    [Plugin] Purge All
    65 Posts 32 Posters 145.4k Views 32 Watching
      If you have permissions to add files to your Plugins folder...
      Properties > Security > Edit... FULL for all listed...
      And you have indeed installed it properly...
      When you restart SketchUp the tool should now appear appear in the Plugins menu - there is no 'button' unless you have a 'doctored' version that adds a toolbar...
      If you have v2013 why not use the Preferences > Extensions > Install... button to install any RBZ format plugin downloaded from the SketchUcation PluginStore...
      http://sketchucation.com/resources/pluginstore?pln=PurgeAll
      Or why not get/use the SketchUcation Plugin Store toolset and then you can AutoInstall plugins from within SketchUp automatically.
      http://sketchucation.com/resources/plugin-store-download
      Now there's no need to mess on manually installing plugins - provided that you have FULL permission to the Plugins folder πŸ˜‰
        There's a new version available from the PluginStore.
        It contains some 'future-proofing'.
        The log-report format is also improved.
        It is now ready for the next generation of SketchUcationTools etc...
        http://sketchucation.com/pluginstore?pln=PurgeAll
          There's another new version available from the PluginStore.
          It contains some more 'future-proofing'.
          The log-report format is also improved yet again.
          It is now fully ready for the next generation of SketchUcationTools etc...
            There's yet another new version available from the PluginStore.
            It has some cosmetic tweaking and it is now fully ready for the next generation of SketchUcationTools etc...
            • cottyC Offline
              cotty
              Sounds like it is now fully ready for the next generation of SketchUcationTools... 😎
              my SketchUp gallery
                There's a storm a brewin'
                • K Offline
                  kaas
                  Suggestion: to really purge a file to its bare minimum, maybe add an option to remove attributes (set by some plugins), ifc info etc?
                    I was thinking about offering to delete the IFC stuff as that can bloat a file and slow it down.
                    However some other 'attributes' do add usefulness - like DCs... - which should endure - how do we decide what to keep ?
                    • K Offline
                      kaas
                      @tig said:
                      ...However some other 'attributes' do add usefulness - like DCs... - which should endure - how do we decide what to keep ?
                      Good point. Maybe make a combo box with several options for cleaning the attributes: remove all, preserve @ components, ...
                        argenario
                        I,ve just downloaded it and purged 368 materials that were not in use and making my drawing sooo slow(sketchup 2015).... THANK U! THANK U! THANK U! THANKS A LOT!
                          Here's v2.0 http://sketchucation.com/pluginstore?pln=PurgeAll It is now signed for full compatibility with v2016/2017 in all loading-policies.
                          • F Offline
                            feodos
                            Can I ask you to make an icon for this plugin?
                            http://f21.ifotki.info/org/6feee38364657529bba52278e94868bfbca241272661627.png
                              No need to make the plugin more complex. Just make a keyboard shortcut for it.
                                Here's v3.0
                                https://sketchucation.com/pluginstore?pln=PurgeAll
                                It's now signed for full compatibility with all current SketchUp versions, in all extension-loading-policies.
                                It also has the annoying display glitch fixed - where the report's formatting for materials tabbed over to the right too much !
                                • boofredlayB Offline
                                  boofredlay
                                  Thanks TIG
                                    Here's v4.0
                                    It's now made fully compatible with v2020 - replacing 'Layers' with 'Tags' when prompting/reporting...
                                      Thank you sir.
                                        Here's v5.0
                                        It fixes the sometimes confusing reporting of groups getting included in the end components list [groups are component-definitions, but they are never purge-able].
                                        It also address the log-file not opening on MAC's using newer versions of SketchUp...
                                          rv1974
                                          @TIG Could it be non-modal please - what exactly is the point of hitting OK?
                                          TIGT 1 Reply Last reply Reply Quote 0
                                            TIG Moderator @rv1974
                                            @rv1974
                                            It can't be non-modal because it uses the UI.inputbox which is always modal.
                                            Thre has to be a way of closing the window - in this case it's OK or Cancel...
                                            R 1 Reply Last reply Reply Quote 0
                                            • 3 / 4
