    [Plugin] BezierSpline - v2.2a - 22 Apr 21
    460 Posts 183 Posters 2.1m Views 183 Watching
    • robertWanR Offline
      robertWan
      (www.screencast.com)
      Robert
      • SkeeterdS Offline
        Skeeterd
        Wonderful plugin! Is there a way to keep a tool persistent like in the tools on surface plugin?
          tellkurt
          How would I install the plugin for Sketchup 2014 ?
          • fredo6F Offline
            fredo6
            The strongly suggested method is that you first install the Sketchucation PluginStore tool, so that you can easily and safely install any plugin.
            Then, you can auto-install Bezierspline and all other plugins in one click.
            Fredo
              mamagroene
              so, I just installed the plugin, but as soon as I try to use it with sketch up (my version is sketchup pro 2014, the toolbar that appears is just empty. I hope you understand my problem as I'm not a native english speaker. we tried pretty much everything to make it work, but we simply can't. I hope you can help!
              • TIGT Online
                How did you install it ?
                Sounds like some files are missing...
                Please reinstall it using the PluginStore's AutoInstall tool, OR if you have the RBZ, then use it with v2014's Preferences > Extensions > Install... button...
                Also note that many of Fredo's tools need LibFredo - also install the latest version of that [also available at the PluginStore...].
                Restart after the installing to ensure everything is synchronized...
                  antonio.calvo
                  Hello Fredo, thank you for your plugin. Is fantastic and works great. Any way of making it persistent to glue to surface/or group/or edge..? Maybe be with a key stroke? Thank you so much again.
                  • W Offline
                    witjazz
                    thanks
                    • Y Offline
                      yaseerr
                      like it thank you
                      • fredo6F Offline
                        fredo6
                        NEW RELEASE 1.7a - 19 Oct 2014
                        This release is required for SU 2014 when your username contains non-ascii characters
                        Note that non-ascii characters are not supported for SU13 and previous versions of Sketchup
                        Download new release at main post
                        Fredo
                        • W Offline
                          WebBeau
                          Thanks a lot
                          • E Offline
                            Esense3d
                            Hello Fredo
                            I would like to translate this plugin on all German but can not find language files
                            Bezier spline is only partially translated
                            Fredo I now have this new address
                            Roland F Swiss
                            • fredo6F Offline
                              fredo6
                              @esense3d said:
                              Hello Fredo
                              Roland F Swiss
                              Thanks for this proposal.
                              BezierSpline is not compliant with LibFredo6. So, it is built differently. I will make a full refresh one of these days.
                              Anyway, the current version already includes a German translation.
                              Fredo
                              • E Offline
                                Esense3d
                                Hello Fredo
                                I See but it is not Full Translated
                                Just Parts of it
                                I also have your other plugins translated fully ie including the main folder
                                and other
                                Therefore, any icons etcetera in German
                                If you want I send you these versions as rbz versions to
                                If you do not mind I would publish in the German part please
                                Roland F.
                                • fredo6F Offline
                                  fredo6
                                  NEW RELEASE 1.7b - 22 Mar 2015
                                  This release removes noisy traces at startup of Sketchup
                                  Fredo
                                  • fredo6F Offline
                                    fredo6
                                    NEW RELEASE 1.7c - 23 Mar 2015
                                    This release removes noisy traces at startup of Sketchup - second trial
                                    Fredo
                                      rdcraighead
                                      This site is terribly confusing. I just want to buy BezierSpline script, but see no link to allow me to do so. Why does this need to be so complicated?
                                      • G Offline
                                        Gábor
                                        What do you mean by being complicated? In the PluginStore you can easily find it by a simple search: http://sketchucation.com/pluginstore?pln=BezierSpline
                                          It's free.
                                          • MsketcherM Offline
                                            Msketcher
                                            I'm having problems with locking axis reference while drawing a classic bezier curve. It looks like it's trying to, as the "square mark" at the cursor is filled and turns color depending upon which arrow key I press, but it does not restrict axis for me. I'm on a Mac, SketchUp 2015 Pro. I've looked at the manual and thought I am doing everything right. I swear I had it working earlier today...
                                            • 15
                                            • 16
                                            • 17
                                            • 18
                                            • 19
                                            • 22
                                            • 23
                                            • 17 / 23
