    [Plugin] BezierSpline - v2.2a - 22 Apr 21
    460 Posts 183 Posters 2.0m Views 183 Watching
      Diego
      In the latest version of the file - that's download-able from the first post in this topic - the 'preserve' variable is 'commented out' with # ...
      C:\Program Files\Google\Google SketchUp 7\Plugins\BZ_Dir_13\BZ__Segmentor.rb should have the word 'preserve' in it only twice [lines 86 and 128] - both times the line starts with a # to stop it loading...
      Do you have the right version ?
      If not, get it or add the two # yourself ?
        DIEGO-RODRIGUEZ
        TIG thanks.
        now it works perfect.
        • fredo6F Offline
          fredo6
          Thanks TIG for your help.
          For info, the preserve variable is to have an option to keep the original control points, but for whatever reason I forgot to finish the code.
          Fredo
          • H Offline
            hsjzyangbin
            Hope to improve the function :control point along z axis
            maybe add "ctrl" key to control XY plan or z plan
            • fredo6F Offline
              fredo6
              Do you mean you can do it or you wish to do it.
              Planar lock is supported in creation mode.
              Axis lock is also supported in Edition mode for th moving the control points.
              This is explained in the doc, using Ctrl and Arrows
              In a next version, I'll try to make something more explicit and straightforward however.
              Fredo
              • H Offline
                hsjzyangbin
                I used Bonzai3d to do it .
                thanks a lot
                hsjzyangbin
                • H Offline
                  hsjzyangbin
                  wish to have a visual interface control nodes of the function like YAD
                  here is an example:
                  best regards
                    Daniel S
                    here is an example:
                    About visual interface control nodes... Something like this is possible? (Like most 2d Vector software)
                    "A quadratic Bézier curve has a start and an end point (blue dots) and just one control point (red dot) while a cubic Bézier curve uses two control points."
                    Page not found - Welcome
                    Welcome (www.caffeineowl.com)
                    Daniel S
                    • H Offline
                      hsjzyangbin
                      @daniel s said:
                      here is an example:
                      [attachment=1:21zf7cs5]<!-- ia1 -->simulation.gif<!-- ia1 -->[/attachment:21zf7cs5]
                      [attachment=2:21zf7cs5]<!-- ia2 -->bezier.png<!-- ia2 -->[/attachment:21zf7cs5]
                      Daniel S
                      maybe some difference:
                      visual interface control number of nodes
                      [flash=][attachment=0:21zf7cs5]<!-- ia0 -->2010-03-18_0456.swf<!-- ia0 -->[/attachment:21zf7cs5][/flash]
                      thank you
                      2010-03-18_0456.swf
                        thanhsjc
                        thank you very much
                        • K Offline
                          kyyu
                          Hi Fredo6,
                          First of all, thank you very much for this wonderful plugin! 😄 I would like to report a small bug with the "Convert to Catmull Spline" feature. One of the segments is always left out of the conversion.
                          -Kwok
                          • fredo6F Offline
                            fredo6
                            @kyyu said:
                            Hi Fredo6,
                            -Kwok
                            You need to explictly close the loop, by hitting the Key F9 (or via contextual menu).
                            Fredo
                            • K Offline
                              kyyu
                              @kyyu said:
                              Hi Fredo6,
                              -Kwok
                              Fredo
                              Thanks, that worked perfectly!
                              -Kwok
                                Slimdog
                                Hi guys I have just downloaded the most recent version. BezierSpline%201.
                                I have put LibTraductor.rb, BZ_Dir_13, and bezierspline.rb into the plugins folder on my MAC. When I open sketchup I get this error:
                                Error Loading File #extrusionToolbar.rb
                                no such file to load -- deBabelizer.rbError Loading File 2D#.rb
                                no such file to load -- deBabelizer.rbError Loading File extrudeEdgesByEdges.rb
                                no such file to load -- deBabelizer.rbError Loading File extrudeEdgesByFaces.rb
                                no such file to load -- deBabelizer.rbError Loading File extrudeEdgesByLathe.rb
                                no such file to load -- deBabelizer.rbError Loading File extrudeEdgesByRails.rb
                                no such file to load -- deBabelizer.rbError Loading File extrudeEdgesByVector.rb
                                any ideas guys???
                                Cheers
                                Steve
                                  That's messages related to TIG's tools. you're missing one of his dependant files deBabelizer.rb.
                                    Since you must have downloaded both my 2DTools and ExtrusionTools I wonder where you put deBabelizer.rb that comes with both of them ?
                                    Anyway... here's another copy to save you having to find it - put it into the Plugins folder and restart SUp - that error should then be gone...deBabelizer.rb
                                      Slimdog
                                      Yes you guys are correct. My bad. I thought it out when I was loading Bezierspline.
                                      Thanks for the responses.
                                      S
                                        Morphing_24
                                        Hi fredo
                                        I work on a mac and I have a really big problem here.
                                        I dont know how can I view the cadfather toolbar on sketchup, I can only see the standard one and I installed all the files in the correct places bezierspline.rb, LibTraductor.rb and BZ_DIR_13 subfolder. I don't even see the option "convert to" when I right click on a bezier line , I need to use the polyline segmentor and courbette. I tried everything...reinstalling sketchup, also removing all the plugins I have from the Library/AplicationSupport/Google Sketchup 7/Sketchup/ plugins folder,but guest what, I still see all the toolbars working perfectly even though the plugin folder is empty.
                                        However, when I work on windows I have no problems, I install the latest bezierspline and it works perfect.... what am I doing wrong?
                                        • I Offline
                                          inasia
                                          Many Thanks Fredo,
                                          Much appreciated, for your Plugin.
                                          Thank you again
                                          have a good day
                                          cheers
                                          inasia
                                          • fredo6F Offline
                                            fredo6
                                            @morphing_24 said:
                                            Hi fredo
                                            If the Library/AplicationSupport/Google Sketchup 7/Sketchup/ plugins folder is empty and you still have BezierSpline working, then you may have something left in the other plugin folder which is under /user/....
                                            Otherwise, maybe some Mac users could help you to troubleshoot, as I don't have a Mac at hand.
                                            Fredo
                                            • 6
                                            • 7
                                            • 22
                                            • 23
                                            • 5 / 23
