.rb:25:in <top (required)>'
                        Error Loading File Fredo6_ToolsOnSurface.rb
                        C:/Users/Tina/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_ToolsOnSurface.rb:41:in <module:Fredo6>' C:/Users/Tina/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_ToolsOnSurface.rb:25:in <top (required)>'
                        Error Loading File C:/Users/Tina/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/maxwell/init.rb
                        Could not find included file 'C:/Users/Tina/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/maxwell/init.rb'
                        Error Loading File C:/Users/Tina/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/su_grid/grid.rb
                        Error: #<SyntaxError: C:/Users/Tina/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/su_grid/grid.rb:63: syntax error, unexpected ',', expecting =>
                        defaults = {"dx", 8.feet, "dy", 8.feet, "nx", 4, "ny", 4}
                        C:/Users/Tina/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/su_grid/grid.rb:63: syntax error, unexpected ',', expecting :: or '[' or '.'
                        C:/Users/Tina/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/su_grid/grid.rb:63: syntax error, unexpected ',', expecting keyword_end
                        C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/extensions.rb:197:in require' C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/extensions.rb:197:in load'
                        C:/Users/Tina/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/su_grid.rb:36:in register_extension' C:/Users/Tina/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/su_grid.rb:36:in module:Grid'
                        C:/Users/Tina/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/su_grid.rb:26:in <module:Samples>' C:/Users/Tina/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/su_grid.rb:25:in <top (required)>'
                          I'll look into that Fredo but I don't see why it should get installed in a different directory either via the Pluginstore (which is pointing to ~/User/Library/.../SketchUp 2014/Plugins) or via Install Extension.
                          • fredo6F Offline
                            Tinanne
                            You seem to have a version of Fredo6_!LibFredo6.rb which is not correct (as it is not correctly encoded).
                            Strange, because many users should have this problem too.
                            • fredo6F Offline
                              NEW RELEASE: LibFredo6 v6.1b - 22 Sep 14
                              LibFredo6 6.1b is a release mainly for VisuHole 1.0.
                              I republish it because there seems to be a problem with the encoding of the main rb file.
                              • tinanneT Offline
                                tinanne
                                @fredo6 said:
                                Tinanne
                                So what do I do from here? I used the Sketchucation plugin to install it and then tried the other types of installs.
                                Thanks again for looking into it.
                                • fredo6F Offline
                                  Tianne,
                                  I have republish a version of LibFredo6 - 6.1b - in the PluginStore.
                                  Can you try it.
                                  • tinanneT Offline
                                    tinanne
                                    @fredo6 said:
                                    Tianne,
                                    I republish a version LibFredo6 6.1b on PluginStore. Can you try it.
                                    I just installed from the plugin store and still getting this error...
                                    • fredo6F Offline
                                      Tinanne,
                                      You must have an old version of some of my plugins, or some plugins that have their UTF encoding changed for whatever reason.
                                      Can you check
                                      • tinanneT Offline
                                        tinanne
                                        I'm sorry to be such a pain! I've uninstalled all the Fredo6 plugins and reinstalled using the plugin store and now I get this error.
                                        • fredo6F Offline
                                          At least you seem to have no problem with my scripts.
                                          Try to remove the su_grid plugin which seems faulty
                                          • tinanneT Offline
                                            tinanne
                                            A ha! Finally! No more errors. Thank you!
                                            • 39
                                            • 40
                                            • 41
                                            • 42
                                            • 43
                                            • 111
                                            • 112
                                            • 41 / 112
