    [Plugin] BezierSpline - v2.2a - 22 Apr 21
    460 Posts 183 Posters 2.0m Views 183 Watching
    • H Offline
      helmholtz
      Thank you greatly good sir πŸ˜„
        marcel.forum
        Dear Fredo
        Big thanks for this plugin.
        Marcel
        • X Offline
          xrok1
          spotted this in another thread. Worth noting:
          http://forums.sketchucation.com/download/file.php?id=67872&t=1
            rv1974
            Hi Fredo,
            I recently updated your spline tools set and unfortunately it stopped functioning.
            I get the toolbar, I can activate the commands, but they simply don't draw.
            I'm pretty sure the file's structure is OK, the FredoLib is updated.
            What could be the reason?
            Thank you in advance.
            BTW where could I download the older version?
              Have you tried reinstalling it? Completely removing the existing plugin first and then reinstall to be 100% sure everything is installed correctly.
                rv1974
                Did it a couple times it didn't help.
                  What is your system info? Windows and SketchUp version?
                  Does none of the drawing functions work?
                  I cannot reproduce it here on my end. Everything appear to work. SU8M1 Pro, Win7.
                    rv1974
                    it's win7x64 + su8 (see the printscreen).
                    none of drawing tools work.
                      rv1974
                      I just downgraded to v1.2. It solved πŸ˜• the problem
                        You shouldn't have to do that, though.
                          Lets see what Fredo says - there's been no other reports of this issue since it was released in January. Seems that there's some local issue. Have you tried temporarily to run SU with just BezierSpline? In case there is a conflict with some other plugin?
                            rv1974
                            Bingo!
                            I took (my curiosity conquered my natural laziness he-he) the virgin plugins folder and placed the latest spline set. It works.
                            but now I have dilemma: to filter hundreds plugins or comfortably stay with the mess?
                              Do it 'by halves'.
                              Add half of the Plugins back in and retry.
                              If it fails you know the problem is with that half just moved back.
                              Remove half back into the temp folder and retry.
                              If it fails you know the problem is in the remaining portion left in etc etc
                              It it's still OK try moving over half of what's left... etc
                              Again if it fails you know the issue is with the 'half' just moved back and so on...
                              You can quickly narrow it down to a small group of files so 512 > 256 > 128 > 64 > 32 > 16 > 8 > 4 > 2 > 1 => only 10 steps in the very worst case...
                                Meanwhile, take a screenshot of your plugins folder content so we can scan it for known rogue plugins. Matchbox for instance is a known troublemaker.
                                  rv1974
                                  @tig said:
                                  Do it 'by halves'.
                                  that's smart I'll try it
                                  But I guess the number of plugins itself is a biggest troublemaker.
                                  • fredo6F Offline
                                    @rv1974
                                    Maybe you can open the Ruby console and chcek if there is any message displayed that could give me a hint (plugins like Matchbox and old versions of Podium are known to create side-effects).
                                    Also, if you use my other plugins (like FredoScale or RoundCorner), do they function correctly?
                                    In last resort, use TIG's method to find out. Detecting plugin conflicts is always useful for the community of users.
                                      rv1974
                                      At the end I restartedmy PC, replaced (portion by portion, TIG's prescription) and magically the things get normalized).
                                      So, let's say it was kind a local turbulence.
                                      Sorry for bothering,
                                      and thank you for replies.
                                      • majidM Offline
                                        majid
                                        these are really great tools, just wish a more descriptive image (tut) πŸ‘
                                          Jaebum Myung
                                          Dear Fredo,
                                          Thanks for everything.^^
                                          from mooksu
                                          • X Offline
                                            xellos
                                            thank you very much
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 22
                                            • 23
                                            • 12 / 23
