    [Plugin] UVTools v0.1
    180 Posts 71 Posters 160.5k Views 71 Watching
    • GaieusG
      Hehe. True - for a couple of second job you really don't need that robust plugin (or you can even make a couple of spheres and save them as components and keep reusing them)
      πŸ˜‰
      • E
        Ecuadorian
        That's why I said: πŸ˜„
        @ecuadorian said:
        If you have SketchyPhysics installed, use it to easily create a sphere with the SketchySolids toolbar.
        -Miguel Lescano
        • W
          Wizaerd
          Is there something I can submit or show that'll help troubleshoot the porblem I'm having with it? Because everytime I try to use it (just choosing the menu option in the right click menu) causes my SU to crash, each and every time.
          • jeff hammondJ
            i guess you could post the .skp of your sphere along with the texture to make sure those aren't causing a problem..
            fwiw, it works for me with su7.1
            [edit] oh, make sure you have the proper face (front) showing.. if i'm trying to map the sphere with the back face showing -- instacrash..
            also, make sure there is a texture on the sphere before using the tool.. trying to use the tool on the blank sphere will crash su
            • W
              Wizaerd
              I suppose I can send the sphere, but it's just a basic sphere. Created a circle, deleted half of it, used the follow me tool to create the sphere, made sure the faces were all pointing outwards. As far as the texture, I never get to that point. I select the sphere, right click to choose UV Tools->Spherical Mapping and SU crashes, so there's no texture involved. At all. And it consistently crashes each and every time...
              EDIT
              Never mind, I get what's wrong... Never dawned on me I had to have a texture applied before I run the plugin... Completely my fault... D'uh.
              Sphere.skp
              • jeff hammondJ
                ha, yeah.. afterall, you are trying to map the texture πŸ˜„
                • W
                  Wizaerd
                  I assumed the plugin was creating UV coordinates so that when a texture was applied, it would use them. I really feel kinda stupid now... heh heh heh
                  • KrisidiousK
                    Krisidious
                    is there a box mapping function for this?
                    By: Kristoff Rand
                    • jarynzlesaJ
                      jarynzlesa
                      good work - thank you πŸ‘ .
                      http://www.vizualizaceschodiste.mypage.cz/
                      • G
                        Globalist
                        Thank you so much.Very kind of you (all).
                        Regards.
                        • C
                          caarloos82
                          Thank you for your plugin. Between all of you (pluginΒ΄s developers) are going to do of sketchup a software as good or even better than softwares like rhinoceros.
                          cheers
                          • RichardR
                            Richard
                            Thomas!
                            Mate I played around with the plugin for a tree trunk in combination with fredoscale and I ended up with a mass of assigned materials (all the same) when exported to maxwell. I noted this before with Whaat's UV tools (cant remember the name of the plugin).
                            Funny though it was only for several faces - I'll have to test some more and see what went on there!
                            BUILTBRAND.COM.AU
                              This is Whaat's UV Tool thread?
                              Are you looking for Thomthom UV Toolkit 2.1.0?
                              http://forums.sketchucation.com/viewtopic.php?t=18992
                                @richard said:
                                Thomas!
                                I'm not entirely sure, but I'm guessing the Maxwell exporter exported out a texture for each face with a distorted texture.
                                • RichardR
                                  Richard
                                  yep! They didn't call me Richard (dick) for nothing! That's funny - just clicked on thread from "view your posts" and bang wrong one!
                                  Yes Thomas - I'll continue this to your tool thread!
                                  Sorry Dale for getting off topic!
                                  BUILTBRAND.COM.AU
                                    No hassle Dic....Richard! How Thom found it here i another story..... 😲
                                      I'm connected to the Matrix. πŸ€“
                                      • K
                                        Khai
                                        that explains the glasses....
                                        • sadyoS
                                          sadyo
                                          Can not using this plugin on SU Pro 8.0.4811, everytime i try to using it, it's make SU Bugsplat
                                          It's happening too with UVTools v0.2 ❓ ❓ ❓ ,
                                          • sadyoS
                                            sadyo
                                            Oops...Sorry 😳 It's working pretty well on SU8 now, when i try to using it with Jeff Hammond Tips
                                            • 8 / 9
