    [Plugin] UVTools v0.1
    180 Posts 71 Posters 155.4k Views 71 Watching
    • GaieusG
      Hi Wizaerd,
      It crashed my SU 4 times today, too.
      I'll have to get a better look into it but then Dale (developer of this plugin) can also see the details (I'll make sure to let him know if I found that the tool is indeed the culprit).
      • majidM
        majid
        now we are on sketchup 7.1 , and no improvement on special mapping!!! 😒 so once again I am gonna ask our ruby heros for help and progressing the script 🎉
        • E
          Ecuadorian
          No need to create a sphere the hard way. If you have SketchyPhysics installed, use it to easily create a sphere with the SketchySolids toolbar. UVtools will map it without problem, except for a few hurricanes in both poles.
          -Miguel Lescano
          • W
            Whaat
            hi,
            I haven't tested the plugin using SketchUp 7.1 yet. Maybe there is a conflict...
            • E
              Ecuadorian
              SU 7.1 here, and no conflicts at all.
              -Miguel Lescano
              • W
                Wizaerd
                I didn't necessarily think that method of creating a sphere was hard or difficult. Plus the plugin you reccommended, SketchyPhysics, seems a bit overkill just to create a sphere... I don't use Sketchup for animations, so physics aren't really necessary for what I'm using it for, unless I'm missing something...
                • GaieusG
                  Hehe. True - for a couple of second job you really don't need that robust plugin (or you can even make a couple of spheres and save them as components and keep reusing them)
                  • E
                    Ecuadorian
                    That's why I said: 😄
                    -Miguel Lescano
                    • W
                      Wizaerd
                      Is there something I can submit or show that'll help troubleshoot the porblem I'm having with it? Because everytime I try to use it (just choosing the menu option in the right click menu) causes my SU to crash, each and every time.
                      • jeff hammondJ
                        i guess you could post the .skp of your sphere along with the texture to make sure those aren't causing a problem..
                        fwiw, it works for me with su7.1
                        [edit] oh, make sure you have the proper face (front) showing.. if i'm trying to map the sphere with the back face showing -- instacrash..
                        also, make sure there is a texture on the sphere before using the tool.. trying to use the tool on the blank sphere will crash su
                        • W
                          Wizaerd
                          I suppose I can send the sphere, but it's just a basic sphere. Created a circle, deleted half of it, used the follow me tool to create the sphere, made sure the faces were all pointing outwards. As far as the texture, I never get to that point. I select the sphere, right click to choose UV Tools->Spherical Mapping and SU crashes, so there's no texture involved. At all. And it consistently crashes each and every time...
                          EDIT
                          Never mind, I get what's wrong... Never dawned on me I had to have a texture applied before I run the plugin... Completely my fault... D'uh.
                          Sphere.skp
                          • jeff hammondJ
                            ha, yeah.. afterall, you are trying to map the texture 😄
                            • W
                              Wizaerd
                              I assumed the plugin was creating UV coordinates so that when a texture was applied, it would use them. I really feel kinda stupid now... heh heh heh
                              • KrisidiousK
                                Krisidious
                                is there a box mapping function for this?
                                By: Kristoff Rand
                                • jarynzlesaJ
                                  jarynzlesa
                                  good work - thank you 👍 .
                                  http://www.vizualizaceschodiste.mypage.cz/
                                  • G
                                    Globalist
                                    Thank you so much.Very kind of you (all).
                                    Regards.
                                    • C
                                      caarloos82
                                      Thank you for your plugin. Between all of you (plugin´s developers) are going to do of sketchup a software as good or even better than softwares like rhinoceros.
                                      cheers
                                      • RichardR
                                        Richard
                                        Thomas!
                                        Mate I played around with the plugin for a tree trunk in combination with fredoscale and I ended up with a mass of assigned materials (all the same) when exported to maxwell. I noted this before with Whaat's UV tools (cant remember the name of the plugin).
                                        Funny though it was only for several faces - I'll have to test some more and see what went on there!
                                        BUILTBRAND.COM.AU
                                          This is Whaat's UV Tool thread?
                                          Are you looking for Thomthom UV Toolkit 2.1.0?
                                          404 Not Found
                                          (forums.sketchucation.com)
                                            @richard said:
                                            Thomas!
                                            I'm not entirely sure, but I'm guessing the Maxwell exporter exported out a texture for each face with a distorted texture.
                                            • 8 / 9
