    [Plugin] UVTools v0.1
    180 Posts 71 Posters 150.6k Views 71 Watching
    • W Offline
      Wizaerd
      @ecuadorian said:
      No need to create a sphere the hard way. If you have SketchyPhysics installed, use it to easily create a sphere with the SketchySolids toolbar. UVtools will map it without problem, except for a few hurricanes in both poles.
      I didn't necessarily think that method of creating a sphere was hard or difficult. Plus the plugin you reccommended, SketchyPhysics, seems a bit overkill just to create a sphere... I don't use Sketchup for animations, so physics aren't really necessary for what I'm using it for, unless I'm missing something...
        Hehe. True - for a couple of second job you really don't need that robust plugin (or you can even make a couple of spheres and save them as components and keep reusing them)
        πŸ˜‰
        • E Offline
          Ecuadorian
          That's why I said: πŸ˜„
          -Miguel Lescano
          • W Offline
            Wizaerd
            Is there something I can submit or show that'll help troubleshoot the porblem I'm having with it? Because everytime I try to use it (just choosing the menu option in the right click menu) causes my SU to crash, each and every time.
            • jeff hammondJ Offline
              i guess you could post the .skp of your sphere along with the texture to make sure those aren't causing a problem..
              fwiw, it works for me with su7.1
              [edit] oh, make sure you have the proper face (front) showing.. if i'm trying to map the sphere with the back face showing -- instacrash..
              also, make sure there is a texture on the sphere before using the tool.. trying to use the tool on the blank sphere will crash su
              • W Offline
                Wizaerd
                I suppose I can send the sphere, but it's just a basic sphere. Created a circle, deleted half of it, used the follow me tool to create the sphere, made sure the faces were all pointing outwards. As far as the texture, I never get to that point. I select the sphere, right click to choose UV Tools->Spherical Mapping and SU crashes, so there's no texture involved. At all. And it consistently crashes each and every time...
                EDIT
                Never mind, I get what's wrong... Never dawned on me I had to have a texture applied before I run the plugin... Completely my fault... D'uh.
                Sphere.skp
                  ha, yeah.. afterall, you are trying to map the texture πŸ˜„
                  • W Offline
                    Wizaerd
                    I assumed the plugin was creating UV coordinates so that when a texture was applied, it would use them. I really feel kinda stupid now... heh heh heh
                    • KrisidiousK Offline
                      Krisidious
                      is there a box mapping function for this?
                      By: Kristoff Rand
                      • jarynzlesaJ Offline
                        jarynzlesa
                        good work - thank you πŸ‘ .
                        http://www.vizualizaceschodiste.mypage.cz/
                          Globalist
                          Thank you so much.Very kind of you (all).
                          Regards.
                            caarloos82
                            Thank you for your plugin. Between all of you (pluginΒ΄s developers) are going to do of sketchup a software as good or even better than softwares like rhinoceros.
                            cheers
                            • RichardR Offline
                              Richard
                              Thomas!
                              Mate I played around with the plugin for a tree trunk in combination with fredoscale and I ended up with a mass of assigned materials (all the same) when exported to maxwell. I noted this before with Whaat's UV tools (cant remember the name of the plugin).
                              Funny though it was only for several faces - I'll have to test some more and see what went on there!
                              BUILTBRAND.COM.AU
                                This is Whaat's UV Tool thread?
                                Are you looking for Thomthom UV Toolkit 2.1.0?
                                404 Not Found
                                (forums.sketchucation.com)
                                  @richard said:
                                  Thomas!
                                  I'm not entirely sure, but I'm guessing the Maxwell exporter exported out a texture for each face with a distorted texture.
                                  • RichardR Offline
                                    Richard
                                    404 Not Found
                                    yep! They didn't call me Richard (dick) for nothing! That's funny - just clicked on thread from "view your posts" and bang wrong one!
                                    Yes Thomas - I'll continue this to your tool thread!
                                    Sorry Dale for getting off topic!
                                    BUILTBRAND.COM.AU
                                      No hassle Dic....Richard! How Thom found it here i another story..... 😲
                                        I'm connected to the Matrix. πŸ€“
                                          Khai
                                          that explains the glasses....
                                          • sadyoS Offline
                                            sadyo
                                            Can not using this plugin on SU Pro 8.0.4811, everytime i try to using it, it's make SU Bugsplat
                                            It's happening too with UVTools v0.2 ❓ ❓ ❓ ,
                                            • 8 / 9
