    [Plugin] FollowMe and keep (v0.04 update 20090210)
    223 Posts 79 Posters 182.0k Views 79 Watching
      Aroundthebend
      @box said:
      You might have more luck with ...
      Follow me Helix
      http://sketchucation.com/forums/viewtopic.php?p=353956
      or Helix along curve
      http://sketchucation.com/forums/viewtopic.php?t=51770
      Thanks for the quick reply Box.
      I used Helix along curve to create the Helix. I'm having trouble creating the 'Spiral Guard'. I've drawn a profile (cross section of the 'Spiral Guard') but I can't get it to follow the Helix the way I would like Using FMK or SUs Follow Me tool. I'll have a look at Follow me Helix
        callinas
        Hi, have installed the plug-in and worked fine. Today i m trying to use the tool, but simply dont work. What may i do ?
        • cottyC Offline
          cotty
          You may upload an image or the model...
          my SketchUp gallery
            tailgater
            Is it in your plugins folder? Are you using an updated version of SketchUp?
            I somehow find out how I solved mine.
            If your problem is same as mine, open your FAK.rb and paste this line of code on the very top line:
            require 'sketchup.rb'
            Save it, then make sure the rb file is in the tools folder and not in the plugins folder.
              terrylewis
              Incredible!
              Thank you! Why don't you distribute this through sketchup and sign it? It is very nice work and it would make it easier for the user.
              • I Offline
                idcampza
                πŸ‘ πŸ‘ πŸ‘ πŸ‘ πŸ‘ gggg
                  ricdach
                  Do you have an English version?
                    This is a really old plugin, it's encrypted and terribly out of date !
                    Also it ships in its RBZ in two versions - the EN one is actually in Chinese and always fails, the other file [CN?] is actually in ENglish and works !
                    There are instructions in earlier posts on how to fix this...
                    In any case it may well prove flaky in newer versions of SketchUp, but you can try it and see...
                      JohnMTB
                      Wikii,
                      I can see the extension in my Extension Manager, but it shows up as, β€˜Blocked’. If I click on the arrow, I am advised that it is unsigned.
                      What do I do please?
                      johnmtb
                      • jujuJ Offline
                        juju
                        @johnmtb said:
                        Wikii,
                        johnmtb
                        unsigned isn't a problem the extension will work just fine, just relax your extension loading policies
                          JohnMTB
                          juju,
                          I have done as you suggest and it is now in the Extension Manager as enabled.
                          It also appears as FollowMeAndKeep, under Extensions, but I do not see it in the Toolbars, so how do I get it onto the main screen?
                          johnmtb
                            Read the tool's usage notes.
                            Many Extensions don't appear under the Extensions menu !
                            Some appear elsewhere - e.g. for Fredo's tools are under:
                            Tools > Fredo Collection OR Fredo Tools...
                            The Toolbars are activated separately...
                            To use Extensions/Plugins effectively you must read their usage notes...
                            So don't even have menu items - e.g SectionCutFace which is a context-menu tool only available when there's a selection of a single Section-Plane...
                              JohnMTB
                              TIG,
                              where do I find the usage notes?
                              johnmtb
                                The '[More ]Info' button when considering downloading/installing etc is a good starting point, but also read the main thread's posts for each tool - there are often good tips and advice in those...
                                  JohnMTB
                                  TIG,
                                  It was from clicking on the, β€˜More Info’, that I got to this forum. And, I have read all of the posts but found nothing that would help me.
                                  Also, as I mentioned earlier, on the menu line, under Extensions, I have FollowMeAndKeep and Mirror Selection. Mirror Selection works, but FollowMeAndKeep does nothing.
                                  Any ideas?
                                  johnmtb
                                    The FaK instructions are in the first post: https://sketchucation.com/forums/viewtopic.php?p=129504#p129504
                                    There's also some discussion in subsequent posts...
                                    It is old and unsupported for many years, so it's unsigned - set your Extension Manager > Extensions Loading Policy to 'Unrestricted' and restart SketchUp to see the menu-item if needed...
                                    There's no Toolbar...
                                    It appears under the Plugins menu - which is now known as 'Extensions' in newer SketchUp versions...
                                    put simply, preselect a path and a face and run the tool, it should extrude OK...
                                    Run it with the Ruby Console open to see if there are any issues...
                                      JohnMTB
                                      TIG,
                                      In the Extension Manager, FAK is there and it is marked as Enabled.
                                      As I mentioned previously, under Extensions, I have FollowMeAndKeep and Mirror Selection. Mirror Selection works, but FollowMeAndKeep does nothing. However, when I downloaded FAK.skp, at the beginning of this forum, and clicked on FollowMeAndKeep it worked; why?
                                      Unfortunately, I am very new to SketchUp and I do not know what you mean by, β€˜Run it with the Ruby Console open to see if there are any issues.’ Where do I find the Ruby Console?
                                      johnmtb
                                        Menu Window / Ruby Console πŸ˜‰ (till 2017... i suppose that is the same for new versions)
                                        Sorry in French but ... πŸ˜„
                                          JohnMTB
                                          Pilou,
                                          Thank you for that information.
                                          TIG,
                                          The Ruby Console was blank when I used FollowMeAndKeep but when I used Mirror the console was populated with information.
                                          johnmtb
                                            Please copy/paste those messages from the Ruby Console, explaining which tool was being used...
                                            My Mirror should not produce any error-messages in the RC...
                                            Sometimes the FAK tool can produce error messages - usually around 'zero-length' vectors when the path is overly complex...
                                            Perhaps conflating these two tools is confusing ?
                                            • 8
                                            • 9
                                            • 10
                                            • 11
                                            • 12
                                            • 11 / 12
