    [Plugin] UVTools v0.1
    180 Posts 71 Posters 138.8k Views 71 Watching
    • W Offline
      Whaat
      hi,
      I haven't tested the plugin using SketchUp 7.1 yet. Maybe there is a conflict...
      • E Offline
        Ecuadorian
        SU 7.1 here, and no conflicts at all.
        -Miguel Lescano
        • W Offline
          Wizaerd
          @ecuadorian said:
          No need to create a sphere the hard way. If you have SketchyPhysics installed, use it to easily create a sphere with the SketchySolids toolbar. UVtools will map it without problem, except for a few hurricanes in both poles.
          I didn't necessarily think that method of creating a sphere was hard or difficult. Plus the plugin you reccommended, SketchyPhysics, seems a bit overkill just to create a sphere... I don't use Sketchup for animations, so physics aren't really necessary for what I'm using it for, unless I'm missing something...
            Hehe. True - for a couple of second job you really don't need that robust plugin (or you can even make a couple of spheres and save them as components and keep reusing them)
            • E Offline
              Ecuadorian
              That's why I said: 😄
              -Miguel Lescano
              • W Offline
                Wizaerd
                Is there something I can submit or show that'll help troubleshoot the porblem I'm having with it? Because everytime I try to use it (just choosing the menu option in the right click menu) causes my SU to crash, each and every time.
                • jeff hammondJ Offline
                  jeff hammond
                  i guess you could post the .skp of your sphere along with the texture to make sure those aren't causing a problem..
                  fwiw, it works for me with su7.1
                  [edit] oh, make sure you have the proper face (front) showing.. if i'm trying to map the sphere with the back face showing -- instacrash..
                  also, make sure there is a texture on the sphere before using the tool.. trying to use the tool on the blank sphere will crash su
                  dotdotdot
                  • W Offline
                    Wizaerd
                    I suppose I can send the sphere, but it's just a basic sphere. Created a circle, deleted half of it, used the follow me tool to create the sphere, made sure the faces were all pointing outwards. As far as the texture, I never get to that point. I select the sphere, right click to choose UV Tools->Spherical Mapping and SU crashes, so there's no texture involved. At all. And it consistently crashes each and every time...
                    EDIT
                    Never mind, I get what's wrong... Never dawned on me I had to have a texture applied before I run the plugin... Completely my fault... D'uh.
                    Sphere.skp
                      jeff hammond
                      ha, yeah.. afterall, you are trying to map the texture 😄
                      dotdotdot
                      • W Offline
                        Wizaerd
                        I assumed the plugin was creating UV coordinates so that when a texture was applied, it would use them. I really feel kinda stupid now... heh heh heh
                        • KrisidiousK Offline
                          Krisidious
                          is there a box mapping function for this?
                          By: Kristoff Rand
                          • jarynzlesaJ Offline
                            jarynzlesa
                            good work - thank you 👍 .
                            http://www.vizualizaceschodiste.mypage.cz/
                            • G Offline
                              Globalist
                              Thank you so much.Very kind of you (all).
                              Regards.
                                caarloos82
                                Thank you for your plugin. Between all of you (plugin´s developers) are going to do of sketchup a software as good or even better than softwares like rhinoceros.
                                cheers
                                • RichardR Offline
                                  Richard
                                  Thomas!
                                  Mate I played around with the plugin for a tree trunk in combination with fredoscale and I ended up with a mass of assigned materials (all the same) when exported to maxwell. I noted this before with Whaat's UV tools (cant remember the name of the plugin).
                                  Funny though it was only for several faces - I'll have to test some more and see what went on there!
                                  BUILTBRAND.COM.AU
                                    This is Whaat's UV Tool thread?
                                    Are you looking for Thomthom UV Toolkit 2.1.0?
                                    http://forums.sketchucation.com/viewtopic.php?t=18992
                                      @richard said:
                                      Thomas!
                                      I'm not entirely sure, but I'm guessing the Maxwell exporter exported out a texture for each face with a distorted texture.
                                      • RichardR Offline
                                        Richard
                                        yep! They didn't call me Richard (dick) for nothing! That's funny - just clicked on thread from "view your posts" and bang wrong one!
                                        Yes Thomas - I'll continue this to your tool thread!
                                        Sorry Dale for getting off topic!
                                        BUILTBRAND.COM.AU
                                          No hassle Dic....Richard! How Thom found it here i another story..... 😲
                                            I'm connected to the Matrix. 🤓
                                            • 6
                                            • 7
                                            • 8
                                            • 9
                                            • 8 / 9
