    POST YOUR RENDERS NR.2: WAREHOUSE
    130 Posts 45 Posters 31.8k Views 45 Watching
    • EarthMoverE Offline
      EarthMover
      Actually this warehouse is the fist thing I've rendered since I updated, and I've experienced zero parsing times. Could be that there are only 5 or so materials in the whole model. The 1.5 I was using before this was really bad. It's good to do quick test renders while texturing to find out what is slowing down parsing. It's usually due to materials placed on or in nested components.
      Content Creator at Skapeup
        tmposey
        Kerkythea render preset 19 MLT/50 passes
        t.
        • soloS Offline
          solo
          We should have this kind of "challenge" at least once at week. What do you guys think?
          Sounds like a great i dea Competition will push my skill even further
          Guys I have to disagree there, as making it competitive or a challenge will take the free flow fun out of it and force us to judge instead of enjoy.
          Secondly I am opposed to judging render apps against each other as that is what it will end up as being.
          Lets keep it fun.
          http://www.solos-art.com
          • FrederikF Offline
            Frederik
            Lets keep it fun.
            Fully agree with Pete on this one...!! πŸ‘
            Let's keep it fun..!! πŸ˜„
            Cheers
            Kim Frederik
            • stefanqS Offline
              stefanq
              I guess you're right, Pete.
                richcat
                Please - let's keep it fun, informative and learn from each other.
                • N Offline
                  nomeradona
                  Lets keep it fun.
                  well said solo/
                  visit my blog: http://www.nomeradona.blogspot.com
                    sepo
                    Keep it fun please...
                    • AnssiA Offline
                      Anssi
                      I fired up Artlantis R version 1 after about a year of no renders. This is what I got with no tweaking of materials at all. I will have to brush up my skills, but the model is so well textured that I am actually quite pleased already. Render time 48 seconds. Setup time 2-3 minutes.
                      Anssi
                        RustyShack
                        Another Artlantis render (v2). 3 mins
                        • marked001M Offline
                          marked001
                          @earthmover said:
                          After Post Process in Photoshop CS3
                          http://img80.imageshack.us/img80/4076/warehousevrayforsketchuge5.jpg
                          i think this is my fave so far.. def the most realistic. you should explain what all you did in pshop πŸ˜„
                          i'm working on a maxwell one right now.
                          http://www.revision21vis.com
                          instagram: revi21on
                          • E Offline
                            ENG. YASEEN
                            By Vray
                            By Vray
                            My Website:
                            http://xyz4studio.blogspot.com/
                              richcat
                              @kevsterman said:
                              I've downloaded the .skp but I seem to have a dark grey stripe top and bottom and I can't get rid of it πŸ˜•
                              Does anyone know whats causing it?
                              Kev if you have not fixed it already it can be corrected with a Rick Wilson ruby from smustard FixAspectRatio
                              • DanielD Offline
                                Daniel
                                Three Vue 7 renderings.
                                My avatar is an anachronism.
                                  l.frisken
                                  Indigo Render 5 hours 1333 samples per pixel on my 1.7 GHz that i think i accidently downclocked to around 0.7!
                                  • K Offline
                                    kevsterman
                                    I solved the problem by pasting the warehouse into a new model. Thanks for your advice though πŸ‘
                                    "Avoid keeping more than 3 items on your desk that you can't fit into your mouth."
                                    • N Offline
                                      nomeradona
                                      here is my another try. this time with additional model from the warehouse
                                      Adding some more Warehouse stuff
                                      http://i334.photobucket.com/albums/m421/nomeradona_1234/withabubots.jpg
                                      Then warehouse models were refined to show details. created some bump textures and added them to the diffuse map. So here is the my render image (no post process). more than 12 minutes with my quad core.
                                      http://i334.photobucket.com/albums/m421/nomeradona_1234/warehouse_render_nopostcopy.jpg
                                      Post process image to add grunges.
                                      my steps using photoshop: 1. created a copy of the image and add filter high pass.. play on the opacity
                                      2. add a new layer, then use gradient tool of two colors (one light brown and one dark brown) blending mode is overlay
                                      3. add noise to this gradient map
                                      4. add mask and use textured map (35%) to removed slightly some grunge effect
                                      http://i334.photobucket.com/albums/m421/nomeradona_1234/renderwarehouse_Final.jpg
                                        marked001
                                        great job with the bump maps nomeradomna..that container looks great.
                                        here's my quick 15 minute maxwell setup..think it rendered for like 8 hours or so... didnt really adjust any of the materials, aside from the emitters..
                                        http://img4.imageshack.us/img4/6987/warehousetest3ox9.jpg
                                        and via multilight, here is a a daytime version
                                        http://img165.imageshack.us/img165/9003/frame1uc0.png
                                        instagram: revi21on
                                        • N Offline
                                          nomeradona
                                          mark, thnaks for that. i noticed you said your render is about 8 hours, thats really long. Mine was just 12 minutes. Is it becasue of the emitters?..How about the daytime version?
                                            marked001
                                            maxwell is slow slow slow... it probably could've been shorter though, but i went out and left it running. the night and day images are created from the same render.. maxwell has a feature where you can adjust the output of each individual emitter, as well as the environment..
                                            instagram: revi21on
                                            • 6
                                            • 7
                                            • 5 / 7
