    [Plugin] FollowMe and keep (v0.04 update 20090210)
    223 Posts 79 Posters 224.0k Views 79 Watching
    • mitcorbM
      mitcorb
      It's OK, rainfrog:
      I am just glad I was able to assist.
      By the way, when I looked at the replica I did, at first it had a bounding box like a group. I clicked somewhere and the box disappeared. I could not retrieve the group, but the model remained. Also, I noticed that a line segment was bridging one of the bends, like it did not get bent by the plugin, even though I selected the whole thing before bending.
      • jarynzlesaJ
        jarynzlesa
        works perfectly, thank you - good work 👍
        http://www.vizualizaceschodiste.mypage.cz/
        • C
          ciudadanochano
          Hey!! I have a very stupid question...How can I download this plugin? I´m serching everywhere, but I can´t find the way. Thanks!!
          • GaieusG
            Hi Chano,
            Plugins published on these forums are generally attached at the bottom of the very first post in their respective topics - in this case, download/install FAK.rb (or extract it from the FAK.rar archive also attached).
            • K
              kienho
              Thank you Wikii! Your plugin helps me alot in modeling.
              • Tim DanaherT
                Tim Danaher
                Is FMAK supposed to smooth the result automatically?
                I can't get this one to smooth -- the resulting sweep is nice, though...
                FMAK_Profile.skp
                Cheers,
                Tim
                http://vizarch.blogspot.com
                • jeff hammondJ
                  @rainfrog said:
                  Basically, I want a profile to follow a path much like in the FollowMe and keep plugin, but in a way that preserves the proportions of the profile perpendicular to the path, whether that path is level or on a slope.
                  hey rainfrog,
                  that's possible using the extrude along path tool in the 1001bit suite
                  http://www.1001bit.com/
                  followmeproblem_fixed.skp
                  • X
                    xrok1
                    the native follow me tool works this way???? did you try it?
                      You can use also the TIG Extrude Edges by Rails by Face 😉
                      and maybe 2 faces + Path by Kirill2008
                      • jeff hammondJ
                        they won't keep the bottom flat though.. i'm pretty sure 1001bit is the only ruby solution for this particular scenario.
                        • X
                          xrok1
                          i downloaded his file and to me 1001bit and native follow me are identical, except 1001 triangulates. 😕
                            FollowMeAndKeep?
                            • X
                              xrok1
                              FollowMeAndKeep?
                              FAK "squashes" the profile going up hill because it doesn't rotate.
                              • Tim DanaherT
                                Tim Danaher
                                I'm not having much luck with this at all...
                                Trying to sweep a spiral stair rail. I've got the path running smack through the midpoint of the balusters, and the profile lined up as centrally as possible, but the resulting handrail is never on the path.
                                The original path & Profile are in one group in the attached .skp, the resulting sweep in another...
                                Anyone point me to where I'm going wrong?
                                Ta,
                                Spiral Stairs_Baluster.skp
                                Cheers,
                                Tim
                                • jeff hammondJ
                                  check this comparison..
                                  fm_vs_1001.skp
                                  [edit] oh, regarding the 1001bit triangulation.. i run the deletecoplanaredges ruby on it afterwards.. found here..
                                  http://www.cad-addict.com/2009/07/sketchup-plugins-delete-coplanar-edges.html
                                  • jeff hammondJ
                                    Ta,
                                    i really don't know what's going on there Tim and i don't have FAK.rb installed anymore but i tried it with the 1001bit extrude and it worked out..
                                    that said, we're talking a $30 tool set vs. a free plugin so...
                                    TD_baluster.skp
                                    • Tim DanaherT
                                      Tim Danaher
                                      Ta,
                                      [attachment=0:afd99swm]<!-- ia0 -->TD_baluster.skp<!-- ia0 -->[/attachment:afd99swm]
                                      Thanks, Jeff -- Nice result... will have to pony up the dosh, then... 😮
                                      Cheers,
                                      Tim
                                      • X
                                        xrok1
                                        Ta,
                                        [attachment=0:1ls3nueo]<!-- ia0 -->TD_baluster.skp<!-- ia0 -->[/attachment:1ls3nueo]
                                        thanks for clearing that up Jeff. i hadn't noticed that detail. i thought he was refering to the height difference on the slopes. 😳
                                        • Tim DanaherT
                                          Tim Danaher
                                          [attachment=0:3ewotani]<!-- ia0 -->TD_baluster.skp<!-- ia0 -->[/attachment:3ewotani]
                                          Hah! No I won't... the developers have made it free for academic use, and since I teach SU at a design school...
                                          Cheers,
                                          Tim
                                            a $30 tool
                                            It's free if you use it for personnal use 😎
                                            You will have just a starting message 😉
                                            • 11
                                            • 12
                                            • 6 / 12
