    [Plugin] BezierSpline - v2.2a - 22 Apr 21
    460 Posts 183 Posters 2.1m Views 183 Watching
    • jeff hammondJ
      Just one remark: with your skinning approach, you don't need to divide the segment. Curviloft can do it for you via the Sampling parameter.
      ha.. yeah, i knew that (as it's a great feature of curviloft in general). what i meant to do was use the manual divide as a way to show me trying to force curviloft to make the lines to no avail.
      for whatever reason, i ended up doing it in a few different parts..
      i should maybe try following a script next time i make a video πŸ˜„
        redsteel
        Hi Fredo
        I just want to say thank you very much!
        • V
          vidy
          Dear Fredo,
          First of all i want to thank you for this magnificent plugin.. πŸ‘
          but i have question, is there a way to slow down the movement of the grip, when we select a grip or a point to edit it?? i usually have this problem when i want to move it on certain axes (after im press ctrl button)
          Regards,
          still so much to learn..
          • C
            clifdon
            Great thank you for this plugin πŸ˜„.
            • H
              helmholtz
              Thank you greatly good sir πŸ˜„
                marcel.forum
                Dear Fredo
                Big thanks for this plugin.
                Marcel
                • X
                  xrok1
                  spotted this in another thread. Worth noting:
                  http://forums.sketchucation.com/download/file.php?id=67872&t=1
                    rv1974
                    Hi Fredo,
                    I recently updated your spline tools set and unfortunately it stopped functioning.
                    I get the toolbar, I can activate the commands, but they simply don't draw.
                    I'm pretty sure the file's structure is OK, the FredoLib is updated.
                    What could be the reason?
                    Thank you in advance.
                    BTW where could I download the older version?
                      Have you tried reinstalling it? Completely removing the existing plugin first and then reinstall to be 100% sure everything is installed correctly.
                        rv1974
                        Did it a couple times it didn't help.
                          What is your system info? Windows and SketchUp version?
                          Does none of the drawing functions work?
                          I cannot reproduce it here on my end. Everything appear to work. SU8M1 Pro, Win7.
                            rv1974
                            it's win7x64 + su8 (see the printscreen).
                            none of drawing tools work.
                              rv1974
                              I just downgraded to v1.2. It solved πŸ˜• the problem
                                You shouldn't have to do that, though.
                                  Lets see what Fredo says - there's been no other reports of this issue since it was released in January. Seems that there's some local issue. Have you tried temporarily to run SU with just BezierSpline? In case there is a conflict with some other plugin?
                                    rv1974
                                    Bingo!
                                    I took (my curiosity conquered my natural laziness he-he) the virgin plugins folder and placed the latest spline set. It works.
                                    but now I have dilemma: to filter hundreds plugins or comfortably stay with the mess?
                                      Do it 'by halves'.
                                      Add half of the Plugins back in and retry.
                                      If it fails you know the problem is with that half just moved back.
                                      Remove half back into the temp folder and retry.
                                      If it fails you know the problem is in the remaining portion left in etc etc
                                      It it's still OK try moving over half of what's left... etc
                                      Again if it fails you know the issue is with the 'half' just moved back and so on...
                                      You can quickly narrow it down to a small group of files so 512 > 256 > 128 > 64 > 32 > 16 > 8 > 4 > 2 > 1 => only 10 steps in the very worst case...
                                        Meanwhile, take a screenshot of your plugins folder content so we can scan it for known rogue plugins. Matchbox for instance is a known troublemaker.
                                          rv1974
                                          @tig said:
                                          Do it 'by halves'.
                                          that's smart I'll try it
                                          But I guess the number of plugins itself is a biggest troublemaker.
                                          • fredo6F
                                            @rv1974
                                            Maybe you can open the Ruby console and chcek if there is any message displayed that could give me a hint (plugins like Matchbox and old versions of Podium are known to create side-effects).
                                            Also, if you use my other plugins (like FredoScale or RoundCorner), do they function correctly?
                                            In last resort, use TIG's method to find out. Detecting plugin conflicts is always useful for the community of users.
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 22
                                            • 23
                                            • 12 / 23
