    [Plugin] FollowMe and keep (v0.04 update 20090210)
    223 Posts 79 Posters 214.6k Views 79 Watching
    • G Offline
      gata
      Dave, you need to add a contruction point at the end of the path. Select all faces, path and point and run script. There are at least 2 scripts which which let you add a construction point - AddVertex+.rb and add_construction_point.rb.
      And to model a loop-de-loop, you need to do the loop part separate. Make a helix from one of the helix scripts. Rotate a copy of your rail faces 90° and position it at the end of the helix path. Don't forget to add a construction point. Then rotate the new extrusion to the correct orientation.
      hebrides, rar is a zip file used in many parts of the world. The stuff you want is inside. Get 7-zip.
      Wikii, a progress bar would be a nice addition. For now I can tell the script is running by how my cursor looks and a slight flicker in a menu bar.
      • E Offline
        Ecuadorian
        I used it to make the wall, with the profile you see in red.
        I then "pathcopied" a component and used booltools to make the battlements.
        -Miguel Lescano
        • X Offline
          xrok1
          ahhh... yes, it was the cutouts i was wondering about.
          thanks
          “There are three classes of people: those who see. Those who see when they are shown. Those who do not see.”
            Seems miss the "little holes" 😉
            • E Offline
              Ecuadorian
              Yup... I was lazy 😉 I'll try it with "little holes" tomorrow.
              -Miguel Lescano
                Slimdog
                Hello all. I am new to the forum and have been reading back through the old posts and learning a lot. I have only been on sketchup for a few months but have a couple of years on AutoCad.
                I have been trying to get the follow me and keep plugin to work but cant figure it out. I have installed a few plugins before with no problem. I just down load the rb. file and chuck it in the plugin folder. The thing I dont get is that in the very first post by Wikii there is a skp. file and a rar. file. I have down loaded them both. With the FAK.skp file I follow the words saying to highlight all and then run the plugin except there is no follow me in my plugins menu.
                Not sure what to do next. Is there an rb. file some where in the skp. file?
                -S
                ps I am on a mac
                  Slimdog
                  Thanks for posting rb. file Pilou. I tried it and works great. Thanks also to Wikii.
                  -S
                    Have you seen inside Menu Tools? 😉
                    Edit: No Sorry! it's because I had put it in this Menu Tools, normally it's inside Menu Plugins! 😳
                    PS You must "unzip" the file Rar!!! If you have not such unrar prog I had linked the file unzipped 😉
                    Hope this help 😄 By Wikii
                    FAK.rb
                    • david_hD Offline
                      david_h
                      I must be doing something wrong. It doesnt seem to go for me. I am trying to test a shape around a helix form. I select all, select FAK and . . .nothing. In fact I get a Splat.
                      Any ideas? ❓
                      • mitcorbM Offline
                        mitcorb
                        It is not working for me either. I downloaded the later FAK.rb posted and the bit count was the same, just the date had changed. I even grouped the path-no dice.
                        Ended up using native followme and cleaned up.
                        mitcorb
                          No special problem with helix except a big time to calculate 💚
                          • jeff hammondJ Offline
                            jeff hammond
                            Any ideas? ❓
                            do you have the construction point in place? it's treated as the align point (see original post of this thread)..
                            if you don't have a construction point laying around, get it here:
                            constpoint.skp
                            if you do have the point in place already then i have no clue what the problem is..
                            dotdotdot
                            • E Offline
                              Ecuadorian
                              The last FollowMe and Keep requires no construction point. It adds one automagically.
                              -Miguel Lescano
                                jeff hammond
                                😳 uh.... ooops 😄
                                [edit] even worse, i have the latest version and i've still been putting the point in there manually 😆
                                dotdotdot
                                • E Offline
                                  Ecuadorian
                                  Worse yet, and a big Duh!
                                  I spent $4 in Smustard.com just to buy the "put construction point" tool, only to discover later that Didier Bur's projections toolbar has a much better version, it's free... and after all, I no longer need a construction point to use FollowMe and Keep!
                                  -Miguel Lescano
                                    you have inside 1001bits an another followme and keep 😉
                                    Very long calculation too ! Maybe the helix is some hard to follow?
                                      jonbassem
                                      @wikii said:
                                      FollowMe and keep the dirction of profiles.
                                      Tip:construction point in selection will be treated as the align_point!
                                      v0.04 20090210
                                      1 if path started at a vertex of profile,the vertex will be treated as align point.
                                      2 auto reverse face to get directviewing result.
                                      v0.03 20090209
                                      1 start at nearest vertex when path is closed
                                      2 fix some bugs
                                      http://www.sketchucation.com/forums/scf/download/file.php?id=21147
                                      v0.02 20090208
                                      1 perfect ending;
                                      2 autosmooth.
                                        So using Perpendicular face tool by Chris Fullmer will be some useful 😉
                                        • david_hD Offline
                                          david_h
                                          I think I got it to work without adding any point. It took a sec to calculate, butTa-DaH! Good little plugin. Thanks 👍
                                            aalaser
                                            Uesful tool for me.
                                            • 6
                                            • 11
                                            • 12
                                            • 4 / 12
