    [Plugin] UVTools v0.1
    180 Posts 71 Posters 155.4k Views 71 Watching
    • K
      kwistenbiebel
      @Whaat,
      I can't seem to find a way to apply the cilindrical uv-mapping to both sides of a surface.
      Any suggestion on how to do that?
      I' m curently trying to render a clipmap texture which is cilindrical mapped on a cilinder using Fryrender.
      Having the ability to map both sides of the cilinder surface would be a big Plus.
      Thanks in advance.
      • soloS
        LOL, I had that exact situation last week, trying to map a barbed wire fence clipmap/alpha to a sphere. There was no way I could map the back faces. 😕
        I ended up using Hexagon (nurb modeler) to map the sphere and import it.
        • FrederikF
          Frederik
          Would that be necessary to map the back-face with the clip-map for a render..?? 😕
          I assume that the clip-map is identical to the actual texture in size, and in the render application you apply the clip-map texture in the clip-mapping channel...
          Or what am I missing..?? 😕
          Cheers
          Kim Frederik
            remus
            Im guessing this isnt the case in other renders, but in indigo its pretty useful to map clip/displacement maps on to the reverse faces. its an easy way to get the UVs right without having to do lots of messing around.
            • K
              kwistenbiebel
              In some cases it is not needed.
              But in my case and the case Solo describes a cilindrical mapped fence seen on both sides in an animation, it is useful.
              • C
                coo_man
                Thanks brother, this is very useful for me.
                  Are you sure of that? Nurbs : I don't think so 😉
                  • soloS
                    Hexagon is primarily a subdivision modeler however, the new version has deformers (Twist, Bend, Taper) which work on subparts of objects. A new and more generic deformer has been added: the Free From Deformation Cage, which allows smooth complex deformations of a model, using a 3D Nurbs cage.
                    • F
                      fakircho
                      I gave the UV tool a try and it works ok but i am getting some weird issues.
                      See attached, any ideas why it is doing that ?
                      • W
                        Whaat
                        Looks weird....are you using spherical or cylindrical? I would suggest using cylindrical. Also...what is the scale of your object? The plugin might fail on faces that are very small so try increasing the size of the object.
                        • TaffGochT
                          TaffGoch
                          Using Whaat's plugin, texture from NASA's "Blue Marble" project, and a 4096-pixel OpenGL-texture registry hack, I'm delighted to find that I can reproduce (totally within SketchUp) results comparable to the Blue Marble globe images on the NASA webpage! (No external rendering - these are cropped SketchUp screen grabs.)
                          (I was inspired to try this after seeing José Manuel's model at the 3D Warehouse...
                          http://sketchup.google.com/3dwarehouse/details?mid=65929d262a58d9e8fdaa51cdb5785d22
                          ...and wondered whether I could push texture resolution to its max.)
                          Marvelous tool, Dale You've fulfilled a wish! 😍
                          (...and, of course, I used a geodesic sphere to provide the triangular tessellation.)
                          Taff
                          "Information is not knowledge." -- Albert Einstein
                          • F
                            fakircho
                            i made the object 10 times bigger and the UV is much better
                            • GaieusG
                              I gues now you can safely reduce the size back without braking the UV.
                              Good to know such tricks, thanks Whaat! 👍
                              • F
                                fakircho
                                Yes you are quite correct. Once the texture is applied correctly ,you can scale the object back down 😄
                                • B
                                  bbwolf
                                  Okay I know you´re all big shots and do renderings at an amazing rate but I still can´t get desired results in SU. UVTools is in the Plug in Folder (OSX 10.4.9 btw) and I tried to project a text. See attached pics.
                                  Question, is text just not for UVTools or do I make a mistake (or more) somewhere in process?
                                  Any help would be appreciated, thanks
                                  Wolf
                                  • GaieusG
                                    Do you want the text to be repeated or only appear at the same size and only once?
                                    • majidM
                                      majid
                                      Thanx dear WHATT .i did a try over this usefull script ( after a long while ) , and rendered it using KT, here is the result:
                                      http://www.sketchucation.com/forums/scf/viewtopic.php?f=81&t=14993
                                      hope u joy
                                      • C
                                        crc
                                        Just found this, really great!
                                        http://www.motoclip.net
                                        • C
                                          chango70
                                          Is UVTools still on v0.1? Does it work in SU7?
                                          • W
                                            Whaat
                                            should work fine on SU7
                                            • 5 / 9
