    The "Duh!" thread (aka the Doh! thread)
    696 Posts 135 Posters 652.1k Views 135 Watching
      ๐Ÿ˜ณ ๐Ÿ˜ณ ๐Ÿ˜ณ Expand revelation! โ˜€
      I had always believed that was reserved to Mac users to have pile of windows like that! ๐Ÿ˜ฎ
      So never try to click on the blue title and have full windows if needed
      by Right Click on the object or moving from the Menu! ๐Ÿ˜’
      • andybotA
        andybot
        Yay! I came upon a huge doh moment, thanks to Taff (he who "makes you think") from this recent thread which sent me to this thread which links to a sketchup sage article
        and long story short, I found that by holding down the "primary mouse button" while using the rotate (protractor) tool, it will inference to the perpendicular of a line. Simply Brilliant!! I've always wondered how to rotate about an axis without constructing a bunch of lines and faces ๐Ÿ˜•
        • TaffGochT
          TaffGoch
          @andybot said:
          Yay! I came upon a huge doh moment, thanks to Taff ...
          ...and long story short, I found that by holding down the "primary mouse button" while using the rotate (protractor) tool, it will inference to the perpendicular of a line. Simply Brilliant!! I've always wondered how to rotate about an axis without constructing a bunch of lines and faces ๐Ÿ˜•
          My primary tip, for any beginning (and, it seems, experienced) SketchUp user!
          -Taff
          "Information is not knowledge." -- Albert Einstein
          • andybotA
            andybot
            -Taff
            Well, this is certainly an example of the dangers of "self-taught" ๐Ÿ˜† One can tend to skip over some basic stuff every now and then...
            • jeff hammondJ
              jeff hammond
              [fwiw- it will also let you orient the protractor to a major axis without orbiting the view etc.. fwiw2.. sort of an ongoing request by people to give this functionality to the circle tool]
              dotdotdot
              • jgbJ
                jgb
                Well shiver me boots. I often need to construct a face/shape/line perpendicular to a non-axis aligned line, and went through all sorts of temp construction to do it. even resorted to "Pipe-along-path" for some.
                So now, for those who may not see the power in this "duh" moment, is how in just a few mouse clicks, make a face perpendicular to any line orientation. ๐Ÿ˜ฎ
                Put the PROTRACTOR tool somewhere on, or even at the endpoint of the line and hold down the primary mouse button. When the protractor aligns with the perp to that line, release the button, select any angle, click and select any angle away, say 90 deg and click again. Now you have 1 guide line perpendicular to the line at some random angle.
                Do this again, but put the protractor ON the intersection of the guide and your line, and set another guide line at some angle away from the first guide line, say 90 deg away.
                You now have 2 guide lines perp to your line. ๐Ÿ˜„
                Pencil tool 4 lines from any point on each guide, and a face will form that is perpendicular to the line. ๐Ÿค“
                Use that face as your construction canvas. Bonus, the face is NOT intersected to the line so the whole line is still intact, until you intersect them. ๐Ÿค“
                jgb
                • R
                  rv1974
                  One can assign shortcuts to the 'Numpad' keys! ๐Ÿ˜ฎ
                  A huge gain, especially for lefties.
                  Doh!
                  • A
                    ArCAD-UK
                    Just discovered in Layout 3 that if you select a block of text and right click (PC) there is a "Size to Fit" option which retains the text block width but extends the box height to show all the text. The amount of time I've spent manually adjusting my text boxes when the contents have been edited... ๐Ÿ˜ณ
                    • R
                      rv1974
                      The 'Lock\unlock aspect ratio' at material edit drove me crazy for years.
                      Clicking it wont change visually its state (stupid bug!). To see it changed one should move
                      the cursor off the button.
                      • I
                        iecovert
                        %(#400080)[ALL toolbars can be mounted on the top OR the side! Not just the SU tools.
                        I've got an increasing number of toolbars mounted up top since that's the way they first show up when a plugin is installed. The decreasing workspace was becoming an issue. The original SU toolbars mount vertically, so I set out to figure out how I could make the new Ruby and plugin toolbars mount vertically too. That seems to make more sense with a widescreen monitor. Spent several hours searching through the forums, help topics, and eventually digging into various Ruby scripts trying to figure it out over the past two weeks. Then last night I was moving a floating toolbar window and grabbed it a little to close to the edge and... it "stretched" out vertically. ๐Ÿคฃ Finally...]
                        • A
                          Aerilius
                          (This belongs probably also into the developers forums:)
                          window.onerror = function(errorMsg, url, lineNumber){ return true }
                          This catches WebDialog script error popups (should they still sometimes occur after thorough testing)!
                          Why didn't I find that before?
                          Note: It needs to be assigned directly to %(#000000)[window] and not attached like %(#000000)[$(window).bind("error", function(){})].
                          • GaieusG
                            Interesting. I do not have that "duh moment" reading this. ๐Ÿ˜†
                            • jeff hammondJ
                              jeff hammond
                              same hereโ€ฆ more like an "uhhhhh ๐Ÿ˜• moment"
                              ๐Ÿ˜†
                              dotdotdot
                              • kenK
                                ken
                                I guess I could call this "The Well I'll be Darn Thread". I have used Sketchup since V 4. And I know that the text tool will give me info on geometry. Like length, area, but today, surprise, I used the text tool on the apex of an angle and I got the following, the degrees of the angle in the text box. Never saw that before, and I would have an illustration to show you if I could get the text tool to do it again.
                                Ken
                                • GaieusG
                                  I was reading a topic and realized that I did not understand a word.
                                  Then looked up and also realized I was in the Developers Forum. ๐Ÿ˜’
                                  • thomthomT
                                    0101011101101000011000010111010000101100001000000111100101101111011101010010000001100100011011110010000001101110011011110111010000100000011101010110111001100100011001010111001001110011011101000110000101101110011001000010000001100010011010010110111001100001011100100111100100111111
                                    • TIGT
                                      Didn't you mean
                                      010110010110111101110101001000000110010001101111001000000110111001101111011101000010000001110101011011100110010001100101011100100111001101110100011000010110111001100100001000000110001001101001011011100110000101110010011110010010000000100001
                                      ๐Ÿ˜• ๐Ÿ˜‰
                                        01101000 01101111 01110111 00100000 01110010 01110101 01100100 01100101 00100001
                                        • TIGT
                                          It wasn't... but
                                          0100011001100101011000110110101100100000011010010111001100100000011100100111010101100100011001010010000000100001
                                          • M
                                            mrossk
                                            I think I got geek all over me ๐Ÿ˜‰
                                            https://www.mkaplanfinefurniture.com/
                                            • 18
                                            • 19
                                            • 20
                                            • 21
                                            • 22
                                            • 34
                                            • 35
                                            • 20 / 35
