    [Plugin] UVTools v0.1
    180 Posts 71 Posters 150.6k Views 71 Watching
    • plot-parisP Offline
      plot-paris
      😳 thank you.
      I wish ruby programming was as easy 😄 (I never went beyond the "hello world" stage...)
        lewiswadsworth
        @plot-paris said:
        :oops: thank you.
        I can program in Ruby, and I hate it. I hate programmming in OO languages. I just hate it...the whole non-native-language grammatical lexicon of UML languages and their contrived set of relationships. Classes, methods, instances...Pahhh!...object-orient THIS!
        Normally I resist suggesting major changes to SU, but I really think they missed the boat with scripting in SU. Other programs are implementing true visual programming languages, with immediate uptake on the part of users:
        http://grasshopper.rhino3d.com/
        col sporcar si trova
        • MALAISEM Offline
          MALAISE
          What 'else , an another amazing tool .
          Champagne .....
          • MALAISEM Offline
            MALAISE
            Hi everybody
            Does anyone use the plugin ? Could we have just a simple tuto ?
            I forget something because SU goes out as far as I start UVTool
            MALAISE
              addicted2ownage
              great work !!! 😍 thank you very much 😄
              • G Offline
                gaucho
                I'm having problems using this plug-in. But I’m maybe using in the wrong way.
                I normally use the SU in “color by layers” and not with normal materials. This ‘cause the way that people draw in the office, and also to make my file smaller (since they always have more than 100mega)
                Sometimes, rarely, I use in the same mode, an image as layers color to show an specific situation. This is when the problem occurs; apparently I’m not able to use this plug-in in this mode.
                Is that right?
                Does anyone know something about it?
                Thanks!
                "eat well, stay fit, die anyway..."
                • bigstickB Offline
                  bigstick
                  Using colour by layer isn't the best way to assign textures. It isn't really compatible with most renderers for a start. Although it is very efficient for modelling, it doesn't allow any flexibility for positioning textures on surfaces at all.
                  It would be useful to have a Ruby plugin which reads these textures from layers and assigns them directly to faces.
                    plot-paris
                    as far as I know there is a ruby that does exactly that. has been discussed here somewhere. don't ask me where though.
                    • G Offline
                      gaucho
                      So that means the ruby script won't work in the "colour by layer" mode... snif...
                        jstahlman
                        @whaat said:
                        This plugin is a work in progress. There is much functionality yet to be added but it is still quite useful in it's current state so I am releasing it.
                        Installation:
                        1. Copy to SketchUp/Plugins folder
                        Usage:
                        1. The plugin will create a context menu called 'UVTools'
                        I put the UVtools.rb file in Macintosh HD/Library/Application Support/Google Sketchup 6/SketchUp/Plugins
                        I also tried Users/myname/Library/Application Support/Google Sketchup 6/SketchUp/Plugins
                        But it no contextual menu shows up when relaunching SU
                        • K Offline
                          kwistenbiebel
                          @Whaat,
                          I can't seem to find a way to apply the cilindrical uv-mapping to both sides of a surface.
                          Any suggestion on how to do that?
                          I' m curently trying to render a clipmap texture which is cilindrical mapped on a cilinder using Fryrender.
                          Having the ability to map both sides of the cilinder surface would be a big Plus.
                          Thanks in advance.
                          • soloS Offline
                            solo
                            LOL, I had that exact situation last week, trying to map a barbed wire fence clipmap/alpha to a sphere. There was no way I could map the back faces. 😕
                            I ended up using Hexagon (nurb modeler) to map the sphere and import it.
                            http://www.solos-art.com
                            • FrederikF Offline
                              Frederik
                              Would that be necessary to map the back-face with the clip-map for a render..?? 😕
                              I assume that the clip-map is identical to the actual texture in size, and in the render application you apply the clip-map texture in the clip-mapping channel...
                              Or what am I missing..?? 😕
                              Cheers
                              Kim Frederik
                                remus
                                Im guessing this isnt the case in other renders, but in indigo its pretty useful to map clip/displacement maps on to the reverse faces. its an easy way to get the UVs right without having to do lots of messing around.
                                • K Offline
                                  kwistenbiebel
                                  In some cases it is not needed.
                                  But in my case and the case Solo describes a cilindrical mapped fence seen on both sides in an animation, it is useful.
                                    coo_man
                                    Thanks brother, this is very useful for me.
                                      Are you sure of that? Nurbs : I don't think so 😉
                                      • soloS Offline
                                        solo
                                        Hexagon is primarily a subdivision modeler however, the new version has deformers (Twist, Bend, Taper) which work on subparts of objects. A new and more generic deformer has been added: the Free From Deformation Cage, which allows smooth complex deformations of a model, using a 3D Nurbs cage.
                                        • F Offline
                                          fakircho
                                          I gave the UV tool a try and it works ok but i am getting some weird issues.
                                          See attached, any ideas why it is doing that ?
                                          • W Offline
                                            Whaat
                                            Looks weird....are you using spherical or cylindrical? I would suggest using cylindrical. Also...what is the scale of your object? The plugin might fail on faces that are very small so try increasing the size of the object.
                                            • 6
                                            • 7
                                            • 8
                                            • 9
                                            • 5 / 9
