    [Plugin] FollowMe and keep (v0.04 update 20090210)
    223 Posts 79 Posters 224.0k Views 79 Watching
    • jeff hammondJ
      You can use also the TIG Extrude Edges by Rails by Face ๐Ÿ˜‰
      and maybe 2 faces + Path by Kirill2008
      they won't keep the bottom flat though.. i'm pretty sure 1001bit is the only ruby solution for this particular scenario.
      • X
        xrok1
        i downloaded his file and to me 1001bit and native follow me are identical, except 1001 triangulates. ๐Ÿ˜•
        โ€œThere are three classes of people: those who see. Those who see when they are shown. Those who do not see.โ€
          FollowMeAndKeep?
          • X
            xrok1
            FollowMeAndKeep?
            FAK "squashes" the profile going up hill because it doesn't rotate.
            • Tim DanaherT
              Tim Danaher
              I'm not having much luck with this at all...
              Trying to sweep a spiral stair rail. I've got the path running smack through the midpoint of the balusters, and the profile lined up as centrally as possible, but the resulting handrail is never on the path.
              The original path & Profile are in one group in the attached .skp, the resulting sweep in another...
              Anyone point me to where I'm going wrong?
              Ta,
              Spiral Stairs_Baluster.skp
              Cheers,
              Tim
              http://vizarch.blogspot.com
              • jeff hammondJ
                check this comparison..
                fm_vs_1001.skp
                [edit] oh, regarding the 1001bit triangulation.. i run the deletecoplanaredges ruby on it afterwards.. found here..
                http://www.cad-addict.com/2009/07/sketchup-plugins-delete-coplanar-edges.html
                • jeff hammondJ
                  Ta,
                  i really don't know what's going on there Tim and i don't have FAK.rb installed anymore but i tried it with the 1001bit extrude and it worked out..
                  that said, we're talking a $30 tool set vs. a free plugin so...
                  TD_baluster.skp
                  • Tim DanaherT
                    Tim Danaher
                    Ta,
                    [attachment=0:afd99swm]<!-- ia0 -->TD_baluster.skp<!-- ia0 -->[/attachment:afd99swm]
                    Thanks, Jeff -- Nice result... will have to pony up the dosh, then... ๐Ÿ˜ฎ
                    Cheers,
                    Tim
                    • X
                      xrok1
                      Ta,
                      [attachment=0:1ls3nueo]<!-- ia0 -->TD_baluster.skp<!-- ia0 -->[/attachment:1ls3nueo]
                      thanks for clearing that up Jeff. i hadn't noticed that detail. i thought he was refering to the height difference on the slopes. ๐Ÿ˜ณ
                      • Tim DanaherT
                        Tim Danaher
                        [attachment=0:3ewotani]<!-- ia0 -->TD_baluster.skp<!-- ia0 -->[/attachment:3ewotani]
                        Hah! No I won't... the developers have made it free for academic use, and since I teach SU at a design school...
                        Cheers,
                        Tim
                          a $30 tool
                          It's free if you use it for personnal use ๐Ÿ˜Ž
                          You will have just a starting message ๐Ÿ˜‰
                          • X
                            xrok1
                            it says 30 day trial period on mine?
                              rainfrog
                              Jeff, thanks for alerting me to the continued discussion here, regarding the problem I had a few months back! And also for demonstrating the different results between the original follow me and the 1001bit tool. It is nice to see that there is indeed a plugin out there that performs the exact function I was looking for. Very helpful! ๐Ÿ‘
                              • B
                                BERNS
                                THIS IS AN EXCELENT PLUGIN FOR TOPOGRAPHY AND MANY OTHER THEMES! I SAVED UP ALMOST 95% OF TIME AND WORK.
                                • L
                                  lightburn
                                  thanks for this wonderful plugin. this just saved me a hell lot of headaches.
                                  • B
                                    Blomman
                                    A really useful plugin. It helped me with creating a highway interchange.
                                    But what if I want to paint the created shape in more than just one color? Since I'm using this plugin to create a road ramp I really want to be able to paint the sides in different colors and textures. As it is now I can't since all the sides of the thing are treated as one. If I click on the left side for example, the right, top and bottom also gets highlighted. Is there anyway to solve this?
                                    By the way, I'm using this plugin together with the bezier curves plugin by Fredo 6 if that matters.
                                    • mitcorbM
                                      mitcorb
                                      @Blomman:
                                      I am not sure if this is valid, but is the resulting model a group or component? If so, could you right click on this, Edit Group, or Edit Component, and then apply colors, materials, textures to the various faces?
                                      Save first, then try the above. Undo(Control Z)if this does not get the desired results.
                                      Keep watching this thread for other replies.
                                      • B
                                        Blomman
                                        Yes, the model is automatically turned into a group which, as far as I know, can not have multiple textures or colors applied to. I forgot to mention that I've already done what you suggested (edit group) which is were I noticed the problem I described in my previous post. I've also tried "explode" but with the same result. ๐Ÿ˜
                                          Has the model, during the FMAK process, had it's edges smoothened?
                                          Have you hidden geometry on or off?
                                          If it's off, just turn it on and paint the faces. Or right click the entity and choose soften/smooth and lower the slider bar until the lines appear. You can use Ctrl+E to soften any lines that you don't want to see.
                                          I could be way off the mark ๐Ÿ˜•
                                          • B
                                            Blomman
                                            The hidden geometry was indeed off, now it works perfectly. Thanks! ๐Ÿ˜„
                                            • 11
                                            • 12
                                            • 6 / 12
