    [Plugin] UVTools v0.1
    180 Posts 71 Posters 160.5k Views 71 Watching
    • plot-parisP
      plot-paris
      as far as I know there is a ruby that does exactly that. has been discussed here somewhere. don't ask me where though.
      • G
        gaucho
        @bigstick said:
        Although it is very efficient for modelling, it doesn't allow any flexibility for positioning textures on surfaces at all.
        So that means the ruby script won't work in the "colour by layer" mode... snif...
        "eat well, stay fit, die anyway..."
          jstahlman
          @whaat said:
          This plugin is a work in progress. There is much functionality yet to be added but it is still quite useful in it's current state so I am releasing it.
          Installation:
          1. Copy to SketchUp/Plugins folder
          Usage:
          1. The plugin will create a context menu called 'UVTools'
          I put the UVtools.rb file in Macintosh HD/Library/Application Support/Google Sketchup 6/SketchUp/Plugins
          I also tried Users/myname/Library/Application Support/Google Sketchup 6/SketchUp/Plugins
          But it no contextual menu shows up when relaunching SU
          • K
            kwistenbiebel
            @Whaat,
            I can't seem to find a way to apply the cilindrical uv-mapping to both sides of a surface.
            Any suggestion on how to do that?
            I' m curently trying to render a clipmap texture which is cilindrical mapped on a cilinder using Fryrender.
            Having the ability to map both sides of the cilinder surface would be a big Plus.
            Thanks in advance.
            • soloS
              LOL, I had that exact situation last week, trying to map a barbed wire fence clipmap/alpha to a sphere. There was no way I could map the back faces. 😕
              I ended up using Hexagon (nurb modeler) to map the sphere and import it.
              • FrederikF
                Frederik
                Would that be necessary to map the back-face with the clip-map for a render..?? 😕
                I assume that the clip-map is identical to the actual texture in size, and in the render application you apply the clip-map texture in the clip-mapping channel...
                Or what am I missing..?? 😕
                Cheers
                Kim Frederik
                  remus
                  Im guessing this isnt the case in other renders, but in indigo its pretty useful to map clip/displacement maps on to the reverse faces. its an easy way to get the UVs right without having to do lots of messing around.
                  • K
                    kwistenbiebel
                    In some cases it is not needed.
                    But in my case and the case Solo describes a cilindrical mapped fence seen on both sides in an animation, it is useful.
                    • C
                      coo_man
                      Thanks brother, this is very useful for me.
                        Are you sure of that? Nurbs : I don't think so 😉
                        • soloS
                          Hexagon is primarily a subdivision modeler however, the new version has deformers (Twist, Bend, Taper) which work on subparts of objects. A new and more generic deformer has been added: the Free From Deformation Cage, which allows smooth complex deformations of a model, using a 3D Nurbs cage.
                          • F
                            fakircho
                            I gave the UV tool a try and it works ok but i am getting some weird issues.
                            See attached, any ideas why it is doing that ?
                            • W
                              Whaat
                              Looks weird....are you using spherical or cylindrical? I would suggest using cylindrical. Also...what is the scale of your object? The plugin might fail on faces that are very small so try increasing the size of the object.
                              • TaffGochT
                                TaffGoch
                                Using Whaat's plugin, texture from NASA's "Blue Marble" project, and a 4096-pixel OpenGL-texture registry hack, I'm delighted to find that I can reproduce (totally within SketchUp) results comparable to the Blue Marble globe images on the NASA webpage! (No external rendering - these are cropped SketchUp screen grabs.)
                                (I was inspired to try this after seeing José Manuel's model at the 3D Warehouse...
                                http://sketchup.google.com/3dwarehouse/details?mid=65929d262a58d9e8fdaa51cdb5785d22
                                ...and wondered whether I could push texture resolution to its max.)
                                Marvelous tool, Dale You've fulfilled a wish! 😍
                                (...and, of course, I used a geodesic sphere to provide the triangular tessellation.)
                                Taff
                                "Information is not knowledge." -- Albert Einstein
                                • F
                                  fakircho
                                  i made the object 10 times bigger and the UV is much better
                                  • GaieusG
                                    I gues now you can safely reduce the size back without braking the UV.
                                    Good to know such tricks, thanks Whaat! 👍
                                    • F
                                      fakircho
                                      Yes you are quite correct. Once the texture is applied correctly ,you can scale the object back down 😄
                                      • B
                                        bbwolf
                                        Okay I know you´re all big shots and do renderings at an amazing rate but I still can´t get desired results in SU. UVTools is in the Plug in Folder (OSX 10.4.9 btw) and I tried to project a text. See attached pics.
                                        Question, is text just not for UVTools or do I make a mistake (or more) somewhere in process?
                                        Any help would be appreciated, thanks
                                        Wolf
                                        • GaieusG
                                          Do you want the text to be repeated or only appear at the same size and only once?
                                          • majidM
                                            majid
                                            Thanx dear WHATT .i did a try over this usefull script ( after a long while ) , and rendered it using KT, here is the result:
                                            http://www.sketchucation.com/forums/scf/viewtopic.php?f=81&t=14993
                                            hope u joy
                                            • 5 / 9
