    [Plugin] BezierSpline - v2.2a - 22 Apr 21
    460 Posts 183 Posters 2.0m Views 183 Watching
      rv1974
      Hi Fredo,
      I recently updated your spline tools set and unfortunately it stopped functioning.
      I get the toolbar, I can activate the commands, but they simply don't draw.
      I'm pretty sure the file's structure is OK, the FredoLib is updated.
      What could be the reason?
      Thank you in advance.
      BTW where could I download the older version?
        Have you tried reinstalling it? Completely removing the existing plugin first and then reinstall to be 100% sure everything is installed correctly.
          rv1974
          Did it a couple times it didn't help.
            What is your system info? Windows and SketchUp version?
            Does none of the drawing functions work?
            I cannot reproduce it here on my end. Everything appear to work. SU8M1 Pro, Win7.
              rv1974
              it's win7x64 + su8 (see the printscreen).
              none of drawing tools work.
                rv1974
                I just downgraded to v1.2. It solved πŸ˜• the problem
                  You shouldn't have to do that, though.
                    Lets see what Fredo says - there's been no other reports of this issue since it was released in January. Seems that there's some local issue. Have you tried temporarily to run SU with just BezierSpline? In case there is a conflict with some other plugin?
                      rv1974
                      Bingo!
                      I took (my curiosity conquered my natural laziness he-he) the virgin plugins folder and placed the latest spline set. It works.
                      but now I have dilemma: to filter hundreds plugins or comfortably stay with the mess?
                        Do it 'by halves'.
                        Add half of the Plugins back in and retry.
                        If it fails you know the problem is with that half just moved back.
                        Remove half back into the temp folder and retry.
                        If it fails you know the problem is in the remaining portion left in etc etc
                        It it's still OK try moving over half of what's left... etc
                        Again if it fails you know the issue is with the 'half' just moved back and so on...
                        You can quickly narrow it down to a small group of files so 512 > 256 > 128 > 64 > 32 > 16 > 8 > 4 > 2 > 1 => only 10 steps in the very worst case...
                          Meanwhile, take a screenshot of your plugins folder content so we can scan it for known rogue plugins. Matchbox for instance is a known troublemaker.
                            rv1974
                            @tig said:
                            Do it 'by halves'.
                            that's smart I'll try it
                            But I guess the number of plugins itself is a biggest troublemaker.
                            • fredo6F Offline
                              fredo6
                              @rv1974
                              Maybe you can open the Ruby console and chcek if there is any message displayed that could give me a hint (plugins like Matchbox and old versions of Podium are known to create side-effects).
                              Also, if you use my other plugins (like FredoScale or RoundCorner), do they function correctly?
                              In last resort, use TIG's method to find out. Detecting plugin conflicts is always useful for the community of users.
                              Fredo
                                rv1974
                                At the end I restartedmy PC, replaced (portion by portion, TIG's prescription) and magically the things get normalized).
                                So, let's say it was kind a local turbulence.
                                Sorry for bothering,
                                and thank you for replies.
                                • majidM Offline
                                  majid
                                  these are really great tools, just wish a more descriptive image (tut) πŸ‘
                                    Jaebum Myung
                                    Dear Fredo,
                                    Thanks for everything.^^
                                    from mooksu
                                    • X Offline
                                      xellos
                                      thank you very much
                                        caronte01
                                        Thanks for this very useful plugin Fredo. I use it a lot!
                                        • gullfoG Offline
                                          gullfo
                                          copy of note in LibFredo thread:
                                          not sure if it is the LibFredo 4.3b or the BezierSpline 1.4f plugin, but if the LibFredo 4.3b is enabled, the BezierSpline 1.4f does not work. i get a Ruby console error for line 592 cannot convert nil to float.
                                          Error: #<TypeError: no implicit conversion to float from nil>
                                          C:/Program Files/Google/Google SketchUp 8/Plugins/BZ_Dir_14/bezierspline_main.rb:592:in -' C:/Program Files/Google/Google SketchUp 8/Plugins/BZ_Dir_14/bezierspline_main.rb:592:in onMouseMove'
                                          Fredo tools works regardless of BezierSplines being enabled or not.
                                          NOTE: I only encountered this error since updating to 4.3b and prior to that it was working correctly.
                                          NOTE: this result was found with only the LibFredo and BezierSpline plug-ins running - SU8 Pro on Windows Vista SP2 Ruby 1.9.3
                                          NOTE: it may be due to LibTraductor - the old version is still in the plug-in directory and the Lib6Traductor in the LibFredo dir is not compatible with the BezierSpline calls.
                                          Glenn
                                          http://www.runnel.com
                                          • fredo6F Offline
                                            fredo6
                                            @gulfo
                                            The error is strange (it has nothing to do with LibTraductor and should not create problem). Is it always the same?
                                            There may be some corruption of the scripts.
                                            Unless already done, I would suggest you clean up the two folders and 3 files and reinstall a fresh version taken from Sketchucation.
                                            Fredo
                                            PS: Just comment out the line 592, which should be return if (t - @time_move) < 0.01, by prepending a # character. Can you then check if this work.
                                            • 10
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 22
                                            • 23
                                            • 12 / 23
