    [Plugin] FollowMe and keep (v0.04 update 20090210)
    223 Posts 79 Posters 179.9k Views 79 Watching
      ciudadanochano
      Hey!! I have a very stupid question...How can I download this plugin? I´m serching everywhere, but I can´t find the way. Thanks!!
        Hi Chano,
        Plugins published on these forums are generally attached at the bottom of the very first post in their respective topics - in this case, download/install FAK.rb (or extract it from the FAK.rar archive also attached).
        • K Offline
          kienho
          Thank you Wikii! Your plugin helps me alot in modeling.
            Tim Danaher
            Is FMAK supposed to smooth the result automatically?
            I can't get this one to smooth -- the resulting sweep is nice, though...
            FMAK_Profile.skp
            Cheers,
            Tim
            http://vizarch.blogspot.com
            • jeff hammondJ Offline
              jeff hammond
              @rainfrog said:
              Basically, I want a profile to follow a path much like in the FollowMe and keep plugin, but in a way that preserves the proportions of the profile perpendicular to the path, whether that path is level or on a slope.
              hey rainfrog,
              that's possible using the extrude along path tool in the 1001bit suite
              http://www.1001bit.com/
              followmeproblem_fixed.skp
              dotdotdot
              • X Offline
                xrok1
                the native follow me tool works this way???? did you try it?
                “There are three classes of people: those who see. Those who see when they are shown. Those who do not see.”
                  You can use also the TIG Extrude Edges by Rails by Face 😉
                  and maybe 2 faces + Path by Kirill2008
                    jeff hammond
                    they won't keep the bottom flat though.. i'm pretty sure 1001bit is the only ruby solution for this particular scenario.
                    dotdotdot
                    • X Offline
                      xrok1
                      i downloaded his file and to me 1001bit and native follow me are identical, except 1001 triangulates. 😕
                        FollowMeAndKeep?
                        • X Offline
                          xrok1
                          FollowMeAndKeep?
                          FAK "squashes" the profile going up hill because it doesn't rotate.
                            Tim Danaher
                            I'm not having much luck with this at all...
                            Trying to sweep a spiral stair rail. I've got the path running smack through the midpoint of the balusters, and the profile lined up as centrally as possible, but the resulting handrail is never on the path.
                            The original path & Profile are in one group in the attached .skp, the resulting sweep in another...
                            Anyone point me to where I'm going wrong?
                            Ta,
                            Spiral Stairs_Baluster.skp
                            Cheers,
                            Tim
                              jeff hammond
                              check this comparison..
                              fm_vs_1001.skp
                              [edit] oh, regarding the 1001bit triangulation.. i run the deletecoplanaredges ruby on it afterwards.. found here..
                              http://www.cad-addict.com/2009/07/sketchup-plugins-delete-coplanar-edges.html
                              dotdotdot
                                jeff hammond
                                Ta,
                                i really don't know what's going on there Tim and i don't have FAK.rb installed anymore but i tried it with the 1001bit extrude and it worked out..
                                that said, we're talking a $30 tool set vs. a free plugin so...
                                TD_baluster.skp
                                dotdotdot
                                  Tim Danaher
                                  Ta,
                                  [attachment=0:afd99swm]<!-- ia0 -->TD_baluster.skp<!-- ia0 -->[/attachment:afd99swm]
                                  Thanks, Jeff -- Nice result... will have to pony up the dosh, then... 😮
                                  Cheers,
                                  Tim
                                  • X Offline
                                    xrok1
                                    Ta,
                                    [attachment=0:1ls3nueo]<!-- ia0 -->TD_baluster.skp<!-- ia0 -->[/attachment:1ls3nueo]
                                    thanks for clearing that up Jeff. i hadn't noticed that detail. i thought he was refering to the height difference on the slopes. 😳
                                      Tim Danaher
                                      [attachment=0:3ewotani]<!-- ia0 -->TD_baluster.skp<!-- ia0 -->[/attachment:3ewotani]
                                      Hah! No I won't... the developers have made it free for academic use, and since I teach SU at a design school...
                                      Cheers,
                                      Tim
                                        a $30 tool
                                        It's free if you use it for personnal use 😎
                                        You will have just a starting message 😉
                                        • X Offline
                                          xrok1
                                          it says 30 day trial period on mine?
                                            rainfrog
                                            Jeff, thanks for alerting me to the continued discussion here, regarding the problem I had a few months back! And also for demonstrating the different results between the original follow me and the 1001bit tool. It is nice to see that there is indeed a plugin out there that performs the exact function I was looking for. Very helpful! 👍
                                            • 6
                                            • 7
                                            • 8
                                            • 11
                                            • 12
                                            • 6 / 12
