    [Plugin] UVTools v0.1
    180 Posts 71 Posters 135.4k Views 71 Watching
    • K Offline
      Khai
      @thomthom said:
      I'm connected to the Matrix. πŸ€“
      that explains the glasses....
      • sadyoS Offline
        sadyo
        Can not using this plugin on SU Pro 8.0.4811, everytime i try to using it, it's make SU Bugsplat
        It's happening too with UVTools v0.2 ❓ ❓ ❓ ,
        • sadyoS Offline
          sadyo
          Oops...Sorry 😳 It's working pretty well on SU8 now, when i try to using it with Jeff Hammond Tips
            Sketchy Master
            Where Is the URL for download
              It's in the first post.
              • P Offline
                pdwyer
                Does this still work with SU8 on windows?
                The plugin doesn't start, no menu is created. 😞
                  It works perfectly you must have installed it incorrectly.
                  I use it everyday on v7, v7.1 and v8
                  • massimoM Offline
                    massimo Moderator
                    Hi pdwyer, I don't have SU 8 so I cannot test it. Anyway the plugin only appears in the context menu so right click on a texture-->UV tools.
                    • P Offline
                      pdwyer
                      Ignore me, it is working, just not the UI I was expecting πŸ˜„
                      all good
                        burningman
                        I'm using Sk 8-0-11751 on a mac book pro. Can you point me to the download for the uv tools plugin? Thanks so much.
                          It's attached to the first post with a
                          http://forums.sketchucation.com/images/upload_icons/ruby.gif
                          icon.
                          Generally this is the way authors publish and keep their plugins updated here so always look in the first post.
                            burningman
                            BIGthanks mate!
                            • E Offline
                              Eric5150
                              I have a problem using UVTools. I am new to UV texturing. My current project is a sketchup version of Spaceship Earth from EPCOT. The link to the sketchup file is below. I need to know how to get the texture located in front of the sphere to wrap around the sphere.
                              Please give me a tutorial as I would like to know how to do this in the future. Any help would be appreciated as I tried looking through this post but Sketchup kept crashing everytime I tried to do it.
                              Eric
                              http://www.ejlmusic.com/sketchup/Spaceship Earth Final 12C.skp
                              Thanks in advance
                              (would love a youtube video tutorial if anyone has time...it would help us noobs out immensely)
                                jumpjack
                                I don't understand how to use the plugin.
                                I installed it,I get the new context menu.
                                I create a cylynder/sphere, then... what? I create a wall close to it, apply a texture to the wall and use the UV right menu on it?
                                Nothing happens.
                                • FrederikF Offline
                                  Frederik
                                  Why would you install a plugin if you don't know what it is...?
                                  Take a look at some of the posts on page 1 and 2... There's a good tutorial by Alan Fraser...
                                  Try applying a bitmap texture to a sphere or a cylinder...
                                  It's important that it's not just a color but a bitmap texture...
                                  You'll see that the texture looks odd on such shapes...
                                  Now click the sphere to select it...
                                  Right-click it an from the submenu select UV tools and then select i.e. spherical...
                                  You'll see that the texture looks correct now...
                                  Cheers
                                  Kim Frederik
                                    demigamer
                                    Thanks A lot !
                                    Downloading. . . . πŸ˜‰
                                    • HornOxxH Offline
                                      HornOxx
                                      Hi All,
                                      Since I use Artisan, I have the need to improve my uv-texturing skills ❗
                                      I want to use the UV-Tools plugin but I donΒ΄t get it to run on SketchUp 2013 - IΒ΄m certainly
                                      doing anything wrong. The only footprint is the "UVtools.rb"-file (?) but inside SketchUp
                                      I dontΒ΄t get any icons or any context menu
                                      I appreciate any help
                                      never trust a skinny cook
                                      • N Offline
                                        numerobis
                                        you could try ThruPaint
                                        http://sketchucation.com/forums/viewtopic.php?f=323%26amp;t=44552
                                        or SketchUV
                                        http://extensions.sketchup.com/en/content/sketchuv
                                          thegoodguy
                                          Thanks for this awesome plugin Whaat!
                                          • N Offline
                                            nlipovac
                                            I use SketchUV and Roadkill, and it works great. πŸ˜„
                                            WrapR is in development and it will make unwraping inside SU.
                                            • 6
                                            • 7
                                            • 8
                                            • 9
                                            • 9 / 9
